retird
Everything posted by retird
  1. In the first shot you reach the set temperature ( 180C) quickly (red line) thus the device throttles back. In the second shot your device settings never let you reach your 220C set temperature ( red line) as it peaks at 191+ C.
  2. Works now and I hear the click but not the whistle.... all my volumes are at maximum..... Which mod is that? I deleted the 2 posts that did not work......😊
  3. Can't get either one to work.... runs for just a second with no audio volume at all....
  4. Can you post an audio file or video file so we can hear/see what you are hearing? Never had one whistle or a chirp..... THX
  5. If you have latest EScribe then any SP updates will be available to you to update.... it will tell you an update is available....
  6. If you can Save and Post the "ecigtheme" file here we can upload it and look at it. Themes can be different depending on how they are designed...
  7. Setting atty specific profiles is the way some folks set up their devices and atty's thus it was just a suggestion for you to consider trying. It is not for you the way I read your post.... Good that you started a ticket..... let us know what you find out..... Does this happen with all your atty's or just specific atty's....unless I overlooked your post you didn't say...
  8. Are you taking an atty off of another device and putting it on the device while the atty is still warm? You might try this and see what the results will be....: Create a Profile for each atty using Replay..... Use each Atty with it's corresponding Profile.....
  9. That YouTube..... Must be an an early version on the 75C as it does not show Boost or Replay.... When Boost and Replay were added the function you seek went away........
  10. hum......, we know that as batteries age they lose capacity. Here is a screenshot showing my 250C Li-Po pack at full charge. It shows 100% charge in Device Monitor and it also shows 100% and "Full Charge" on my device screen with the Theme I use. Run Battery Analyzer or do the quick fix as @Wayneo just posted and see what results you get. FOOTNOTE: From quick Google search...... Charging a battery forces ions from the cathode to the anode; using the batteryreverses the flow. Over time, this process wears out the cathode, which results in reduced capacity. A high-end lithium-polymer battery can lose about 20 percent of its capacity after 1000 charge cycles.
  11. Can you give a screenshot of Device Monitor while firing the device?
  12. You don't have that option .... but you can change Preheat Punch to Temperature..... set the Preheat Temperature @ where you want it to cut off. Example: You want it to Preheat up to 400F when Temperature is set to 450F.... Will that work for you?
  13. Good.... yep the longer you run the analyzer the numbers will climb because the analyzer slightly heats the atty.... glad we got to the bottom of your concern...
  14. This just could be that you are seeing Cold ohms from Atty Analyzer whereby when using atty analyzer it slightly warmed the atomizer giving the Cold ohms. In use it reads live ohms thus the drop.... I had to dig up a Kanthal coil to see how it reacts as I seldom use Kanthal. My Kanthal coils show the same thing.... Here is my screenshot using a DNA250C device with a pre-made coil head rated at 0.60 ohms........
  15. So what do you get while firing?
  16. Was the atty warm from use when you put it on the device and told it was new coil? You might try building a new coil.... put it in a cool atty that hasn't just been used..... put on device and run Analyzer then fire....when asked select New Coil..... vape a bit.... what are your results???
  17. Hope you get it sorted out..... let us know......
  18. I posted that so you could get the CSV file for your batteries not for the case analyzer information.... yep google is your friend.... If no one has the info you want why not run analyzer yourself.... and post your results for others.... we try to share and help here.....
  19. Googled this forum and found this.... click on it and see if that is the 3 cell CSV file you are wanting.... google is your friend....
  20. 32 A and 30 A......... Default Settings from Evolv for DNA250C and ........Evolv Default Settings of 28 A and 28 A for the DNA250
  21. Here is a CSV battery profile from my ERM DNA250C which charges to full charge and shows 100% charge in Device Monitor and on the device screen. Give it a try after vaping your batteries down to at least 95%.... 250c.csv
  22. From your Screenshots you can see that TC is trying to get to Set Temperature of 210.00 @ 17 watts but only gets to 194.00. Raising the wattage a bit or adjusting preheat should let it get to Set Temperature. We know that is how the 250C board manages TC. Now in Replay Mode the device (DNA250C board) manages in the background many functions to achieve consistent repeated vapes. I don't know how it manages things but it does. I assume you are vaping 1 vape then setting Replay.... try vaping 2 vapes then set Replay and see what it looks like in Device Monitor. Maybe I'm not understanding what the issue is? Is your issue that you get the same vape in Replay as you get in TC mode but just at different Temp and Watts as seen in Device Monitor?
  23. TC and Replay manage things differently as I understand. The end result is the same quality of vape.
