If it were me, I'd hit up the mod maker for a replacement. The height measurement of the 4 on shapeways are all different (smallest measurement and less than 1cm) and you could end up futzing around.
I think that means I was correct? All these falling out of TSD issues have you checked your atty connection is stable with Atomizer Analyzer. Using SS clapton when cold I'll usually get ~0.003 fluctuation.
My colour mods are all at SP38. I’m a simple man so I usually use a minimal basic theme like the default with a few tweaks and have not seen the error again. You could try the default, and follow what I did to both create and resolve the issue before making wholesale changes to yours.
Guys, so much going on in this 1 post and I can't 'quote' multiple posts that span pages, so I'll just ramble. Yes, we (moderators) suffer from the same timeout where we need to log back in numerous times. Sometimes even during a long reply while we gather our thoughts. I also only see the translate option while using Chrome (Mac user) I have seen the error press up, and after making a single change on a theme and after a simple change I've never seen it again. Details here and YMMV. http://bit.ly/31Dg7cg
Hold your horses! That pinhole is for an LED, like while it’s charging. There is no External reset on the mod. There are a couple reboot options or a restore, but only available within escribe
No worries, I misread your initial post. If you can't even connect BUT you see a reset option, that is only on a theme and relating to puffs on the mod.
First off I'd suggest you do a File - Save of your old mod setup/settings in case of problems. Failing any better answers, I'd suggest you open a 'Help Desk' ticket. Link in my sig.
No, there is nothing similar to the way non-color boards were. BUT, there IS an option within Theme Designer under Miscellaneous->Debug to have the screen always ON. i have not tried it, but I have seen it on the odd Theme. I just look at the LED for the status when fully charged.
Quick answer, no. The 75 board is much larger and won't fit horizontally or vertically. You can download the datasheets which list the dimensions of each at www.evolvapor.com
@ Mr.Bottomfeeder IMHO there's only 1 person ( @James ) that could answer your question, and you might get a quicker answer by opening a Help Desk ticket . Let us all know the answer. Link in my sig.
That can be answered by opening a Help Desk ticket. Link in my sig.
Could the connection just be loose? I've squeezed the cable connector tight with my bare fingers on a cable or two. Failing that, you could open a Help Desk ticket. Link in my sig.
Try using a different USB cable or port and see if that helps.
I'll take a stab at this. You can trust the built-in protections of both the color and non color boards you mention. Regardless of the batteries you use or the % you see. That % is really meant for the battery icon display. The boards have hard coded minimum input voltage values.
That board button is actually composed of 3 pieces. You can carefully remove the top metal section by the raised section in each side, and below remove the rubber and silver disc, then clean them all and re-assemble. Or, failing that, open a Help Desk ticket for their guidance. Link in my sig.
@MonotremataYou are correct there was a SP20! That version was never posted publicly as a Beta or with any notes. It just magically appeared as a direct download link. BUT I COULD BE WRONG AGAIN. Do you remember ANY notes/comments about it, or what did it fix for you? Edit: Why don't you PM a copy of it to him
In my old, tired mind it was never posted here, and not for Mac. It was Windows only, in a very non standard way published by LostVape to upgrade the Orion Go to the Plus version.
What is the coil material? I see both coils actually dropping resistance when firing by a couple mΩ's. And you can use a sniping tool for decent printscreen.
Need how-to for screen replacement on drone 250c
Wayneo replied to Bombastinator's topic in DNA 250 Color
T5 torx screws 😀 -
DNA 60 menu shows volts instead of watts
Wayneo replied to Anderk's topic in EScribe, Software and Firmware
Glad you got it sorted. Enjoy your mod. -
Mac user here. Overall, yes it works. The more detail the better and a printscreen or two later. How old is the iMac? What version OS? What version number of escribe? How is it plugged into the iMac? IF you want, you can skim through this thread, dedicated to Mac escribe. https://forum.evolvapor.com/topic/68861-mac-escribe-suite-beta-thread/
Sure, we try to help. If we say something you don't understand, let us know. Pretty much all non colour DNAs (keystrokes) are the same. Same for escribe, Atomizer Analyzer and Device Monitor. DJLSB has some good youtube videos and the search function here works. Let us know how you get on. One last thing, you can post images here as opposed to imgur. -
I'd say your mod has dropped out of TC mode and is just firing in straight watts. If you look at your 3rd pic it shows what you've selected for those 3 parameters. 'Device Monitor' will prove that if you tick cold ohms and live ohms. It's usually a connection issue somewhere. You can use Atomizer Analyzer to see how stable the coil is, and it should fluctuate a few milliohms at best. Either at the 510 connection (where yours is manual), or one of your coil legs is loose, or even hotspots. I'd check those in that order. Just wondering why you locked the ohms? That should be a solid setup. Finally (IMHO and some might disagree) unless you set your preheat wattage HIGHER than your set watts, you're not getting any benefit out of that option Welcome -
https://forum.evolvapor.com/topic/68221-can-anyone-help-me-out-with-this-theme/?do=findComment&comment=913493
