Dna 250c Paranormal - clock error - usb not recognized
Wayneo replied to SKL's topic in Report a Bug
@zlollar06 What firmware version is on your mod? -
@Augmentin @Ghoulsfrank What firmware version?
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
@zark Just to clear up a bit of confusion, whenever I've typed "mods" I'm referring to the volunteers in this forum, and nothing else as we really only discuss DNAs here.
Buddy, that was enthusiasm. My question remains, which other mods? There are 5 mods here (volunteers), 3 main developer/owners at Evolv. If you're talking abut Zark, he's not a part of either category. PS I think you might be the first person to ever call me out for 'bad info'. But that's OK, I'm chillin. 😎
Great, then go lock. You finally got the answer you want. What other mods recommend that you lock? And where?
The research tab might help you. Or your stats are downloaded to ecigstats.org or available via ecigstats. Because you own a 'C", there is much more information available to you. They are also on your device. Hobbyquaker's work IIRC was done by the serial commands available. More info in the Research area. If you only use DNAs, ecigstats can colate all the info in one place for a complete picture.
Do you already own a DNA mod? How many mods do you own?
Atomizer is wiggling even when fully tightened.
Wayneo replied to Paramike166's topic in Manuals, Instructions, and Tutorials
I've heard of it less than a handful of times for all their products. There is a nut underneath, but unless your resistance was also fluctuating, I doubt it. But easy enough to check when you get the torx. Just lift it straight up and out, less than an inch. -
If you remove your tank, and look down at the 510 plate, are there a couple tiny torx screws holding it tight? -
I believe there is a UK center for repairs. Lucky for you, as I've dealt with Chinglish and time zone differences. Taken from the LV site. http://www.lvevapor.com/regular-inquiry/#toggle-id-4
@Adam_Aves I notice that another mod answered you before. I also saw what atty you have. I took this from their site Recommended Settings: Triple Titanium w/ Black Ceramic Coil: 20-25W; TC-Ti, 350-400F <- that says you should be using the Titanium material profile and 25 watts & 350-400F 13mm Sequoia Ceramic Donut: 15-25W; TC-Ni, 300-400F <- that says you should be using the Nickel material profile, 15-25watts & 300-400F I can try to answer your questions but I have no clue how things are on your end. I'm sure there are other forums that are more knowledgeable about that atty and settings. My first answer remains the same.
@Adam_Aves I can only vouch for myself and all the other mods here (and I think we'd all give this same answer). Now, my replies in this thread was for the Non color mod, and a year ago. So here goes. On your 250C, if you have stable readings (Atomizer Analyzer) , then NO, you never need to lock the resistance in any mode.
Reset puffs on vt75 without escribe
Wayneo replied to Booster's topic in Manuals, Instructions, and Tutorials
No can do on a NON color board. Here are a couple suggestions Use temp control, which offers dry hit protection Put puffs as one of the displayed items shown, and note it down Get a new C (color) mod and use a theme that allows that reset- 1 reply
- 1
Open/close - 3 color pictures are usually in the datasheet for each board. The connector hinges at the edges, close to the board. I usually grip the connector with my fingers at each side and lift it straight up towards the cable. When you reinstall, there's like a click/detent so you know it's locked in.
Don't wait for the message. Read the resistance of a new cold coil in every profile you think you might use it in. So that would be Replay and the watts at a minimum (and SS316 in your case). I'd say no. I think you meant Device Monitor.
Good, I didn't go that link. Ideally, you've built a coil as a few loops of straight wire that look like tennis balls, and you have a fan blowing on them
@Capobuf Yup, the old screen disconnects value should be zero. The ribbon cable was probably pinched by the fire button. You can put a bend in the new one's or ensure their placement isn't interfering.
@MohKha Thanks, your batteries appear to be firing evenly, that's a good thing. Here's your printscreen back with a few notes on it for you. No need to repost it back here. And maybe you can find a Lyra forum to ask all those other questions.
paranormal dna 250C disassemble
Wayneo replied to Ricardom.016's topic in Manuals, Instructions, and Tutorials
Search for posts by @joeblowma , he's posted some.- 1 reply
- 1
- paranormal
- dna250c
(and 1 more)
Tagged with:
For battery details it's under the Mod tab For the MOD tab to appear - Options (menu bar) -> User Interface -> Manufacture
Batteries talk in volts, but you can see their performance in Device Monitor. Only Click/select cell 1-3 and post a full printscreen while firing. you might want to lower your cell soft cutoff to 2.7-3V I already answered your question 3. Live display.
Wayneo replied to David Campbell's topic in EScribe, Software and Firmware
@Robbchillin Was that plugged in directly, and not through any sort of hub? Have you tried another port? -
Screens aren't normally covered by warranty. You can get replacements from modmaker or stealthvape, both in the UK. Vaporshark's - you'd need to contact as their cables are different. What value? Or post a full printscreen
Sounds quite normal. On my 2, they both came with low puffs (6-10) each, and 1 reset. Sealed. Those puffs were all of the same duration. Exactly 1-2 seconds each (can't remember exactly). Enjoy your mod.
- 2 replies
- dna 250c
- paranormal
(and 2 more)
Tagged with:
Every 'C" board can run the US or Intl version of software. All depends what you load on it. So apart from 75watts, it can now Punch your watts to 100 to heat high mass coils quickly, as well as Replay your puffs.
