blueridgedog Posted August 25, 2015 Report Posted August 25, 2015 I am going to test this week to see if the pulse disconnect in virtual box happens with various cables. I have not ruled out a USB 3 to USB n translation issue/period.
laadam Posted August 25, 2015 Report Posted August 25, 2015 I was using ISB 2.0 and a high quality cable when I noticed the erratic connection in Virtualbox. More frequent connection errors were noticed utilizing USB 3.0
blueridgedog Posted August 26, 2015 Report Posted August 26, 2015 I just ran a test with the current VirtualBox and a good cable. I get intermittent "phase out" that you can see in device monitor. This is worse if the host is emulating USB3 and is least at USB1.1. I suspect this impacted the last firmware update.
James Posted September 4, 2015 Report Posted September 4, 2015 Posted the 2015-09-03 EScribe. Minor bug fixes only.
James Posted September 4, 2015 Report Posted September 4, 2015 blueridgedog: Parallels on Mac does glitch on me occasionally, randomly pausing for a second every once in a while. The EScribe version I just posted has longer timeouts, so it shouldn't be fazed by that.
laadam Posted September 6, 2015 Report Posted September 6, 2015 James said:Posted the 2015-09-03 EScribe. Minor bug fixes only.Has anyone run into issues downloading 2015-09-03 EScribe?I get version 2015-08-21 EScribe using the link
antyac2108 Posted September 6, 2015 Report Posted September 6, 2015 Yes I had the same issue and there was no firmware update
Nach Posted September 6, 2015 Report Posted September 6, 2015 [QUOTE=James]*** 2015-09-03 EScribe ***This is a minor bug fix release for EScribe. It features:(1) a fix for Device Monitor flashing on some computers with Windows XP,(2) longer timeouts, for fewer error messages when using VirtualBox/Parallels on a Mac, and(3) ECigStats 1.1, which adds support for localization (Chinese and Norwegian, initially)[/QUOTE]Guys, just read the notes as you click the download links!
laadam Posted September 9, 2015 Report Posted September 9, 2015 [QUOTE=Nach][QUOTE=James]*** 2015-09-03 EScribe ***This is a minor bug fix release for EScribe. It features:(1) a fix for Device Monitor flashing on some computers with Windows XP,(2) longer timeouts, for fewer error messages when using VirtualBox/Parallels on a Mac, and(3) ECigStats 1.1, which adds support for localization (Chinese and Norwegian, initially)[/QUOTE]Guys, just read the notes as you click the download links![/QUOTE]What are referring to?
antyac2108 Posted September 9, 2015 Report Posted September 9, 2015 It was just an escribe update not a firmware update
Vape_Like_A_Boss Posted September 9, 2015 Report Posted September 9, 2015 [QUOTE=laadam][QUOTE=Nach][QUOTE=James]*** 2015-09-03 EScribe ***This is a minor bug fix release for EScribe. It features:(1) a fix for Device Monitor flashing on some computers with Windows XP,(2) longer timeouts, for fewer error messages when using VirtualBox/Parallels on a Mac, and(3) ECigStats 1.1, which adds support for localization (Chinese and Norwegian, initially)[/QUOTE]Guys, just read the notes as you click the download links![/QUOTE]What are referring to?[/QUOTE]Just to clarify, it was only the EScribe PC Software (PC Interface) that was updated, the firmware on the mod didn't change at all. Just the windows software version changed and was updated.
laadam Posted September 9, 2015 Report Posted September 9, 2015 That makes sense. I did not notice a version change when you click on "Help" and "About EScribe"I may have just recalled incorrectly...What version do you show? I'm at 1.0.33
tomdunahoo@gmail.com Posted September 9, 2015 Report Posted September 9, 2015 James I am curious on this new feature of hide ohms or show ohms in the new coil screen. It is asking me for x and y values. Where do I get these values. Also can we get the bug fixed for profiles. The issue I have is on TC with crown tank I got profile set and it is PERFECT. The issue I have is I also use this DNA200 for cloud comps. When I switch to my Alliance profile which is at 200watts and then go back to Crown profile the TC loses its punch and is flat or burned. Ohms are still locked at .17 temp is still at 475 and watts at 45.I have to hook up to escribe open my saved profile and reload device. Then it is back to perfect vape in TC again. It would be nice if the profiles worked. I have tried selecting yes new coil and I have tried no old coil. Neither one get me back to my sweet spot settings. It seems to go back to the profile but doesn't have that preheat punch in it.
