VapingBad
  1. No, I am a beta tester I just edited the theme in a beta version of EScribe.
  2. [Escribe - Help -> 7 clicks on the Evolv logo to get into debug mode] Good luck with the RMA, I'm sure they will take good care of you.
  3. It's fine to connect directly, better performance wise, you just need to make it the last job and be careful not to short anything with the soldering iron or when fitting to the case, Capton tape can help with that.
  4. Sounds like a large voltage sag/drop in the mod, could be a poor or dirty ground connection, I don't know the Therion had the same the issue with thread lock on the 510 the Paranormal does
  5. It won't affect what it reads or the rate of discharge, just how it converts voltage to battery % for the gauge. All the performance and safety features work by real time data, the user set limits for low cut off, max currents, max temps, number of cells and battery type, max recharges (cause Li batteries to charge up to 4.1 V to double their life approx) are all respected.
  6. In Escribe goto help and click the Evolv logo 7 times (activates debug mode) then open device manager and look for a reading for screen disconnects on the left hand side, if this is much above 0 then it is most likly the screen cable was not properly routed and has got damaged by the fire button or it has come loose.
  7. The Wh in the csv id just for info and not used bu the board, it uses the setting you put in the boxes. As others have said the csv is only battery % vs voltage to try an make thee gauge more accurate, for example there's no reason not to reduce the highest voltage reading by a few tens of millivolts if it says 99% when fully charged and you want it to say 100% it will not affect softy or performance.
  8. If you mean replay you can turn it on and off on the mod, Evolv just didn't put it on their theme, here is the default 250C theme with replay as a check box so it doesn't hide temp and the ability to adjust preheat, boost and turn on replay for a profile (via atty screen), a few other minor things like no decimal places and step size of 1 for temp. vb 01 int.ecigtheme
  9. You say "reccomended csv", not sure where that came from as the stock 316 profile is what I would think of as recommended and what I use all the time for 316 & 316L and the best place to start IMO.
  10. It is the default theme from the default 250C profile, start Escribe without a device connected and save the theme. In general you need replay enabled for the profile and you may need to change Mod - Replay setting to "Allow dubious coils" (the Viable cut off was set as some kanthal coils have Ni legs which could mislead the board to see them as temp sensing).
  11. What no XT30?
  12. IIRC in theme designer - default theme, don't forget to enable replay for the profile or you wont see it.
  13. Only removed or refitted them when given a mod to fix, not fitted one from new.
  14. That goes back to before any of us were mods and is from the old forum, I don't think any of us really know what was intended. I only see a single zip file for DNA 200 3D files that I can open, but I have unpinned the thread as it is so old. These files now go on the product pages or in the Resources section.
  15. A screenshot of your profile and of device monitor would help.
  16. I just use the back of a Frosts Mora knife for slotted 510s, worked perfectly on Varitube, FlabbyDaddy and Boxer, obviously be careful the other side can also hold a decent edge.
  17. No, but I wouldn't worry if it only happened once it could have just been swapping the screen into memory.
  18. I could be the battery is out of balance, you can see the cell voltages in Escribe, sometimes this is a dirty or dry solder joing on the balance connector. Or it could just be USB Charging has been disabled in Escribe - Device Monitor - Diagnostics.
  19. Running the case thermals maybe a good idea, not essential by any means, but wood and plastic cases dissipate heat far slower than metal so can affect temp limiting refinemant.
  20. Conditions sort of swap which field is displayed or how it is displayed depending one the conditions, you can chain 8 IIRC, they take up the same screen area as the element you attach them to which is why I said sort of swap.
  21. Yes it will, there are pics in the 250C datasheet (has one more balance connection, but the principal is the same)
  22. Same as the 200/133 for the 250/167, for the 250C you would have to bridge cell 3 and 4 for 2 batteries or cell 4 for 3.
  23. Everyone loves Mamu
  24. No, you can't map the fire button as far as I know, I will go back on any screen that does not have "can fire on this screen" checked.
  25. No, it is a sign of a poor connection, I have only had it persistently once since using TC with a poor origenny 2 clone, that tank is mixed metal construction and the originals didn't have the issue. I never get it and use dual twisted Ni, a few different SS builds from single strand to dual fused stapled claptons on all the Evolv temp limiting boards without locking the resistance. I believe it is more likely to happen if you go between temp extremes like a warm building to a very cold winter climate, but that is from the early DNA 40 days so may well have been fixed.
