  1. No idea, I don't work here/there. BUT you can always open a Help Desk ticket and officially inquire. Link in my signature line.
  2. Your duplicate posts have been merged and moved. The navigation key combinations are exactly the same as on the 75 you have/had. Let's see if I hit all your issues. Using escribe 'Device Monitor', bottom line you can see what profile you're in. Using escribe you can choose ' temperature dominant' for the big temp, in any profile you want. Using escribe When the mod shows 'OFF', make sure you have a TC type material(SS in your case) for that profile chosen Upload settings to mod.
  3. Here will always work better than there.
  4. So much for reading your own post on reddit where I already answered all these questions, 10 hours ago. Reddit answer: Material(wire) profiles don't care about build specs, or wraps. Only the wire itself. And even on a color board you can't 'type in the TCR on the go' SO 1 Material(wire) profiles don't care about build specs, or wraps. Only the wire itself. 2 Rename a Profile Kangar, put in those preheat, power, and material type 3 Material(wire) profiles don't care about build specs, or wraps. Only the wire itself.
  5. That was your original question. I read that as 'Can I use a DNA60 small screen with a DNA75' That answer is no because there is no firmware option/support for the 75 with a small screen (like there is with 60 board).
    Welcome, You can use that 'About This File' area to comment about the features of this theme you created, or even give credit to the original author
  6. Contact the modder and ask, but for now, refer to this post for workarounds.
  7. Found the cheat sheet for non color mods. The only thing missing is the boost punch feature (like pre-heat for any wire type not used in a TC mode) which is on the latest dna60 firmware. https://bit.ly/323Wigr
  8. There is an evolv default SS316 material type already on there that should work fine. You can assign it to any of the 8 profile names
  9. OK. So no idea why it's not recognized as every board type I own is recognized up to macos 10.15.X The 60 like all others come with 8 profiles and ~4 material types like your 75. Luckily, there are key(button) combinations to move between them, but you won't be able to add new material or change the wording. To switch between profiles on the device, put the DNA60 into Power Locked mode by pressing and holding both the up and down buttons for two seconds. From power locked mode, to cycle between profiles, double click the Up or Down button. To select the displayed profile, press the fire button. To switch between material type within a profile on the device, put the DNA60 into 5x (fire button) Locked mode. Then by pressing and holding fire, up and down the material name will show up. Up or down to cycle through them, then fire button to select the chosen one. It's much easier than it sounds. While you're trying that, I'll hunt for a credit size graphic for you.
  10. Yes escribe works with the 60 on a Mac. Are you sure it's an Evolv board? I thought the 'Rus' meant Russian, and I thought they were a different board
  11. Here's me injecting one note. When you're all done figuring out what batteries you're gonna use, use the 'watt hour calculator'. Yours currently shows 9Wh, and that's usually about right for 1 new high quality battery
  12. What firmware are you now running? I hope you read the release notes for what each subsequent release changed/addressed. So if you're all fine now, great, enjoy your mod. Do not read any further If you're still having issues, post a printscreen of 'Profile 1', and what material (wire) are those coils. From the word 'delay' are you saying from when you push the fire button nothing at all happens on the mod? because your puffs are barely 2 seconds long?
  13. Can you describe your coil AND post a printscreen from escribe of the profile you're using I'm understanding that every time after sitting for a few minutes, only the first puff seems delayed, but subsequent puffs are fine. If so, have you used Replay?
    Original 'Theme' Designers at least deserve some credit for their work. The wallpaper might be original, but in both the 'about' screen and the credits, the info shows this is the work of @formula 1 Oops!
  14. After changing pretty much anything mod related in escribe, always 'Upload settings to device'
  15. Nah. Escribe came out with the 200 in 2015. Then in 2016, the 75, 250 and 60. All working with escribe
  16. @Madzz Inquiring minds need an update. What kind of mod is that white Delrin? Did you try the test theme? If it didn't work did you open an official Help Desk ticket for that firmware fix? Hope you had a great Father's Day
  17. Well, my bad. Sorry.
  18. I don't even know how you can ever see the firing button, but whatever. Your firing starts blue for like ½ a second then that red for like ½ a second. Repeats the red then back to blue. Put together it would appear as 1 solid second of each. If the 'normal' isn't blank, my question is: After making these changes did you 'upload settings to mod'?
  19. @Sn00n00 The Evolv default will work fine. Having an accurate CSV file for your batteries will only make your battery gauge and % more accurate. Battery life will not change. There are two settings that affect battery charge life and they are Cell Soft Cutoff and Charge Mode. Many use 2.75 volts for round cells and 4.2 volts for charge mode. This pretty much gives the most puffs from each charge. Maybe you can explain more the big NEED.
  20. There are many different ways to set up a Temp Protected vape. Your (those) settings will work after just enabling/clicking on that box above 'Temperature' that says 230°C We all vape differently, so if you vape at 100 watts normally, you can adjust the temp up or down until you get the same 'heat' but with smaller clouds.
  21. That was NOT a true statement. Even if you setup your profiles as @dwcraig1 has suggested, YOU will still need to change to that profile.
  22. I'd suggest you update your version of escribe first. Link is in my signature for the latest.
