  1. If lowering the screen brightness doesn't make it visible, sounds like you might need a new one. I'd suggest you open a ticket with the Help Desk. Link in my signature.
  2. That's 3 separate cells sharing the full charging rate. So effectively that's charging at just under .7A per cell.
  3. Nichrome is NOT a TC wire. No material file necessary. If you're lucky it might work with straight watts in Replay. Cross your fingers. Material files do not care about build specs AT ALL.
  4. WHAT WIRE (material) TYPE ARE YOU MISSING? Right on their site, on the Wire Wizard tab, you can read more help/details below the boxes under TCR. Quick and dirty: Choose wire types from boxes, top right box you'll see a little graph, click dna200 box to download. THEN: FOLLOW the posts by @dwcraig1 here.
  5. Your mod display will benefit from a more accurate battery curve and Wh setting. You have at least 2 options. Follow this to see the Mod tab, then under battery tab you can run the battery analyzer. Option 1. Search the forum for your battery type, and use what someone else created as your parameters. Option 2. Run your own Battery Analyzer, and when done, upload settings to your mod. Anytime you make changes in escribe, you always have to upload them to to your mod.
  6. This will let you see the mod tab.
  7. Welcome and no worries. I believe it also would've required you to run in Power Supply mode. Cheers
  8. "So the big question is does the balancer do anything else whilst in use" Well of course it does. 2 big ones IMHO are How will you or the board know the cell charges ? Why would you want to disable the many battery safety management aspects? Although they recommend wiring the JST connector directly to the board, why don't you just run a small enough length of wire x 5, to the jst connector that you can then connect to the batteries jst
  9. You have 2 options. Open a ticket with the Help Desk, they will guide you on the repair process. I do not believe they need any receipt. The link is in my signature. Search the forum for posts by joeblowma. I think he's ripped his apart a couple times if you're handy.
  10. Means 'yes'. Steam-engine ohms law. The message is theme related, so look around in there. Actually 'Screen' tab. Change it up there. I think 2 nd and 3rd option. Right after orientation.
  11. That board has a 6 volt output voltage max with 2 cells, 9v limit with 3 cells. 2 cells -> ~22watts max at 1.7ohms, watts decreasing as the ohms rise. 3 cells ~47 watts max at 1.7. 'Ohms too high' is really just informational, and you can just turn the message off knowing you might be hitting the limits
  12. Good to hear. In this area the topmost pinned post are the discussions on the software, and below it the actual post with software. Early Firmware and EScribe Suite Discussion Thread Early Firmware and EScribe Suite Occasionally there will be an odd release for a specific issue, which will then be incorporated into a larger Service Pack. Enjoy your mod
  13. Gotcha. Click the link below. You'll want to install the EARLY SERVICE PACK EScribe Suite 2.0 SP18
  14. What version of escribe? What OS version on your Mac?
  15. @tennisguru1 Simple Answer: No, as it's not mentioned at all above. Long answer: The DNA75 only ever needed 1 update which was named and released 2016-06-05. You can see your current firmware version in 'Device Monitor', lower right hand corner
  16. Steam-engine. Wire Wizard. Upper right hand box. You'll see equivalents. Use Nickel. In the lower area of the page, use your actual material. Also it's a good way to use different materials on the DNA40 which only had Nickel.
  17. Quick easy answer: Yes! Longer answer: Architecture/thought process change with the C boards. On the C boards, both the resistance and the temp it was measured at is written into the profile number you are/were in. From there the cold ohms at 70F can be calculated (like the 60) and used inTC. OR in theme designer you can change the value displayed to you, to what it would be at 70F.
  18. You can get an official answer here. https://helpdesk.evolvapor.com/?a=add For Question 2, there's a firmware (SP38) you can try in the thread called "Throttling" right here in this DNA 250 Color - General Discussion area. Right now on my browser, it's on Page 4 posted by James. Welcome
  19. @James , my mod with SP35 (told you about this earlier) did not exhibit this until after I created a new screen on the Evolv default theme and had it set to 'return to parent'. After changing that option to 'return to main screen' all is fine at SP35. That mod is still at SP35.
  20. @taffarovsky@yahoo.fr This .ecig file would be the settings for his mod, with his batteries, and its thermal characteristics. The improvements will be that the ambient temperature should be more accurate, and his battery % will be more accurate. Many will just download this and use it, or the tools are there for you to run your own. These are mainly important for very low ohm build Temperature control vaping. Welcome.
  21. Moderator EDIT: Moved to a better area. You'll need to read through this post. Like I already mentioned .... it's a cheat so YMMV. Welcome
  22. You've posted this in the DNA250 Color area. Is your mod a color screen or actually a DNA200 or 250? Yes to the 250 and 250C, there's a cheat for the 200.
  23. Yes. Escribe software link was/ is also in my signature line
  24. Here you go. 1st and last entries.
