Open a ticket with the 'Help Desk', give them the details. Link in my sig.
Did you actually check that the ribbon cable is pushed into the connector straight and far enough? Did you hear that definite click when you closed the connector?
new to dna mod , couple of questions please
Wayneo replied to leea12345's topic in DNA 75 Color and 100 Color
Preheat applies extra power until the heating coil is up to operating temperature to shorten the delay between pressing the fire button and generating vapor. Because preheat is temperature based, it will not overheat or burn the vapor. The Preheat settings can be adjusted from the device. That #1 is the Punch setting - Scale 1-11, which is how close to your Set Temp before ending the Preheat settings Yes Similar to Preheat for TC vaping http://www.steam-engine.org/wirewiz# DJLSB Vapes has some good YouTube tutorials on the DNA Color chip. I highly suggest you watch at least one before you start changing things Welcome -
It's good to leave the defaults set by the manufacturer until you understand what/why you're changing them. Those 'Advanced' settings allow you to (tailor/be more specific) the battery specs you actually have, for the mod. And other things. The closer you are to .2, the more watts you can use. Boost will briefly give you more watts than you have set to get the coil heat up quicker. The closer to 11, the more watts will be used. Using 'Device Monitor' you can enable/disable and view how your mod is operating. Battery in your case. DJLSB Vapes has some good YouTube tutorials (I don't regularly keep up with ANY youtuber and definitely not user comments)
Website escribe download software not working
Wayneo replied to EDMKEV's topic in EScribe, Software and Firmware
We've seen where on a Windows machine, you might need to try a different USB2 port and plugged directly into the PC. -
What are the individual cell voltages? And the USB voltage when looked at in Device Monitor? -
You're only get 2A charging while using an external block and a high quality cable. The closer the battery is to full, the charge rate will go lower. -
Sure, it should install. I do believe that has worked for me in the past. What are you trying to update, the firmware on your mod or escribe itself on your PC? -
Just tested for SP19 and NOT working either. I have sent messages to Evolv. -
Welcome @Pino74 The GO chip in your mod offers 'Replay' which has the benefits of TC such as dry hit prevention. You MUST use a TC capable material/wire such as Ni200, Ti01, SSxxx, NiFexx (or others) in order to activate 'Replay'. So yes, your NiFe48 material/wire should work. That GO board works best in the .2-.4Ω range.
Welcome @milly89 Hope you will contribute. This is a DNA focused forum on vaping nicotine with all Evolv products.
PC charging is slow at best. Don't vape while charging as it interrupts the charging for the length of time you have configured.
If it were me, I'd hit up the mod maker for a replacement. The height measurement of the 4 on shapeways are all different (smallest measurement and less than 1cm) and you could end up futzing around.
I think that means I was correct? All these falling out of TSD issues have you checked your atty connection is stable with Atomizer Analyzer. Using SS clapton when cold I'll usually get ~0.003 fluctuation.
My colour mods are all at SP38. I’m a simple man so I usually use a minimal basic theme like the default with a few tweaks and have not seen the error again. You could try the default, and follow what I did to both create and resolve the issue before making wholesale changes to yours.
Guys, so much going on in this 1 post and I can't 'quote' multiple posts that span pages, so I'll just ramble. Yes, we (moderators) suffer from the same timeout where we need to log back in numerous times. Sometimes even during a long reply while we gather our thoughts. I also only see the translate option while using Chrome (Mac user) I have seen the error press up, and after making a single change on a theme and after a simple change I've never seen it again. Details here and YMMV. http://bit.ly/31Dg7cg
Hold your horses! That pinhole is for an LED, like while it’s charging. There is no External reset on the mod. There are a couple reboot options or a restore, but only available within escribe
No worries, I misread your initial post. If you can't even connect BUT you see a reset option, that is only on a theme and relating to puffs on the mod.
First off I'd suggest you do a File - Save of your old mod setup/settings in case of problems. Failing any better answers, I'd suggest you open a 'Help Desk' ticket. Link in my sig.
No, there is nothing similar to the way non-color boards were. BUT, there IS an option within Theme Designer under Miscellaneous->Debug to have the screen always ON. i have not tried it, but I have seen it on the odd Theme. I just look at the LED for the status when fully charged.
Quick answer, no. The 75 board is much larger and won't fit horizontally or vertically. You can download the datasheets which list the dimensions of each at www.evolvapor.com
@ Mr.Bottomfeeder IMHO there's only 1 person ( @James ) that could answer your question, and you might get a quicker answer by opening a Help Desk ticket . Let us all know the answer. Link in my sig.
That can be answered by opening a Help Desk ticket. Link in my sig.
Could the connection just be loose? I've squeezed the cable connector tight with my bare fingers on a cable or two. Failing that, you could open a Help Desk ticket. Link in my sig.
Try using a different USB cable or port and see if that helps.
