HolmanGT Posted February 18, 2016 Report Share Posted February 18, 2016 Use this one[RECOMMENDED]*** 2015-10-21 EScribe 1.0.35.2 ***The latest is marked [Test] unless you really want to play around I would stay away from that one until the programmer changes it to "Recommended" Link to comment Share on other sites More sharing options...
retird Posted February 18, 2016 Report Share Posted February 18, 2016 Yes the auto update works but only when Evolv places an update release as such. I guess what you are getting at is that Evolv hasn't formally released the recommended or the test update to the auto update process yet. Link to comment Share on other sites More sharing options...
Guest Posted February 18, 2016 Report Share Posted February 18, 2016 retird said:Yes the auto update works but only when Evolv places an update release as such. I guess what you are getting at is that Evolv hasn't formally released the recommended or the test update to the auto update process yet. it works great I installed first on a new board created a problem my self by not being patient as it up loaded new drivers. that took me a couple hours to work out .then installed on my friends when he stopped by to get some new cotton yesterday just let it do its deal I like the way I can name the mod now .lot easier to change settings. Now if James would add a chime to go off and message at set time to remind me to plug the DNA in to the charger at night Link to comment Share on other sites More sharing options...
ahpaa Posted February 19, 2016 Report Share Posted February 19, 2016 Does anybody know what the Screen message "OFF" means?I'm running a hybrid coil of single 0.4mm SUS304 core claptoned with Ni80 38awg on an aromamizer dual coil.Mod settings on a VT200 are Temperature dominant with sus304 tcr profileWhen I fire my coils the main digits (usually showing current temp with the new firmware) shows "OFF" Link to comment Share on other sites More sharing options...
VapingBad Posted February 19, 2016 Report Share Posted February 19, 2016 ahpaa said:Does anybody know what the Screen message "OFF" means?I'm running a hybrid coil of single 0.4mm SUS304 core claptoned with Ni80 38awg on an aromamizer dual coil.Mod settings on a VT200 are Temperature dominant with sus304 tcr profileWhen I fire my coils the main digits (usually showing current temp with the new firmware) shows "OFF"Temp limiting is turned off, this is done on the mod by adjusting the temp past 600 F. Link to comment Share on other sites More sharing options...
ahpaa Posted February 19, 2016 Report Share Posted February 19, 2016 Hi Vapingbad,Ahh ok ok. which means my coil is kicking the temp control out? I've set the temp to 210 Deg C or about 430F or so. Link to comment Share on other sites More sharing options...
Bobby Posted February 19, 2016 Report Share Posted February 19, 2016 ahpaa said:Hi Vapingbad,Ahh ok ok. which means my coil is kicking the temp control out? I've set the temp to 210 Deg C or about 430F or so.I think that your coils are heating up too slow. I think the initial raise in temperature should be more than 150 degree F in the first second. If this is not seen bij the DNA it will change over to powermode.You could try to increase the preheat/punch to see if this improves the situation. If not, post your profile settings and people might have other suggestions. Link to comment Share on other sites More sharing options...
Dampmaskin Posted February 19, 2016 Report Share Posted February 19, 2016 Thanks for the update. I'm eager to try it out. FYI, ATM there are six open pull requests for translations at https://github.com/Evolvapor/EScribeTranslations/pullsI hope you can find the time to have a look at them before the next version comes out. Link to comment Share on other sites More sharing options...
ahpaa Posted February 19, 2016 Report Share Posted February 19, 2016 Bobby said:[QUOTE=ahpaa]Hi Vapingbad,Ahh ok ok. which means my coil is kicking the temp control out? I've set the temp to 210 Deg C or about 430F or so.I think that your coils are heating up too slow. I think the initial raise in temperature should be more than 150 degree F in the first second. If this is not seen bij the DNA it will change over to powermode.You could try to increase the preheat/punch to see if this improves the situation. If not, post your profile settings and people might have other suggestions.[/QUOTE]Hi Bobby,Thing is that it was almost instantly when i hit the fire button, it came up with "OFF" on the screen.Cleaned up the coil by dry firing, new wick and its working again. Same settings. Will take note and bump up the preheat.My original preheat was 80W @ 6 hardness for 3 secs.My dual coils come up to 0.27ohms and i'm firing at 50w normal. Link to comment Share on other sites More sharing options...
Wingsfan0310 Posted February 19, 2016 Report Share Posted February 19, 2016 It was probably the coil, not the preheat if you had it at 80 watts. I'm using SS430 with the preheat off and I never get kicked out of TC. A loose post screw would probably do it too. I change my coils approximately once a week (I have 200 feet of SS430, figured I might as well use it lol)Edit SS is/can be finicky because for the most part it's TCR is on the edge of what mods can deal with. That's why I'm using 430 because of it's relatively high TCR (.00138) for SS. Link to comment Share on other sites More sharing options...
Bobby Posted February 19, 2016 Report Share Posted February 19, 2016 Aphaa was using a dual clapton coil (more mass = slow heat up), that's why I suspected the slow ramp up but seeing how he corrected the problem, you are probably right and it was a poor post connection. Link to comment Share on other sites More sharing options...
Wingsfan0310 Posted February 19, 2016 Report Share Posted February 19, 2016 Bobby said:Aphaa was using a dual clapton coil (more mass = slow heat up), that's why I suspected the slow ramp up but seeing how he corrected the problem, you are probably right and it was a poor post connection.I wasn't trying to be argumentative Bobby. I did however miss the dual Claptons part. I had seen him post he changed coils and got it working so I figured it was either a bad coil or connection. I'm using simple dual 7 wrap 2mm (it's a touch springy so I think they may be closer to 2.5mm) coils with 28ga SS430 so I don't think for me ramp up will ever be a problem lol .Cheers,Steve Link to comment Share on other sites More sharing options...