VapingBad Posted September 9, 2015 Report Posted September 9, 2015 I think the x&y are for the position of the values on your custom screen.Could you problem be to do with the mod getting hot during comps and remaining warm for a long time afer, maybe running case analyser would help, just a guess.
Vape_Like_A_Boss Posted September 9, 2015 Report Posted September 9, 2015 VapingBad said:I think the x&y are for the position of the values on your custom screen.Could you problem be to do with the mod getting hot during comps and remaining warm for a long time afer, maybe running case analyser would help, just a guess.Just to add on this thought, maybe to get some more data TomDunahoo could temporarily set the screen fields to show board temperature and room temperature, both when it's working normal from room temp and also in the conditions it's getting whacky, when the mods been run really hard and temps are higher.I was thinking if you could check those temps during both conditions, it might show a correlation with temperature, and maybe be a touch helpful in determining if case analyzer makes any difference if it happens often enough to note the before/after results and see a pattern.
blueridgedog Posted September 9, 2015 Report Posted September 9, 2015 James: Timeout is better. I still get a hickup periodically, but I leave it to you to decide if it is now long enough. I will a handful of flashes to see if it gets in the way. The best way to see them is in atomizer analyzer.
laadam Posted September 9, 2015 Report Posted September 9, 2015 The one error I got during an update did create an issue. The mod was stuck in upload but when I was able to get it going, I noticed it reset everything to factory default. Uploaded all settings again and working fine
promod2000avenger Posted September 9, 2015 Report Posted September 9, 2015 Thank you so much James for the Escribe update.It has fixed the black flashing screen in live view with parallel and XP sp3 Walt
Smoove0214 Posted September 10, 2015 Report Posted September 10, 2015 laadam said:That makes sense. I did not notice a version change when you click on "Help" and "About EScribe"I may have just recalled incorrectly...What version do you show? I'm at 1.0.33 Mine shows up as 1.0.32
Vape_Like_A_Boss Posted September 11, 2015 Report Posted September 11, 2015 laadam said:That makes sense. I did not notice a version change when you click on "Help" and "About EScribe"I may have just recalled incorrectly...What version do you show? I'm at 1.0.33I show 1.0.33 after installing that escribe only update, so I'm thinking you're probably good to go.
Mangiman Posted September 20, 2015 Report Posted September 20, 2015 Any body knows how to copy the settings from one dna chip to another ?
alistairs Posted September 23, 2015 Report Posted September 23, 2015 Edit: see updated reply in the "More than 1 DNA" thread:https://forum.evolvapor.com/topic/68146-topic/?do=findComment&comment=912975
Spirometry Posted October 4, 2015 Report Posted October 4, 2015 It would be nice if you would list version numbers and firmware version on the front page.for example,*** 2015-09-03 EScribe v 1.0.33***https://www.dimensionengineering.com/software/UpdateES_2015-09-03.exe (10MB online installer)https://www.dimensionengineering.com/software/SetupES_2015-09-03.exe (51MB standalone installer) *** 2015-08-21 EScribe v 1.0.??****** 2015-08-21.sw-update***https://www.dimensionengineering.com/software/SetupES_2015-08-21.exe
mrminimal Posted October 16, 2015 Report Posted October 16, 2015 Hi, has someone else got problems with autoupdating escribe to version 1.0.34 and the dna 200 firmware 2015/09/30? Also I cant finde those updates on evolvs homepage either. I am sure they exist because in Mr. Phil Busardo tutorial they exist.
