  1. Seriously, how do you rate a theme you can't even load. SMH. This should have been, at most a comment not a review. Update your mod to the latest firmware and then try to load it. The font used is clearly shown in escribe, just look through the tabs.
  2. Well yeah. in escribe. Surely you read the release notes for each update.
  3. Did you try turning fill pod off?
  4. What is the version of your firmware? Bottom right hand corner of Device Monitor.
  5. NO, it will not work. Your pod does not house a 'DNA 75 Color, 100 Color or 250 Color' board. There are no themes for the OXVA. At best you can change mainly colors or a wallpaper.
  6. Are you running the latest version of escribe. There was an issue which is now fixed. I just dowloaded and uploaded it successfully to my mod.
  7. NO. Those are re-wraps. Search for 'battery Mooch' and choose from his listings. Known good brands are Sony, Samsung, and Molicel purchased from a reputable supplier.
  8. Read what you quoted a couple times to yourself. And you forgot to answer this Well? What other mods/pods have you used before this, and do any have adjustable wattage? It is common knowledge to start low and increase to where YOU get the best flavor. My very first puff was at that value and it burned my mouth not the coil. So I set it to 11 and worked up to what I liked which was 15. And 14 on the 0.8. I know it was OXVA that set those wattages for each of the different pods, and the .6 for sure matches with their Kanthal version. So you put in an empty pod at your regular watts, the mod lets you vape, and you don't complain of that nasty cotton taste? So after 1 puff you're throwing them out? That's usually what a person does when a coil burns. If you LOWER your watts and put more juice in any of those pods, do they taste burned?
  9. Watts can play a massive role, but the majority of complaints are the exact opposite of yours, with numerous 'fill pod' warnings. You're vaping at the edge. If you read the notes as I suggested, you could use ecigstats, and download a couple of your burnt puffs. The maximum any 0.6Ω coil can reach is 0.558Ω. Yours 0.4158Ω The maximum any 0.8Ω coil can reach is 0.687Ω. Yours 0.6259Ω That's perfectly acceptable, what does not seem right? You hit .62Ω that's so close to the max, ~560F. That won't trigger any warning. For the second time, turn down the watts and try that.
  10. Those are both very close to their maximums. You could turn the both down a couple watts. For me, I run my .6 at 15 watts and the .8 at 14 watts. If you read that firmware thread going up from the bottom you'll see their notes. 128 is the current latest and there is an experimental SP130 in the works (you can use search for more details).
  11. What watts are you using for each pod? Are you using the latest firmware (which won't fix your intermittent fill pod, but does enable more reorting)? The latest is always the last post here. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/page/2/#comments Your Atomizer Analyzer readings are well within the range for each pod. 1. Yes, you are correct. More details here https://forum.evolvapor.com/topic/76121-low-sensitivity-fill-pod-settings-file/#findComment-946026 2&3. Anti Burn shows when a SS pod is inserted. A regular coil will not show that. Yes, it is active and prevent a dry hit in real time. More details here. https://forum.evolvapor.com/topic/76128-the-fill-pod-situation/#findComment-946065 With ~50k puffs between 2 devices, I could not say it's a board issue
  12. When you start escribe with your mod plugged in, you will also be given a notification if there are updates.
  13. @fp1 No, not the latest. The latest is always the last post here. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/page/2/#comments
  14. If that's the evolv default theme Go to settings (cog) -> coil -> boost, then up/down If that's not the evolv default theme, ask the theme designer
  15. There are not 'Themes' per se. All changes you can do are under the 'Display color schemes' in escribe.
  16. You can open a 'Help Desk' ticket and ask them to fix it. Link in my signature line
  17. If you start Device Monitor and enable volts and power, you can see how each mod is operating with your batteries. Here, with an almost 10 year old Sony 18650, for my 30 watts, the voltage drop is ~.55V (not good). When the lowest V (middle vertical line hits ~3V) I'll need to recharge.
  18. You mean check battery? The icon? What value and where? In the 80C you cannot adjust the battery curve which controls the icon or the low cutoff value, as you can in the 60 and 60C. What battery and what watts are you using in the 80C?
  19. Sent you a private message. You need to read and action it.
  20. Wayneo
    Pan
    7 seconds IS the limit. Not a bug. https://forum.evolvapor.com/topic/76116-oxva-xlim-pro-2-dna-max-puff-time-nwkg/#findComment-945935
  21. None of your 3 videos worked or showed up. I don't think if you click on them here they will show for you. AND THAT'S FINE AS I DIDN'T ASK FOR THEM, because I understood your words. In the future (what has worked for me) is use that 'choose files' option and you're done, nothing else to do. 🙂
  22. Just gotta ask. Using that same charger and cable in the same socket, will it show charging on a different device (phone, etc)?
  23. Open a 'Help Desk' ticket here. ⬇️ Link in my signature line. ⬇️
  24. You can try a hardware reboot on the device. (Remove the pod and disconnect from USB. Then hold the Fire button until it reboots. It should take about 10-15 seconds.)
  25. Never heard of this issue before. Here's what I would do, and in this order Contact the place of purchase as it's 'dead on arrival' for a replacement. Contact OXVA as it's 'dead on arrival' for a replacement. Open a 'Help Desk' here. Link in my signature line.
