dwcraig1
Everything posted by dwcraig1
  1. What I see is the coil material isn't changing resistance when heated. It might be Kanthal or Nichrome and that is not TC capable. Sometimes due to poor connections between the board and coil there is enough resistance change to trigger the Save Puff, but this is pretty much by accident and not by design. Try using Stainless Steel mesh/wire.
  2. The coil material must be capable of being used in temperature mode, Kanthal and Nichrome will not change resistance when heated. Check in Escribes Device Monitor to see if resistance changes from cold to hot.
  3. Check here first.
  4. What you have there is the limit of the cells. The output is never going to be higher than the battery voltage (under load). You have a couple of choices, build closer to .2 ohms. The other choice would be using 30 amp CDC cells like Samsung 20S. these would get you up around 135 watts on a charged set of 30 amp cells. ( You are really pushing those HG2s and 30Qs too hard)
  5. So you were able to get it back using the "Backup" feature in EScribe after all?
  6. Firmware version is in the right lower corner of Device Monitor in EScribe
  7. I would think as more of them are sold you should be able to have someone upload the theme.
  8. Very few manufacturers set up their mods properly to where you can reset defaults and end up with how it came out of the box. I'm not sure how Dovpo set up the Odin. Generally when "Reset Defaults" is used the board get set to Evolv's default settings not the mod makers. One way to get it back to original setting would be to connect it to EScribe on the/a computer that it had been connected to when the desired settings were still on the mod. Connect to EScribe and go to the "Help" and choose "backups", scroll to the one needed, they list the board type and date then upload settings.
  9. https://forum.evolvapor.com/applications/core/interface/file/attachment.php?id=235932 (US) https://forum.evolvapor.com/applications/core/interface/file/attachment.php?id=235933 (INT) Some folks have reported good results with this firmware, I'm thinking more is going on other tan a fw problem but just my thoughts. Paste the fw in your fw folder during the fw update process . Or Appdata/Roaming/Evolv/EScribe Suite/Firmware/DNA Color 250
  10. dwcraig1
    BB 60
    I used an old cartomizer that I soldered over the positive/negative of it's 510, I also had to shorten it some. IMO battery analyzer would be a waste of time, It will only make the battery bar more accurate. The mod will still work exactly the same. I got a reading of 0.009 ohm and 0.008 ohm on the two SXK BB's that I have.
  11. You might try looking at Puff Info in ECigstats
  12. I would try another theme and see if it make a difference and go from there. Here is the stock Drone theme. Of coarse be sure to be using TC wire. Stock Drone Theme.ecigtheme
  13. My guess would be the wiring from the battery sled has come undone. Not at all sure but that's what I think.
  14. First off your video doesn't play. Use EScribe Device monitor and see what the voltage for the cells is listed as and post them here.
  15. 0.003
  16. First thing to due is to make sure that the cable that you are using isn't a charge only cable. The early (old) versions of EScribe aren't going to work either, make sure to use a current version.
  17. Not much difference for most users.
  18. With your mod connected to EScribe and Device Monitor tab selected the firmware version is in the lower right side corner. The latest recommended version for 250C is 1.1 SP35 ( EScribe 2.0 SP17) and early release version is 1.1 SP38 (EScribe 2.0 SP19). https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/ Most folks opt for the international version over the US version. EScribe will tell you when an update is available but early releases are not included.
  19. Who did you make multiple ticket with? Evolv warranties the board for 1 year.
  20. The 510 on the Drone is spring loaded and has a fairly stiff spring. This simple test will tell you if the 510 is electrically sound: Open EScribe with mod connected to computer with data cable with no atomizer and select Atomizer Analyzer at the bottom of the General page. Atomizer Analyzer should show "?" Next use a small screw driver inserted into the 510 to short the positive pin to the ground of the 510 (threads). If you get a reading of Ohms instead of a question mark then the 510 is connected to the board. If no change then the 510 is not properly connected to the board or the board it faulty.
  21. Other than checking if the 510 positive pin is stuck at the bottom of the 510's body there is not much than can be done without disassembling it. Ask for help here: https://helpdesk.evolvapor.com/index.php?a=add&category=1 You will get a response, probably won't be till Monday as they don't operate on Saturdays or Sundays.
  22. Ask here also: https://helpdesk.evolvapor.com/?a=add
