Everything posted by dwcraig1
Warranty service when connected to external USB charger
dwcraig1 replied to dl12345's topic in Installation and Assembly
Are you able to use a different cable with your external charger? I recall having a problem with getting "warranty service" message once but can't remember if it was from a particular cable or USB port. -
Will it connect to EScribe? You might get some useful info from there.
Your image show 6.54 volts output, this will be dependent on the cell's charge state. But lets just assume that is the boards maximum voltage output. Then figure in your .26 ohm SS coil. As the coil heats up the resistance will increase a bit, let's guess to 0.29 ohms. https://www.the12volt.com/ohm/ohms-law-calculators.asp Keep in mind that as the charge on the cells go down the voltage output will never be higher than the sum of the voltage drop. Example: cell voltage drops to 2.9 volts per cell under load. Max voltage output will not exceed 5.8 volts. If your settings call for more than that the error may show at end of puff.
It looks to me that you are hitting the set temperature and the board is throttling down the power. Your lowest voltage drop on the pair of cells appears to be 7.08 volts, half being 3.54 volts, well above the 2.75 volt cutoff. Could you post the entire screen with the boxes checked like this snippet?
On the DNA250C with 2 cells I don't know the maximum voltage output but I'm pretty sure that isn't much more than a DNA250 running on 2 cells which is 6.2 volts.
I'm curious as to why you are talking about temperature when it doesn't apply. Sure Device Monitor shows the "set line" but the board does absolutely nothing with the temp setting in this case.
So I did some testing with some of mine, here are the results: Using my meter to measure output voltage off the posts. DNA75-- 0.98 ohms--17 watts-- 4.04 volts. DNA75C--0.99 ohms-- 17 watts-- 4.03 volts Dna250C-- 0.98 ohms--17 watts-- 4.03 volts Kanthal coil All mods have internal resistance set. I figure that FW causes slight variances with resistance readings So they say they don't compare vape wise, maybe slight adjustment required to power. I say *****, either that or I need a new meter. The board is probably better than most meters anyway.
This way is the way to contact Evolv" https://helpdesk.evolvapor.com/index.php?a=add&category=1
If yours is a DNA250C it takes the color screen, I'm not sure of the size without looking it up but all the DNA color screens are the same size. TFT color screen for DNA75C, DNA100C and DNA250C
Protovapor still has some color screens. https://www.protovapor.com/product/replacement-dna-screen/
If you use Google Chrome or the new Edge for your browser just right click the text in the post and select "translate to English". On occasion you might need to adjust the language being input, choosing "detect language" is easiest.
lost vape dna 250c temperature cannot go higher than 180C
dwcraig1 replied to rin's topic in DNA 250 Color
Here is an example of what's requested, this is done with Windows Snipping Tool but any screen grab will do. -
Up at the top of EScribe under the Help there is a Backups tab, this automatically does backups when connected to a device and you can pick and choose from various backups by board and date.
Most folks use the Replay profile, and of coarse wattage is selected as material though TC wire is required. Or you can enable Replay in the TC profiles as you desire. It's just super easy to use it without TC.......but either way. Now does your TC work? Edit: I guess you answered that in the post above.
Your SS316 profile should look like this except your power settings ect. will be as you want. In this profile Relpay is enabled. It is optional, your choice. Disregard the box puff playing. No need to check that.
I will try to help you with it. Connect your 250C to EScribe and click "Mod" tab then "Safety" tab and using the drop down menu change from "normal coils" to "dubious coils" and upload settings to device.
It just keeps the software as is till the application to the government is approved or denied, Things had to stay as they were from US vape manufacturers till the cutoff date. Note Evolv sell nothing to individual any longer. The software is considered nicotine. Even zero nicotine e-liquid is considered nicotine. The big tobacco companies have their vape products for sale all over.
Federal laws, the government thinks we should smoke tobacco and pay the taxes on the cigarettes. Nothing new was allowed the be added to an existing product. Every piece of your vape is considered nicotine in the US. The ;land of the free.......right?
I would think that the reason that it's not in the latest EScribe is because an update wasn't needed. I can't think of anything that needs fix'n
If the firmware is the US version that is the problem. Restore to default as last resort and only after you saved your original configuration.
Proceed with caution
And while they last: https://www.protovapor.com/product/replacement-dna-screen/
Oh, I seemed to have overlooked this, make sure that you are using the International firmware. In the bottom right lower corner of Device Monitor will show the current firmware that's being used.
Perhaps save your current configuration. Under File/Save As
