Twiq Posted March 5, 2018 Report Posted March 5, 2018 8 minutes ago, HolmanGT said: Hang in and I'm sure they will fix you up. fingers crossed i really liked the new boost feature, it made 50 watts kicks like 75++ watts with Ni80 wires, i really don't like the idea of downgrading to previous firmwares and losing this feature, well not for now 😅
HolmanGT Posted March 5, 2018 Report Posted March 5, 2018 Twiq, I know what you mean about the boost. Most of my dual coil 24 Ga builds are a real pain without boost. I have to take a couple of primer puffs so the third is the puff I wanted in the first place. 1
Twiq Posted March 5, 2018 Report Posted March 5, 2018 On 2/12/2018 at 8:51 PM, Wayneo said: @James I take it "... can be configured on-device" strictly means as a profile setting in escribe, and not changeable on mod itself. actually you can change it directly on the mod without escribe, lock your device while on any non TC profile, push and hold - and + button at the same time, you can set the boost value anytime
retird Posted March 5, 2018 Report Posted March 5, 2018 28 minutes ago, HolmanGT said: Twiq, I know what you mean about the boost. Most of my dual coil 24 Ga builds are a real pain without boost. I have to take a couple of primer puffs so the third is the puff I wanted in the first place. I think you will like the "Replay" feature in the DNA250C...... Select "Replay" of the 3rd puff and next puffs are the same while "Playing"..... There is a couple videos out where Brandon speaks about it but you probably have seen them already.... ..........https://www.youtube.com/watch?v=Jac9au_1uY8.......... .........https://www.youtube.com/watch?v=JKPb3UKXXP4...... 1
HolmanGT Posted March 5, 2018 Report Posted March 5, 2018 (edited) Retird, Thanks for the tip. That is one of the options I actually read and remembered. I have watch both videos and now I spend my time searching for the new Lost Vape Mod with the DNA 250C/400C chip-set. :-( George Edited March 5, 2018 by HolmanGT
Twiq Posted March 5, 2018 Report Posted March 5, 2018 15 minutes ago, retird said: I think you will like the "Replay" feature in the DNA250C...... Select "Replay" of the 3rd puff and next puffs are the same while "Playing"..... There is a couple videos out where Brandon speaks about it but you probably have seen them already.... ..........https://www.youtube.com/watch?v=Jac9au_1uY8.......... .........https://www.youtube.com/watch?v=JKPb3UKXXP4...... actually i haven't seen or heard any of it.. and after watching these i get a lot of WHATs.. WHAT? 250C? i haven't even heard of 166C or 200C WHAT? 400 WATTS? with some big ass coils you could definitely roast some meat with those.. what kind of batteries could deliver such power? 4S++ lipos? sh********ttttttt WHAT? REPLAY? sweet spot without needing TC wires? that is really dope.. i'd probably should stop before going more OOT.. but man, evolv is really killing the game.. when is it going to be released? i'm saving some bucks from now on 😂
HolmanGT Posted March 5, 2018 Report Posted March 5, 2018 Twiq, Watch the two videos that Retird linked to. If I try to explain it you'll be more confused than you are now. The new DNA 250C actually uses a 400 watt capable board, Brandon claims the extra head room of the 400 watts can be taken advantage of in "Replay" mode. Anyway the videos will explain what Replay is. Oh - And Lost Vape has one that is do to come out any day now. Also the DNA75C will have new software to incorporate "Replay" but not until they finish dinking with the 250C. 1
Wayneo Posted March 5, 2018 Report Posted March 5, 2018 2 hours ago, Twiq said: lock your device while on any non TC profile, push and hold - and + button at the same time, you can set the boost value anytime Yeah, figured that out about an hour after writing that. And welcome 1
Twiq Posted March 6, 2018 Report Posted March 6, 2018 11 hours ago, HolmanGT said: If you have the new 250 firmware and it is doing what you show in the screen capture I would suggest contacting Evolv's support guy and telling him your problem. As per your recommendation I've posted a bug report, hope they could identify the bug and fix it soon.. but i would love to hear @James 's comment on this really enjoy reading his posts
sealmi Posted March 7, 2018 Report Posted March 7, 2018 Please add to the firmware dna75, preheat kanthal! If dna75 is deprived with boost.
