The U.S. version is feature and hardware limited due to the 2016 deeming date. Right down to the Micro USB connector on some boards. I'd always suggest the INT, created without restrictions. YES, not very detailed but they are here from the birth of escribe in mid 2015. RIGHT HERE IN THE VERY SAME area you posted. Naming might seem cryptic, but the 1st pinned post has software and changes, the 2nd pinned post is the discussion post. With the attention span of many and AI, your posts in here will generate more AI slop.
Temperature control with NiFe30 coil on Paramour DNA 80C mod
Wayneo replied to Sorin9898's topic in DNA 80 Color
None of those items exist as they are not required. Instead, you have Watts and Replay. Replay offers a repeatable puff and dry hit protection like TC did without the complexity. After you’ve taken a puff look down at the centre bottom area of your screen, and if you see the word ready, you can then enable Replay. Replay does require TC capable material for best success. -
There are many DNA60C themes under their Downloads tab. A good designer at a minimum would have written what features are included, some might just show the word. You don't need to upload to your mod initially. Download, and just start Theme Designer, open that file you saved, or even just double click on the saved file. You can use any color theme you wish to learn, beware their features might not be available for your board type.
I think you need at least a 'New atomizer' screen. The mod, depending on what was written into a profile and the variance detected now writes that new value into your profile or leaves the old. So I'd say 3 screens. Stealth mode has 3 options (Like where I showed above 'Atomizer Power' Above) there are 2 for stealth. The options for stealth level are 'Off', '1', '2', or '3'. Off = Stealth mode is disabled 1 = Dim 2 = Very dim 3 = Screen turns off You'll need to play around to see which you prefer. Years ago in my old tired mind, I think I used a toggle with the 1st field, on something totally unrelated like a battery icon.
These changes and most of what you wish for are found in/under Theme -> Theme Designer -> Screens. Although 'watts' are in 3 places, you should only need to change the Main Page. Easiest way IMHO is to Highlight the field, click options, choose 1 decimal and then the step size to 1 or 2 for point 1 or point 2. Enable 'don't show units'. Click OK. Or if you want to see the W you can go change the font size. You can actually setup conditions such as watts > 10 increment by .5, watts > 20 step by 1, etc. but that's more complicated (and has been done in other themes) I'll address your other wish list items later, or 'search works' better with 'all' better than 'any' (click the magnifying glass.
There is NO option for a background image.
Under the escribe 'safety' tab are options to lower or even turn off 'fill pod' warnings. There are ranges of resistance for what the coil Ω's displays as. Yours is now in the 1.2Ω range by 2 hundredths of an ohm. Your 'wrong ohms' issue is harder to explain but could be due to your coil raising its resistance due to getting crusty/carmelized from use and/or dirty contacts. Those factors or others, have raised the resistance to be in the 1.2Ω coil range My simple explanation - https://forum.evolvapor.com/topic/76108-oxva-xlim-pro-2-dna-resistance-issues/#findComment-945868 More detailed explanation (same post) - https://forum.evolvapor.com/topic/76108-oxva-xlim-pro-2-dna-resistance-issues/#findComment-945933
The evolv default theme shows ohms on 4 different 'pages' (that you said showed your '1.x'). Here are 4 screenshots with each 'ohm' field highlighted/selected. Show me the same from your theme or just the missing '1' pages. Thanks.
So it's a display issue. Either you're trying to show too many digits after the decimal or the field is just too small,.
Too many changes going on by you. A shifting landscape where you just guessing as you make changes arbitrarily. So for your last 2 posts, although I posted a screenshot of the exact 7 checkboxes I wanted you to enable, YOU did not. Then you throw in a whole new coil with a new resistance without mentioing if it was dry burned and glowing evenly from the center out. Out of sequence puffs and mismatched profiles do not help either. The intricacies of getting TC to work properly are relatively simple, with barely any manipulation required. I cannot help you any longer. You are free to open a Help Desk ticket, link in my signature line. I will help you with 'Replay' which is much simpler to use and provides dry burn protection like TC, if you wish.
Do you notice DW ONLY has 7 checkboxes enabled. Your DM screenshots should be the same. None of your lower ones, It clutters the display. Your last Profile settings showed Profile 3, yet it also shows you using Profile 8. No need for a new board for testing. ALSO: Describe your coil specs and contact or spaced wraps
Big difference between 'reads' and 'displays', but let's check. Using your theme, post a photo of the screen showing ohms, and then in escribe, start device monitor and post a screenshot.
You could open a Help Desk ticket about this and they will guide you. Link in my signature line.
That's pretty horrendous battery sag you're showing. That's close to 1 volt sag.I do not think it 's a board issue at all, and is a mod build issue. It could be all of those mods or just yours. I would return it to place of purchase for a refund or replacement.
Can you post a full Device Monitor screenshot, enable volts, power and power set only, while taking a few puffs. At the 'battery weak' puff, hover over the volts (black line) and click at the lowest point.
Limited yes, and there are no TC options. Both are supported by serial commands, and both are also visible on the mod.
- 1 reply
- 1
I'd suggest you use Replay with 'watts' set as the material type for best results. You could download the SS904 material file (I believe) from steam-engine, but even then your coil probably has Nickel legs which throws off the proper values of the material file.
- 1 reply
- 1
So depending on how much wire was left on the board and room in the enclosure, you can either solder to the board again or use a connector to match the battery connections. XT30 is a 30Amp connector and the XT60 is 60Amps, but there are many.
Not really. Let's say 2 cells are at 4.1V (fully charged) and the 3rd (unbalanced) cell only reaches 3.5V. So a .6V difference. When that weak cell reaches 3V you'll get a weak battery or check battery warning. Effectively won't fire, while in escribe cells 1 and 2 would still show ~3.6V. I would say yes. You're showing me a four position JST-XH connector. I dont how the outer red and black were connected.
Really, all 4 cells showed 0 Volts in Device Monitor? As 1 or more cells become unbalanced the battery % reflects that and the mod will work less once that weak cell hits the board hard cutoff.
Difficult to explain, but you NOT being a TC user THERE IS NOTHING REALLY TO WORRY ABOUT. The board is sold with default parameters programmed. Quality mfgr's will do their best to guesstimate the Thermal values to use. Some put these boards in a 3D printed housing, some metal, and others wood. Different materials heat and cool differently. The 2 boards have different default values programmed. Under 'mod' -> 'thermal' you can see the above differences. You can 'hover over' field names for official explanations. Unfortunately YOU cannot run 'thermals' on either 60 because of that external/standalone USB charger. There's no communication path.
That's in 'Theme Designer'. If you go to a field, on the RHS near the bottom you'll see the update while firing box to enable.
