  1. You should really open a Help Desk ticket. Even point them back to this post. They will guide you. Link in my signature line. That 1 second boost really drops your voltage down. When that black line hits 2.75V (default) you'll get a warning.
  2. If this is truly just a black and white DNA60, it's the first one I'm hearing about. If it's a color 60 let me know. For the power drops, are they intermittent? What does the voltage drop look like when taking a puff on a full battery? Does it happen with all batteries? Do a Device Monitor screenshot like shown, with only those same checkboxes enabled. Hover your mouse over the lowest point of the black voltage line, click mouse to draw the black vertical line, and post here. Answers. There are no vendor specific limitations on any board. There are no settings for Auto-lock or click counts on a black and white DNA60 Does the fact that it locks mid-puff confirm a mechanical failure of the fire button (ghost clicking)? <- No idea
  3. NO themes per se. All changes in escribe -> Display:Color schemes. From there you can share a .ecigcolor file.
  4. Sounds like positive pin is not making a good connection on the mod. Check if the mod 510 still can depress and spring back. Or even try an atty with a longer connection. 9 times out of 10 you should be answering yes, that's what your mod reads right now. 9 times out of 10 you should not do this. It does nothing in power/watts mode. Every time you push that fire button your mod reads the current resistance.
  5. Does this happen with other attys or only this one?
  6. Yes, except the SS operates at a much higher frequency than Kanthal for a cleaner taste and all the extra fancy features.
  7. Good SS pods. Can confirm. What did your mod display them as? Probably what you bought. More info here specific to what you ask. https://forum.evolvapor.com/topic/76108-oxva-xlim-pro-2-dna-resistance-issues/#findComment-945933
  8. NOT a DNA device.
  9. It's been reported before. Read the post below, I think it includes a test firmware https://forum.evolvapor.com/topic/76162-possible-bug-or-board-problem-and-firmware
  10. Options ➔ User Interface ➔ Manufacturer, first then try again
  11. Start escribe, go to 'About'. Click the logo 7 times and it will flash/disappear. Those fields will now be unlocked. I do NOT suggest you start editing those fields, and you're on your own.
  12. Components have changed in the past based on availability or suppliers, same for screens. In escribe 'General' ->'get information' will give more details. I have NO opinion on its authenticity.
  13. I suggest you open a Help Desk ticket and they will verify for you. Link Here
  14. You'd need to open a Help Desk ticket for that. The 60C screens are delicate, especially that 'fusible link' near the board end. I've been openly saying this since 2024 to one of your guys here https://forum.evolvapor.com/topic/72310-dna60c-screens/#comment-941274
  15. I don't believe you can change it either way, any longer. Also 4.35V is fully charged not overcharged.
  16. Do you actually use Replay? enabled after seeing the ready? During testing I vaped a N80 coil and wick perfectly dry with no burn. 30+ puffs from when the rda was dry. I got nic sick thinking it would be much fewer puffs. It never burned/singed the cotton.
  17. Sure. Replay works best with a proper TC material like SS. You are quite lucky to get a 'replay ready' with N70. You must use enough watts or long puff for the mod to be able to capture the puff. I will assume the 4th that does not show 'replay ready' is your kanthal coil with the flattest/lowest change in resistance.
  18. Or did you charge via your PC? Was there a pod in your mod when you created the screenshot? There is newer firmware, can you update to that and do one last screenshot (low chance, and you should contact OXVA for repair or replacement) Thank you for that screenshot.
  19. The charger you used, what does it say on the label for voltage and current? With your mod plugged in, Start escribe -> Device Monitor and then do a full screenshot. Post the image here.
  20. That link was nearly 10 years old and not for color mods, but you see many parts are still relevant. I think djlsbvapes - and jai Haze made videos about escribe and features except session mode which is newer.
  21. OK, so you see from the 'save' it's what you want to do, and the 'cancel' is when you want to stop. At that point (after you clicked save) if you clicked 'connect and download' you'd see 'Puff Saved, Playing' has been enabled by YOUR MOD. Replay ONLY captures what your last puff tasted/heated. Nothing to do with duration at all. For wattage and duration you want 'session mode' Yup. At most you can uncheck that, otherwise there is no 'puff' for it to recreate. For the third time 'Your mod toggles that 'playing' on and off. Not a faulty chip, there are YT videos on how to use. What training video did you find? There never was one (by evolv) for any color mod. On YT all 75C/100C/250C's operate the same. Or search here for more info on session mode.
  22. What problem(s) are you actually having? NO YOU DO NOT Go read my last sentence again
  23. Exactly what it says. That field ONLY ever shows when the field above it 'enable replay' is checked/enabled above it, and YOU have enabled Replay for that profile. Your mod toggles that 'playing' on and off.
  24. Under the 'safety' tab in escribe, you can adjust that 'fill pod' sensitivity or even turn it off. BUT IT IS WORKING (high watts, low airflow) as you've found out, caused by the wicking not able to keep up.
  25. OK, so you got A bad pod.