Twiq Posted March 13, 2018 Report Posted March 13, 2018 Just an update to my previous posts.. I've contacted for support and had been asked to roll back the firmware and i did, i went back from SP6 INT to SP5.1 and my device no longer suffering from power cut offs.. the downside is i lost the boost feature... dang it.. I hope they found out the problem and got them sorted out.. for now i'll upgrade again to SP6 and enjoy the boost feature and charge my device with 1A only just to be safe
Twiq Posted March 13, 2018 Report Posted March 13, 2018 Quick update Waiiiitttttt, i re-applied SP6 then issued a Hard Reboot from Diagnostic menu/button, the power cut offs automagically disappears.. i will monitor and update again if the power cut offs came back@James @Nick could this power cut offs caused by bad flash of SP? or the hard reboot is necessary after an SP flash?
Twiq Posted March 14, 2018 Report Posted March 14, 2018 Update again It is true after doing a hard reboot i've successfully charged from 70% or so to 100% without being interrupted at all.. however unfortunately this morning when i charge my mod i noticed the cut off returns, i've recorded a video of this and still trying to figure out how to convert this to gif so i can post it to the forum thread
Twiq Posted March 14, 2018 Report Posted March 14, 2018 @Nick here's the recorded cut outs, it's currently running SP6 INT. sorry for big size gif
James Posted March 14, 2018 Report Posted March 14, 2018 @Twiq, SP5.1 and SP6 should be quite similar about charge resetting. Are you sure SP5.1 cuts out less? SP5 certainly would, yes, but SP5.1 should be the same as SP6 in that regard. It is self-protective functionality, detecting quick cut-outs of charge current that can be bad for the device. If it's doing it, it doesn't hurt anything, just annoying. (To be honest, I may have it overly sensitive right now.) PCs have fairly clean USB power supplies so you are unlikely to encounter it there. Does the charge resetting happen to you on other chargers you have? What brand/model of charger is it? 1 Amp or 2 Amp? 1
Twiq Posted March 14, 2018 Report Posted March 14, 2018 (edited) 3 hours ago, James said: @Twiq, SP5.1 and SP6 should be quite similar about charge resetting. Are you sure SP5.1 cuts out less? SP5 certainly would, yes, but SP5.1 should be the same as SP6 in that regard. It is self-protective functionality, detecting quick cut-outs of charge current that can be bad for the device. If it's doing it, it doesn't hurt anything, just annoying. (To be honest, I may have it overly sensitive right now.) PCs have fairly clean USB power supplies so you are unlikely to encounter it there. Does the charge resetting happen to you on other chargers you have? What brand/model of charger is it? 1 Amp or 2 Amp? Hi James, it's 2 Amps and i use / carry around Samsung chargers.. I'm quoting myself from the support ticket between me and Nick. but I forgot to mention i also use Anker Powercore II powerbank and it's 2.0 cables here are the list of USB cables and adapters that i've tried : 2.0A> Adapters : 1. OEM charger for Samsung Galaxy A5 and A7 (2 of them, white and black), 2.0 A output 2. Samsung Travel Charger, 2.0 A output 3. Samsung OEM Charger for Samsung Galaxy S8 (the one i carry around) USB 3.0 Qualcomm Quick charge 4. Hippo dual dynamic charger (1A & 2A ports) 5. Dell Laptop USB Port (2.0 and 3.0) 2.0 Cables : 1. Vaporshark included 2.0 usb cable (data transfer capable) 2. Macson short 2.0 usb data cable (data transfer capable) 3. Samsung 2.0 usb cables (3x paired with the adapters, 2 of them are data transfer capable, 1 is not) 4. Hippo 2 Meter fast charging cable (no data transfer support) i can confirm that no cut off happened while on SP 5.1, and very positively sure it didn't happen before upgrading to SP6 and after downgrade from SP6.. because i have a habit whenever i charge my mod, the screen is always facing my direction, as soon as the battery reaches 100% and current goes less than 0.20A then i disconnect the chargers. i do this almost everytime, except when i go to bed, i charge it with anker powerbank which is intellegently turns itself off after the mod no longer accepts charges.. edit: have you seen my graph on page 49? it has down spikes which i'm not sure have happened before, i rarely use escribe for anything except for theme changes 😉 Edited March 14, 2018 by Twiq 1
Twiq Posted March 16, 2018 Report Posted March 16, 2018 UPDATE @James @Nick I have found a workaround to prevent power cut offs from happening on my Vaporshark DNA250 with SP6 INT. The trick is NOT charging the device directly after a vaping session, but you must let the device to go idle then turns off by itself, after the device is off then plug the chargers, the boot screen will show and will charge normally. Note : i don't know a couple of quick draw counts as a session or not and i haven't tried, but usually my session eats 10%-15% of battery.. i've been doing this 3 times since last night and it's doing great for me.. I'll keep monitoring this however it's pretty annoying to wait for the device to go off by itself then you can charge
Twiq Posted March 19, 2018 Report Posted March 19, 2018 UPDATE the workaround i shared always works this way.. i have no charging issue since last friday.. But i'm curious, are there other DNA 250 users that have tried the SP6 and doesn't have this problem?
