I've been running for a day here, TC with my wonky RDA and single twisted Ni200 coil 28ga, 13 or so turns.  Seems quite stable.  Haven't played with locked ohms yet.
Perfect update install on Windows 7 x64 and successful board flash first try.
I just successfully installed the new EScribe using the above exe and it installed perfectly. So I plugged up my DNA 200, and it notified me of the update. I chose to update the firmware, and it worked the first time, smooth as butter.
So far I can only say the escribe install and firmware flash worked perfectly, and the mod seems to be working fine for the few minutes I've been vaping on the new firmware. I'll update this after vaping it a while and let you know if I find any bugs or problems with the mod while using the new firmware.
So far, it's just like it should be though.
James, thank you so much for providing the change logs with the update links. I know it's not at all a necessity but people like me really enjoy reading them and it gives us a better idea of things to watch for during testing.
So excited having the option to use 2S and should I decide to go through with 3S builds, just flash the firmware back. Awesome addition so soon!
VapingBad said:
The fw does both 3S & 2S it is just a setting on the Mod tab next to Battery - Capacity
Even better. Thanks! Downloading on POS laptop with Win 7 now :)
Added a link above to the 7/29/2015 EScribe version. Main feature: Stealth mode doesn't keep the screen off when you're choosing a profile. Kind of hard to switch profiles otherwise. :)
My results
I downloaded escribe and it installed fine, then firmware flash to the device was flawless on first attempt. Windows 7 x 64.
I tested the profile change in stealth mode and it's working correctly, it's now easy to see the menus to know what modes you're in without leaving stealth mode, and profile switching menus came up like you intended with the change, so everything looks good here that I tested. Oh and it still vapes when I hit the fire button :)
DonnyX said:
Downloaded and installed the eScribe software and the new firmware update on windows 10 x64 no problems at all.
Good to know, thank you sir.
Just wanted to chime in. Updated from 7-9 to 7-29 firmware. All is working well!
Not sure when/what was changed, but preheat seems...different. I'm not entirely sure how, but it definitely seems more consistent with a smoother transition, if that makes any sense. I can't really give any more feedback than that without reverting and studying the device monitor, but whatever was changed was an improvement. If anything was changed at all...I suppose it could just be me.
I believe we played with the thermal control loop a little to better handle high thermal mass coils and titanium. We also made it react faster. Glad it is an improvement.
John, it is definitely an improvement. It's something that I noticed immediately and it has made my vaping experience just that much better. Thank you!
