dwcraig1
Everything posted by dwcraig1
  1. Version 1.0.0
    227 downloads
    I added the first two screens to default Evolv theme only
  2. This is something that I have never done till now. On the the top of forum page I choose create then file download then Theme Park. Select which DNA group. I had saved the theme to desktop using EScribe. The images are there once your post is opened.
  3. I did see the "B" but at the time didn't realize it was "Board" I think you have found the problem......or a problem. Earlier screen shots doesn't show it that hot.
  4. If your mod's resistance is 0.004 ohm and you set it to 0.002 or 0.005 it will make almost no difference to your problem.
  5. Are you setting your cold resistance again after the coil is heated? If so it will use that setting as the cold resistance and be hotter than what it reports.
  6. Try to keep it 220 C degrees or lower. If you want to use spaced coils try making the wraps closer together. I use contact coils only but many prefer spaced, your choice. Try to keep the whole coil in the air flow.
  7. It looks to me that the mod maybe is jumping out of TC and into wattage mode. Device Monitor in EScribe will help determine that. Perhaps poor connections between board and coil resulting in artificial resistance readings.
  8. Image of DNA250 non-color firing dry wick with 316L clapton coil with .5 second 60 watt boost then 40 watts. Same was done with DNA250 Color and results were similar. I had to hold firing button for several seconds before wick would show signs of burning, 15 seconds fire time. Voltage output dropped to 1 - 2 volts on both.
  9. You should ask here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
  10. From what I see you must have a dual battery DNA75C. If what the arrow in the image is pointing too is what you are asking about and are concerned with where the wire from it goes, it goes to battery negative on the board. If not your question please post a photo of the part.
  11. Here is a snip of my 250C at 91% (left side) and 94% (right side), looks pretty similar to your Centaurus
  12. If you have connected it previously to EScribe when the desired theme was present then you most likely have a back up .ecig file for it. Under the Help/Backups.
  13. It is not meant to fix anything just info. Do this: Start Atomizer with no atty. Now start screwing in atty. Note how many turns or partial turns from where Atomizer Analyzer starts reading ohms till it's screwed in all the way.
  14. Try using Atomizer Analyzer in EScribe to see if atty has a connection or not and post findings.
  15. Hook it up with Escribe and see what matches up.
  16. I don't know but could it be the profile number that your using?
  17. Most but likely not all screen problems develop because of the ribbon getting pinched by the pressing of the fire button when the ribbon wasn't folded properly
  18. It must be a red transparent plastic film placed over the screen as I have never seen one yet.
  19. https://forum.evolvapor.com/topic/71411-no-taste-on-temperature-control-just-empty-as-if-nothing-was-missing-zero-taste-of-liquid-help-to-make-the-best-taste/?do=findComment&comment=935201
  20. No that setting is not there for the C boards or their other boards either.
