gorman Posted November 16, 2017 Report Posted November 16, 2017 23 hours ago, James said: I've just posted up EScribe Suite 2.0 SP9. It contains minor fixes for DNA 250, and for DNA 60 international customers only, it supports Boost. Feedback is welcome. @Austin Green: DNA 60 is more niche so we are testing it there first. Thanks James. Looking forward for DNA75 Boost support. I understand testing it on a less popular platform. 1
Austin Green Posted November 16, 2017 Report Posted November 16, 2017 On 15/11/2017 at 9:55 PM, James said: I've just posted up EScribe Suite 2.0 SP9. It contains minor fixes for DNA 250, and for DNA 60 international customers only, it supports Boost. Feedback is welcome. @Austin Green: DNA 60 is more niche so we are testing it there first. Would you have a rough ETA as to when it will be implemented on the DNA250 also please James ?
chrismel Posted November 21, 2017 Report Posted November 21, 2017 Hey all, how can i find the last Escribe version? thanks
chrismel Posted November 21, 2017 Report Posted November 21, 2017 21 minutes ago, dwcraig1 είπε: It will be here Thank you
chrismel Posted November 21, 2017 Report Posted November 21, 2017 (edited) i have a big problem with my drone i cant find in the mode section the Lithium Ion 18650 lebel ...my Escribe have only Lithium Polymer and LiFePo4.... i have some bugs in the lcd Edited November 21, 2017 by chrismel
chrismel Posted November 21, 2017 Report Posted November 21, 2017 when I hit the fire , the screen hangs
retird Posted November 21, 2017 Report Posted November 21, 2017 I don't understand what you mean by "screen hangs"
r3fini Posted November 22, 2017 Report Posted November 22, 2017 (edited) nvm. Edited November 22, 2017 by r3fini Poste on the wrong post silly :s
Doyle4 Posted November 23, 2017 Report Posted November 23, 2017 Is boost mode only supported for 60 and 75/C for now? fingers crossed comes across to 200/250 thanks for your work! 1
steefmobiel5 Posted November 28, 2017 Report Posted November 28, 2017 (edited) Hi chrismel, That definitly looks like your screencable is lodged under the firebutton. Replacing the screen and tidiying up the cable will probably solve your problem. I had the same issue with my smy sdna 75. It was quickly resolved with a new screen from evolv for $18 shipped, which arrived here(the netherlands) in 4 days from the us after ordering. Replacing the screen took maybe 15 min. Including the adding of padding between button and cable, so the sreencable doesnt get cinched. Greetz stephan Ps. Open up the mod first to check the cable is actually inserted on the board correctly before ordering. Edited November 28, 2017 by steefmobiel5 1
Wayneo Posted November 28, 2017 Report Posted November 28, 2017 A quicker, easier way would be; Go to "About" Escribe. Click the juice droplet (middle of the logo) 7 times till it flashes. Fire up "Device Monitor" Way down on the left you'll see "Screen disconnects". That value should be zero 0. Welcome Stephan The rubberized casing on my Black SDNA75 is still mint.
steefmobiel5 Posted November 28, 2017 Report Posted November 28, 2017 Thank you wayneo for pointing out that tip. Completely forgot about that one. Btw mine isnt mint anymore after dropping it a couple of times at work(11m drop and hitting every rail in between that and the ground), but still going working flawlessly.
truckman Posted December 1, 2017 Report Posted December 1, 2017 The boost works very well, but it has no time. I believe that if added ''preheat time limit'' will be perfect.
akiraone Posted December 8, 2017 Report Posted December 8, 2017 (edited) Hi Guys, Im the new happy owner of Therion 75C, today I just pluged it to the computer, downloaded escribe v.2.0sp8. The software asked me do I want update firmware to version 27 (25 pre-installed on MOD). I have one question about battery, because in the tab Mod>Battery the default option is Lithium Ion 18650 (cell soft cutoff at 2.75), is it correct ? Or should I change it to Lithium Polymer ? Also the battery are parallel in this mod, is there any option that I could see thru software what is the status of each of them ? And also, boost in wattage mode, what is it doing by 1=1W, what kind of ramp-up is it? Edited December 8, 2017 by akiraone
giz_60 Posted December 8, 2017 Report Posted December 8, 2017 27 minutes ago, akiraone said: Hi Guys, I have one question about battery, because in the tab Mod>Battery the default option is Lithium Ion 18650 (cell soft cutoff at 2.75), is it correct Yes 28 minutes ago, akiraone said: should I change it to Lithium Polymer No 29 minutes ago, akiraone said: Also the battery are parallel in this mod, is there any option that I could see thru software what is the status of each of them ? No, in a parallel configuration the board sees them as one cell 2
nulled06 Posted December 13, 2017 Report Posted December 13, 2017 Hello guys, i dont understand. Did dna 250 support boost for vw and how i can turn it on?
giz_60 Posted December 13, 2017 Report Posted December 13, 2017 4 minutes ago, nulled06 said: Hello guys, i dont understand. Did dna 250 support boost for vw and how i can turn it on? No 1
nulled06 Posted December 13, 2017 Report Posted December 13, 2017 1 минуту назад, giz_60 сказал: No thx. Can anybody know ETA for this feature?
giz_60 Posted December 13, 2017 Report Posted December 13, 2017 IIRC, it is being tested on the DNA 60 & will be implemented on the 2xx boards soon...Stay tuned!! 2
nulled06 Posted December 16, 2017 Report Posted December 16, 2017 Hi @James! Did evolv have any ETA for boost feature in VW mode on DNA 250? Im really need this =) Forum trick with new material good, but not usable if i use porn coil with 2 different metals. 1
iAlexander Posted December 20, 2017 Report Posted December 20, 2017 What's wrong with ecigstats web service?
protovapor Posted December 31, 2017 Report Posted December 31, 2017 (edited) Got an older dna250 board that refuses to skip the production charging test, and also refuses to pull more than .7a from the computer's USB port, so it never passes. Original programming date sept 2016, while my other 2017 boards skip the charging test fine. Also as part of testing I put in SP9, which causes dna250s to bump to 1.100+v bandgap and fail production. Reverts to 1.02ish when i revert to SP5. Edited December 31, 2017 by protovapor
