Everything posted by retird
Lost Vape Therion DNA75 Latest firmware update help
retird replied to fibercarbon's topic in EScribe, Software and Firmware
Enjoy and folks around here try to help should you have further questions... -
The latest fw version for the DNA75 is 2016-06-05. Open Device Monitor with device connected and look in the bottom right corner for the fw version... If your device is new I suspect it has the latest fw already installed. -
Good starting place to download....scroll down in this link.. https://www.evolvapor.com/products/dna75 -
Or, if you use different atty's with different wattage, temp settings, etc for only watts or 316l wires you could set up profiles (up to 8) for each wattage, temp setting, etc. of each wire.
510 99.9 pure copper Mod resistance tools
retird replied to vegabob's topic in Connectors, Components, and Accessories
6-5-2016 is the latest firmware version for the DNA75. Check the lower right hand corner of Device Monitor and the Switchbox should show that version. Vapor Shark did an excellent job programming the Switchbox with the production utility. -
off board buttons on the dna200 or 250?
retird replied to kaylin1997's topic in Connectors, Components, and Accessories
Lots of info here on the 250 board... https://downloads.evolvapor.com/dna250.pdf -
Lots of things can cause what you call spikes. Posting screenshots of Device Monitor data can help those of us who want to help you. Continuing to talk about it without letting us see screenshot data will probably not bring about the answers you seek.
If I am not mistaken they are still working on that one.... Still ? here..... -
So by saying "randomly doing a power reset" do you mean the device resets and the Evolv DNA75 startup screen comes on again like the board is loosing all power from the battery? Possible loose connections, poor grounding, issue with the wiring. Best guess from the limited info you say. A short video showing what you are seeing may be helpful.
Lost Vape Triade DNA 250
retird replied to Jerry05478's topic in Manuals, Instructions, and Tutorials
If you didn't save the .ecig file from your device maybe somebody here has an .ecig file for you... Maybe contact your vendor.... -
Guess I'm one of the "morons" too....
retird replied to David Campbell's topic in EScribe, Software and Firmware
Yep, same here and others say the same.... Evolv will get it fixed.... it may have to do with Evolv recently moving to a CDN for their downloads, since the traffic was getting kind of high. At least that's my guess.... A content delivery network (CDN) is a system of distributed servers (network) that deliver webpages and other Web content to a user based on the geographic locations of the user, the origin of the webpage and a content delivery server. -
Will DNA200 mods EVER have preheat function for wattage mode?
retird replied to joeong's topic in DNA 200 and 250
Evolv came with Temperature Protection as a means to vape in a safer manner. Temperature Protection allows vapers to adjust and control to safer limits thus reducing the amount and number of bad things that come with high temp, burning cotton and juice, and etc. As Evolv states in their data sheets: Temperature Protection The DNA 200 directly measures and limits the temperature of the heating coil during operation. By preventing the coil from becoming too hot regardless of fluid, wicking or airflow, a variety of undesirable situations can be prevented. For example, appropriate temperature settings will prevent the wicking material from charring, which compromises taste and introduces unintended chemicals into the vapor. Appropriate temperature settings will also reduce the breakdown of flavoring and base liquid components, which could impact taste or safety. -
Has the film of the organic compound (black part of the crystal screen) changed shape since you posted the picture 9 hours ago? Can you post a more close up picture and picture of your board?
Wiring: http://allaboute-cigarettes.proboards.com/thread/59815/wismec-reuleaux-dna200-strip Similar device (rx200): https://www.youtube.com/watch?v=DasAxwurbJk
Don't believe they offer that type of service. There are a lot of "modders" around that may be able to help ya out....it will take more work than just changing the board...
Go to the Screen Tab in EScribe. There are your choices (drop down boxes with choices) to configure what is displayed on screen... Try them out and learn what they do...
Any difference if you increase the power setting?
] So your device works properly otherwise? What is the Pack voltage and individual cells voltages. Maybe you could post a screenshot of the Device Monitor data.... Does it charge properly?
So, have you replied back to them (feature inside the ticket whereby you can reply back) and have you given them more info...may help.....
New and/or Early releases are usually posted here... /topic/66731-topic/?do=findComment&comment=900119
Heck, when Evolv gets back to you on the latest ticket submitted why not package them up together and ship them. You can print another RMA form and have it filled out and ready. Evolv assigns a Tracking ID and a Ticket Number for each ticket. You also need to comment on each RMA form what the issue is with that device. It would help to also list the serial number of the dna board on the RMA form so they will know which device goes with which RMA. Wondering.... at what wattage do you dry burn your coils and for how long?
@jamtwo, I've seen, many times, where Evolv has replaced boards that were damaged by the end user during installation, or even out of warranty, even though it was not covered by the warranty. I understand your frustration but can't agree with your evaluation of Evolv as a company and their product(s). Can you post pictures of your build showing only the board (front and back) and the wiring as we may be able to do a bit of long distance visual troubleshooting and possibly assist you. I do see cold solder joints and a missing ground pad in your post 1 picture. A picture of the battery and the attached connector (s) would be helpful also. Lots of folks here that really try to help .......
@whiteowl84 .... They should get back with you and @so619Cal. I filed a ticket on Wednesday and received a reply yesterday. Don't know what all the daughter board does. Some devices with daughter boards have or control auxiliary switches, and other things. Can't say for sure, when it's not firing, that it's the board. What do you mean "it won't fire"? When you press the fire button I thought you said you were getting messages like ohm's too low or check atomizer. The atty won't fire but those messages mean something was detected and until that is corrected it's not going to fire. That can be many things not board related. At any rate Evolv will get-er-done.... Best company I've ever dealt with when it comes to Customer Service. (short rank, not aimed at you guys) I really have to bite my tongue when someone tries to bash Evolv on other forums and facebook site and they immediately, without even doing any troubleshooting, say the board is bad. (short rant concluded) Evolv's datasheets has a list of the error messages and an explanation of what that error may mean. Please keep us updated on your progress guys....
It seems your vendor is willing to work with you so you might just send both devices back for repair or replacement. It sounds like your issues are not related to the Evolv circuit board. If you feel the issues are with Evolv's board you can fill out a ticket with Evolv explaining the problems and they will reply back to you. https://helpdesk.evolvapor.com/index.php?a=add I also saw that this vendor states that HCigar warranty's are handled by Evolv BUT only Evolv can verify that for certain. You might ask them if you file a ticket. http://vapenw.com/hcigar-vt133-evolv-dna200 You could also contact HCigar at: http://www.hcigar.com/index.php/Info/view/cid/406.html As a side note: It is always advisable to have a back-up device should your main squeeze quit working. Good luck....