YetanotherSteve Posted March 24, 2018 Report Posted March 24, 2018 Hey there. After trying to figure out why my HCigar DNA 75D (with a 75 C chip) did not change the clock ahead one hour during DST, I tried updating EScribe in case that was the problem. I am having trouble finding the best way to update EScribe to the latest version. I cannot find a 'check for updates' selection anywhere in EScribe. I see that I can choose to 'Apply Service Pack' and am given the option to select from a device folder (such as DNA 75 Color, which is the device I am using) but I want to update EScribe, and the folder naming seems to be updates to the devices themselves. On Evolv's DNA 75 Color main page (https://www.evolvapor.com/products/dna75color) I can download EScribe Suite US Edition for Windows, but the site does not show a version or date for the file. How do I know it is newer that the one I already have? (The file name I downloaded today (2018-03-24) is the same as the one I downloaded on a few months ago on 2017-12-27, and both files are named SetupEScribe2_US.exe ) I am using Windows 7 Pro x64, EScribe Version 2.0 SP5.2. "Automatically Check for Service Packs" is checked, and "Internet Sync" is enabled. Nothing pops up or displays when I select or deselecting those options. How do I know that my EScribe software is current? I see references in the forums to version 5.1, 5.2, 6.0... Shouldn't there be a simple 'Check for EScribe Updates' button and a pop up to say you have the latest version, as well as the latest version available shown on the EScribe download page? Am I missing something? Thanks in advance for your help.
Wayneo Posted March 24, 2018 Report Posted March 24, 2018 @YetanotherSteve Hotay, there are 3 major classification types for escribe in the locked post here, called 'Early Firmware and EScribe Suite'. This contains software, and sometimes firmware for SOME board types. RECOMMENDED SERVICE PACK <- Pushed out by escribe to all users (auto updater) EARLY SERVICE PACK <- For early adopters. Like post Beta testing, but not fully vetted by the masses. OTHER SERVICE PACKS <- Older versions of the above, moved here for posterity Within each of those groupings, there are 2 more groupings. US version <- FDA compliant International <- Non FDA compliant, Where NEW features can be introduced AND Finally OS type. Windoze, MacOS, and Linux. Now, just for shits and giggles, I'll bring it all home. Your version of escribe is found under 'About escribe' Your firmware (mod) version can be seen down in the bottom right hand corner of 'Device Monitor'. Those folders you mention only contain prior FIRMWARE versions. 1
YetanotherSteve Posted March 25, 2018 Report Posted March 25, 2018 @Wayneo So... how do I know if my EScribe software is up to date? I don't want to 'assume' it is. ALSO... (wik) Should my DNA 75C device have had it's clock 'spring forward' if the computer it's connected to has, and if it shows as being an hour ahead in the theme preview panel before I update the device? Thanks again for the replies in advance.
pfonseca Posted April 20, 2018 Report Posted April 20, 2018 I found out long ago that the "Automatically Check for Service Packs" does not work. As an example I just bought a new 250C and it didn't appear in the list like when I bought all my 75C. The Latest version is available here: https://www.evolvapor.com/products/dna250color. And the new SP27 was updated to all my devices. Truly a poor service by Evolv!
maximumsport Posted April 26, 2018 Report Posted April 26, 2018 On 4/20/2018 at 5:46 PM, pfonseca said: I found out long ago that the "Automatically Check for Service Packs" does not work. As an example I just bought a new 250C and it didn't appear in the list like when I bought all my 75C. The Latest version is available here: https://www.evolvapor.com/products/dna250color. And the new SP27 was updated to all my devices. Truly a poor service by Evolv! You said SP27? is SP33 the newest one?
pfonseca Posted April 26, 2018 Report Posted April 26, 2018 I downloaded the International version of eScibe last Friday and that was the SP (27) that was uploaded to all my DNA 75C devices. Don’t know if there’s any new SP?
maximumsport Posted April 26, 2018 Report Posted April 26, 2018 1 hour ago, pfonseca said: I downloaded the International version of eScibe last Friday and that was the SP (27) that was uploaded to all my DNA 75C devices. Don’t know if there’s any new SP? Ahh that’s why. 250C is on SP33.