Wayneo Posted February 19, 2016 Report Share Posted February 19, 2016 @wingsfan you said "430 because of it's relatively high TCR (.00138) for SS". So as an example from Steam engine, just using the TCR for 304SS, I should enter .00102? in the materials tabThanks in advance Link to comment Share on other sites More sharing options...
Wingsfan0310 Posted February 19, 2016 Report Share Posted February 19, 2016 Wayneo said:@wingsfan you said "430 because of it's relatively high TCR (.00138) for SS". So as an example from Steam engine, just using the TCR for 304SS, I should enter .00102? in the materials tabThanks in advanceYou can also download the TFR table from Steam Engine as a CSV file to your PC located here. Click on the drop-down box and select the material you are interested in. Then click on the DNA200 tab and finally the download TFR table as CSV tab (pay attention to where you are saving it to on your PC).Then go to your material tab and click on the + button to add a new material. Then you would click on the un-named material you just added, then click the next button to the right of the + tab which is the open material button. Then navigate to where it (the CSV file) was saved on your PC and click on the CSV file and open. That's the way to add a curve instead of a single TCR number. Hope that wasn't confusing. That's the way I do it. It names it for you from the CSV file.Cheers,SteveThere is probably an easier way to do it but that's the way I always downloaded my CSV files before the update so it's what I'm use to. If anyone knows an easier way, I'm sure they will let you know. Link to comment Share on other sites More sharing options...
Wayneo Posted February 19, 2016 Report Share Posted February 19, 2016 I believe from Daniel's (DJLSBVapes) testing with his thermocouple found that just going by the TCR value, the actual temperature was closer than using the fancy curve generated. That's why I want to use his method.Can anyone comment if the setting of .00102 (for 304SS from steam engine) is the proper format? Link to comment Share on other sites More sharing options...
Wingsfan0310 Posted February 19, 2016 Report Share Posted February 19, 2016 Wayneo said:I believe from Daniel's (DJLSBVapes) testing with his thermocouple found that just going by the TCR value, the actual temperature was closer than using the fancy curve generated. That's why I want to use his method.Can anyone comment if the setting of .00102 (for 304SS from steam engine) is the proper format?Sorry about that. I figured the curve would be more accurate than 1 set number. Here's a TCR chart listing most wire types we would use. I've tried 430 both ways and didn't really notice a difference, but I usually set my temperature to 420F. Link to comment Share on other sites More sharing options...
Wayneo Posted February 19, 2016 Report Share Posted February 19, 2016 Perfect. Thanks alot. Link to comment Share on other sites More sharing options...
moto69xxx2000 Posted February 20, 2016 Report Share Posted February 20, 2016 I recently sent my VS DNA200 to have the board replaced and when i got it back the firmware was totally different. Before i had 8 profile settings and now it has a KANTHAL, Ni200, TITANIUM, SS316 with a sweet spot setting as well. I also have Wismec REULEAUX that still has the old version with the 8 different profiles. When i connect my Wismec to escribe i can change evrything like normal but i tried to connect the new chip escribe says it doesnt detect device. What am i doing wrong? I tried downloading new firmware and nothing fixes me being able to connect my Vapor Shark DNA200 to escribe. Please Help. Link to comment Share on other sites More sharing options...
dwcraig1 Posted February 20, 2016 Report Share Posted February 20, 2016 When I installed the "test" EScribe Windows had to locate another (extra) driver. Link to comment Share on other sites More sharing options...
Wingsfan0310 Posted February 20, 2016 Report Share Posted February 20, 2016 It should have 8 profile settings. All of the firmware's I have tried have 8 including the newest beta 2016-02-12. Where did you send it for board replacement? Are you positive it has a DNA200 board in it? Have you tried more than 1 USB cable? Lastly, have you contacted the place you sent it to for the board replacement with your issue? I know it's a lot of questions, but what your describing I've never heard before. More details might better help someone figure out what's happening.Cheers,Steve Link to comment Share on other sites More sharing options...
Wingsfan0310 Posted February 20, 2016 Report Share Posted February 20, 2016 dwcraig1 said:When I installed the "test" EScribe Windows had to locate another (extra) driver.When I installed the newest Escibe/firmware on Windows 10 I got a warning about invalid or corrupt signature iirc but at the same time Norton scanned it saying it was fine. I just clicked on install anyway and it went smoothly. I didn't need to install new drivers or anything. What version of Windows are you running?Cheers,Steve Link to comment Share on other sites More sharing options...
dwcraig1 Posted February 20, 2016 Report Share Posted February 20, 2016 7 & 10 64, oh and XP 32I'm not sure which one(s) asked to find a driver Link to comment Share on other sites More sharing options...
retird Posted February 20, 2016 Report Share Posted February 20, 2016 I had the exact same results as Wingsfan installing the newest EScribe/firmware on Win10 64 bit. Norton said the same thing too. Did not need another driver. Link to comment Share on other sites More sharing options...
dwcraig1 Posted February 20, 2016 Report Share Posted February 20, 2016 I reverted back to the earlier firmware and uninstalled the test EScribe and reinstalled the recommended EScribe. What I got upon installation was the "Found new hardware wizard" (XP) which I canceled this time, It installed and worked just fine. It was for USB serial port btw. Link to comment Share on other sites More sharing options...
James Posted February 20, 2016 Report Share Posted February 20, 2016 moto, you should be able to control the VaporShark DNA with the newest EScribe version in Early Firmware. Please let me know if it does not work. Link to comment Share on other sites More sharing options...
