Whew baby. For starters change that 'cell soft cutoff' value to 2.8v, upload to device, and see how that helps
My Triade DNA250 fires way too low from what i set
Wayneo replied to CuriousVaper's topic in DNA 200 and 250
I think there's a theme's thread you can browse with more than you can imagine. I'm just an old guy with none really. Straight stylized text. I have/use zero images except one for my name using wingdings font. -
Enjoy your 1st DNA, it's all good. -
Close. You set 100w on your mod, like every other mod. 1st it showed (fire button) 0. Like a car when you floor it, you don't hit top speed immediately -
Well, normal behaviour is to show the wattage you set, you hit the fire button, display goes to 0, shows an intermediary value or 2 while it's headed to your set value. Keep watching that display on the mod, does it go to 100? -
What made you think 63.4 watts only? -
You could also try Facebook, or even their phone number on their repair page
Lost Vape Therion 166 with Uwell Crown 3
Wayneo replied to Vaping Jazzman's topic in DNA 200 and 250
@pr0naLd Pretty much correct there. The 75 is 6.2V, 60 and 75C is 9V no matter the amount of batteries. The 2xx boards with 3 cells are 9v and 9.3v output voltage limits. -
@wintergreen Is that the original .ecig file straight from Lost Vape, and before you checked your own mod resistance do you remember what it was set at. Not that it relates to your issue, but it's good for us to know if they're shipping these out with just the Evolv standard. It's not available on their website yet, so I couldn't check myself. Doing your own thermals will take around 3-4 hours, but it'll just run and you don't need to watch it.
That weak battery issue was merely a warning that was fixed almost a year ago in its latest firmware 2016-06-05. That was not a 'board issue' IMHO, but more due to Battery sag, while vaping at high wattages. For a single battery 75, I personally use Sony VTC5A. For my 2 & 3 cell mods I also use those HG2's.
Can you do a File - Save as, and post a copy of your ecig file. And what did you settle at for your mod resistance value?
@retird While you were doing that, I was checking if I could just delete my comment with this new forum software, but got sidetracked.
I have an OG Cleito. I use SS successfully. They are the .4ohm coils, with black rings/gaskets on the coil. Aspire uses orange bands for their clapton coils. What coils are you using? If you're saying that sometimes these same coils work, check for a clean 510, threads, coil on properly snug.
I dont need a full "Device Monitor" screenshot from you, but noted that so the user that asked would not think it was correct. If I thought you were playing I wouldn't have responded at all. Playing referred to what looks like standard default Evolv values after resetting the mod Cnange that drop down from 3 to 2.
Hey meng, that's not a Device Monitor shot, but your battery info shows it's set for 3 cells for starters, and your Therion has only 2. Change that to 2, and double those watt hours. Me thinks you've been playing. And check your version of Escribe
That's a beautiful resistance value for any dual or single battery DNA. Any reason you wanna be at .5? You don't wanna be bouncing off that output voltage limit. The standard Evolv or Steam-engine or TCR value material profile should work fine for that wire
Can you post a full 'Device Monitor' printscreen while firing and this is occuring. Image shows what to have 'ticked' (Include cell 3) and Power, not Temperature, sorry. Include another printscreen of your 'Mod' tab, and finally, what are your battery details (make and model).
Hey Karloz - you been on vacation?
Considering the DNA75's latest firmware is from June 2016, and there's only ever been 1 update, ... not plenty and available, he must be referring to Escribe updates only. Maybe he's looking for 'Flappy Bird' a la Joyetech, or even products that don't even allow/suport updates. That 75 is a solid board if you build within its specs.
Read through the post. There are many scattered hints and tips. Remember, this is not official. This is a working Cheat. Good luck.
I need three screens to be matched in text and look
Wayneo replied to JamesVally's topic in Themes and Custom Screens
@JamesVally 'Sans' - without .... Serifs - characters with those little points on them, like say Times. Arial, and Monaco (as 2 examples of a Sans Serif) font. -
@JamesVally You could do your part by finding the font for that text. That's not artistic or magical, and you might get quicker/better results. -
Become your inner artist. Simple to use. Theme / Screen generator -
Your mod will work fine as is, without a trustable battery icon. Now I don't have one of those mods, so I don't know if there's any HCigar magic that they have done. Here's a manual way. Search for your battery type here on the forum. Download the csv and note the Wh. If that value is ~8 to 10Wh, it's more than likely a single battery file If that value is ~16 to 20Wh, it's more than likely a dual battery file If that value is ~20 to 30Wh, it's more than likely a triple battery file Find the single battery value. Double it for when it dual battery mode, triple it for 3 cell mode, Most 18650's have a complete discharged value at 2.5v. So set your cell soft cutoff value somewhere between 2.8v and 3v, wherever you feel most comfortable. Now here's how to use it when you want to go from one mode to the other Go into escribe and change to your new operating mode (2 or 3), change your battery Wh setting to match the number of cells OR Save a complete backup of a 2S mode and one of 3S mode. Load backup of new mode which will already have the 2 changes required (To me this would be a nightmare to maintain) OR Screw the battery icon, change one of the small displays to show 'Battery Pack', monitor that, and only change the number of cells. Always remembering to Upload to the device after your changes. Good luck, I'm done, I've written a book. I'm sure there are some YouTube reviews out there I won't even ask how you're going to do battery management, you know, the whole marriage thing
