dwcraig1
Everything posted by dwcraig1
  1. Some images show the board with the rails removed, here is an image with rails. Pay no attention to wire colors as they are for converting a particular mod to DNA60.
  2. Graph looks good, with use Replay in profile checked you will be able to get a replication of the saved puff. Try heating the wire a little hotter perhaps. But not bright red.
  3. Not actually twisting it makes it stiffer. When I'm done twisting it I heat the length of it to a slight red. I torch all my wire prior to coiling (even Tii). You could use a Bic lighter if necessary but be sure to dry fire with low wattage to burn off the black stuff. Twisted lightly really doesn't describe it, it's twisted pretty tight. This makes the 2 strands equal / near 26 gauge with lots of area for juice contact. This photo is from a couple of years ago, I twist it a bit tighter nowadays.
  4. @RealMcCoy Could you post a snippet firing your coil in wattage mode with battery voltage also checked? In this snippet I have unchecked the "set temperature" box to avoid any confusion. This is wattage with a little boost without using Replay.
  5. The coil used in my post is two strands of 28 gauge SS 430 twisted tightly with a drill and in a Kayfun Lite Plus.
  6. It appears to me that you are trying to get your perfect puff in TC mode, it doesn't look like your getting a satisfactory puff to base Replay on. Try this, set your profile to "Watts" then set your wattage and Boost and upload settings, Keep making adjustments till you get that puff that you feel is right. Use my profile snip as your guide. Then save puff. On my snip the test puff is on the left. look at the live ohms to note duration as it's hard to see as it is flat 20 watts. Use Watt profile. use TC capable wire.
  7. Honestly I don't know, I've been looking for that setting on my VA Spade in Theme Designer and can't find it. Perhaps Wayneo knows and will answer,
  8. i have mistakenly been giving you advice for a non color board, my apologies. Wayne sent me this just now.
  9. this gets me this. With temperature dominant the large number will be temperature instead of watts.
  10. Do you have this box checked/unchecked? If so uncheck or check it depending with what you want and upload settings.
  11. Look here for resample coil resistance.
  12. Make your desired adjustments here and upload settings.
  13. It appears that you have reset the board to default values which would set it for 3 cells. Connect to eScribe and go to Mod/Battery and change from 3 cell to 2 cell and upload settings.
  14. I buy from here. You can refine your search on the left side of the page pretty well. https://hobbyking.com/en_us/batteries-chargers/batteries/lipo.html
  15. You need a new battery. The voltage is way to low to safely charge it.
  16. Version 1.0.0
    216 downloads
    I added the first two screens to default Evolv theme only
  17. This is something that I have never done till now. On the the top of forum page I choose create then file download then Theme Park. Select which DNA group. I had saved the theme to desktop using EScribe. The images are there once your post is opened.
  18. I did see the "B" but at the time didn't realize it was "Board" I think you have found the problem......or a problem. Earlier screen shots doesn't show it that hot.
  19. If your mod's resistance is 0.004 ohm and you set it to 0.002 or 0.005 it will make almost no difference to your problem.
  20. Are you setting your cold resistance again after the coil is heated? If so it will use that setting as the cold resistance and be hotter than what it reports.
  21. Try to keep it 220 C degrees or lower. If you want to use spaced coils try making the wraps closer together. I use contact coils only but many prefer spaced, your choice. Try to keep the whole coil in the air flow.
