  1. Oh, I hear you. You should have no fears at all with SS at 300°C. The temp required before any sort of offgassing is more than double that. We all like and tolerate different temps. Even my preferences have changed and are now ~390-490°F(200-255°C) moreso based on time of day. PG and VG can break down at higher temps BUT you should notice it And here's what the problems are If you feed these mods good information they will be accurate BUT most manufacturers do NOT set them up fully. Mod resistance left at default, Thermal characteristics left at default, and SS is an alloy. If you look at escribe - mod - thermal there are 5 different parameters that say how long it takes your mod to cool, how much it changes plugging into USB, etc. These all increase the accuracy of your mod as well as the current ambient temperature. When some of those align and you measure your coil resistance you'll have great accurate TC. According to your screenshot when yours was measured, it was ~26°C. TC values are always a pair. Your Ohms Ω, and the temp. Replay with 'watts' as your material will give you the vape you desire and dry hit protection without the temps
  2. If you're happy, then so am I. Some people choose to ride the 'temp limit' line, others ride the 'watts set' line, like you have done. And with riding the watts line you notice the coil didn't get any hotter at your 45 watts. You could let off on the fire button a bit before you stop inhaling and that'll get ejuice off the top of your coil.
  3. Yeah, OK. And how's that vaping for you? Everything looks fine. Pity you didn't "Post screenshot of full screen (link in my signature line)" like I asked which shows much more information. Although your coil didn't reach that 400°F limit, no evolv person ever said you were supposed to .... it's a limit. Is there anything you want more/less, faster/slower, colder/hotter? Hopefully that weirdness should stop. The coil gunk is due to your juice carmelizing. You can always dry burn that coil in TC. It's safe. Two last things, if you get a "is this a new coil" answer yes. And, replay alone at 45 watts, no material profile or punch might give you an even more flavorful vape.
  4. Thanks for those screenshots. Just perfect. 👍 Your coil is definitely reaching the temp limit you set. TC is working as expected, and your coil looks stable. I'd turn off all preheat settings, like 1 watt, punch at 1, and here's why. If you look at that power line(green), it's less than 1 second with your punch to hit 50 watts, and then drops to just over 20 watts. That squiggly temp line(red), is like perfectly vertical meaning it has hit that temp limit and you're missing out on flavors of a complex ejuice. By turning off all preheat settings you should get a gentler slope. You could also raise the temp limit leaving your current set watts. Try those 2 things, and give me your thoughts. You want more clouds, or it was too hot, etc. *If you look a bit lower from the top, do you see where it says "Current Profile: 5" well just a bit lower than that, you showed Profile 1, a kanthal profile so I couldn't actually see your settings. That's just a tip for the future
  5. For ME to help, use TC alone or Replay alone, and then report back with a Device Monitor screenshot. Start Device Monitor. On the left, click these checkboxes only. Power, power set, temperature, temperature set, cold ohms, live ohms. Take a puff or two, pause Device Monitor. Post screenshot of full screen (link in my signature line)
  6. Welcome @Fabian95 👋 You might be very new to TC and Replay on DNA color mods. The TCR/TFR of a material (Titanium in your case) does not care at all about any coil specs. You can check that in steam-engine yourself. While both features offer unique advantages, they serve different purposes. Temperature Control mode focuses on regulating coil temperature, while Replay mode focuses on replicating a specific vaping experience for more consistency and convenience. Both prevent dry hits. TC really protects the temperature of your coil, and is a limit you set. Replay on the other hand is focused on the flavour of your puff. Replay does NOT require any material file at all to operate/work. I do use TI01 in Replay alone with the material identified as 'watts' in that profile BUT I start in TC alone to figure out where to start my watts in Replay, and change up/down slowly. If you are using both together in a hybrid mode, weirdness can definitely occur. Are you using both together?
  7. And so what was the final outcome of this abandoned post? Where I kept making comments like these. Here, I'll show you AND Yup, there you have it.
  8. Welcome 👋 I'll start by saying you should watch a video or two about DNA mods (longer DJLSB Vapes) so you get a better understanding overall of these mods, TC setup, and lingo. I'd prefer to see a Device Monitor screenshot, please. Start Device Monitor. On the left, click these checkboxes only. Power, power set, temperature, temperature set, cold ohms, live ohms. Take a puff or two, pause Device Monitor. Post screenshot of full screen (link in my signature line) cha Edit: Slight changes, but I'll probably continue c&p from this post.
  9. That's what it said. "Charger output +"
  10. @gendengruwo look at my 1st post. 2 questions. What do you read/see for pin 11? Where's yours?
  11. escribe -> mod -> battery tab. Shuts off internal charging completely. Upload settings to mod.
  12. Do you charge your batteries internally or external, in a charger? I'm asking because you can disable internal charging, and if you did that, would that charging icon disappear. Did you have a leak and maybe there's ejuice inside? My only thought is you could dismantle your mod till you see the board and wipe down the battery chip and all the solder points you see, as well as the USB on the front with IPO.
  13. Wayneo
    DNA60 problem
    Well, if your mod still zooms the watts down with the panel removed, wipe those external buttons and solder joints down with IPO. Failing that contact the modder.
  14. Wayneo
    DNA60 problem
    Looks like the '-' (down) button is stuck. Does that mod have a USB port (access to escribe)? Does that mod use 'external to the board' buttons?
  15. @arvelo The only thing NOT working is the message showing you've reached the Temperature limit, but you certainly DID reach the limit you set with SS wire in this Ti01 thread. See that almost vertical red line that then flatlines in both of your first 2 screenshots? See your green power/watts line that then plummets? That's your mod keeping your coil at the temp you set limit
  16. If ecigstats is running in Windows, can you quit that. Then can you do this; Up under Tools - Diagnostics - Reboot device - Hard reboot. Quit escribe, unplug mod and restart. Where'd ya see that?
  17. Try this: Plug the device in & open Escribe. Ignore the connect/no compatible ... prompt. Go to Tools> Apply service pack > Reload a firmware/service pack.Unplug and retry normally.
  18. Have you tried rebooting your PC while plugging into a different port, ideally not through a hub?
  19. Not natively, but YOU could do it manually. Have you checked ecigstats in escribe?
  20. Up under Tools - Diagnostics - Reboot device - Hard reboot is what you should have done. BUT NOW -> Stolen from Jacob. Try this: Plug the device in & open Escribe. Ignore the connect/no compatible ... prompt. Go to Tools> Apply service pack > Try an older service pack. If this applies, then apply the newest service pack from the front page of Escribe. If this doesn't work, I would also try more than one USB cable. Inspect the usb port and ensure it is clean. Even if it looks clean, I would use a small piece of paper towel, isopropyl & a toothpick to carefully clean out the port.
  21. escribe -> mod -> battery tab. Shuts off internal charging completely. Upload settings to mod.
  22. What chipset in your mod?
  23. Here's the quick and dirty. Any escribe/theme designer changes to your mod -> you must do/click upload changes to mod. There are 3 wallpaper slots, or blank(which is black) you can choose for each page. It is wiser to crop/shrink your image outside of 'theme designer' Good luck
