Everything posted by dwcraig1
asmodus oni 167 check battery issue
dwcraig1 replied to kristine4899's topic in Batteries and Charging
It appears that you have reset the board to default values which would set it for 3 cells. Connect to eScribe and go to Mod/Battery and change from 3 cell to 2 cell and upload settings. -
I buy from here. You can refine your search on the left side of the page pretty well. https://hobbyking.com/en_us/batteries-chargers/batteries/lipo.html
You need a new battery. The voltage is way to low to safely charge it.
How do i upload pictures of my themes?
dwcraig1 replied to valdozandrew's topic in Themes and Custom Screens
This is something that I have never done till now. On the the top of forum page I choose create then file download then Theme Park. Select which DNA group. I had saved the theme to desktop using EScribe. The images are there once your post is opened. -
Image of DNA250 non-color firing dry wick with 316L clapton coil with .5 second 60 watt boost then 40 watts. Same was done with DNA250 Color and results were similar. I had to hold firing button for several seconds before wick would show signs of burning, 15 seconds fire time. Voltage output dropped to 1 - 2 volts on both.
You should ask here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
From what I see you must have a dual battery DNA75C. If what the arrow in the image is pointing too is what you are asking about and are concerned with where the wire from it goes, it goes to battery negative on the board. If not your question please post a photo of the part.
Here is a snip of my 250C at 91% (left side) and 94% (right side), looks pretty similar to your Centaurus
Original theme Vicious ant Club omega
dwcraig1 replied to Voodoo's topic in DNA 75 Color and 100 Color
If you have connected it previously to EScribe when the desired theme was present then you most likely have a back up .ecig file for it. Under the Help/Backups. -
It is not meant to fix anything just info. Do this: Start Atomizer with no atty. Now start screwing in atty. Note how many turns or partial turns from where Atomizer Analyzer starts reading ohms till it's screwed in all the way.
Try using Atomizer Analyzer in EScribe to see if atty has a connection or not and post findings.
Hook it up with Escribe and see what matches up.
I don't know but could it be the profile number that your using?
Most but likely not all screen problems develop because of the ribbon getting pinched by the pressing of the fire button when the ribbon wasn't folded properly
