Thank you for the earlier screenshots, it makes troubleshooting/helping much easier. I think there's a problem with how it read that .245Ω's as it's clearly a .196Ω coil, and how it read .185Ω. Did you manually put it there? Look at your 1st pic, what do the live ohms show, Look at your 2nd pic, what do the live ohms show? .196Ω and .197-.196Ω You have a .196Ω coil. The coil resistance is read by the mod. A poor connection by the trapping of the wire, or dirty connections on the mod or atty can affect the reading. BUT, no matter what you change it to or think, when you hit that fire button, the mod reads the live resistance, as it should. Your mod is normal.
- 6 replies
- ohms changing
- ohms reading to high
(and 1 more)
Tagged with:
What kind of material (wire) are you using? What atty? Why would you 'lock the ohms'?
- 6 replies
- ohms changing
(and 1 more)
Tagged with:
I hope if either of you have the raw aluminium with black inlay you've seen VC's notice. I'll send it via PM to both of you incase it's not authentic.
Sure. First start off in the Replay profile, material 'watts'. Warmth set at 1, Punch at 5. Find the ideal watts you could vape all day. If you want it to ramp quicker/slower adjust that Punch value up or down. When you get a great puff, enable replay. You'll get a much fuller puff. Try that for a couple days and let me know what you think. Like TC, start with an ambient/cold coil. No material files to worry about or room temp. EDIT: I've been told by a most respected source those 'P Coils' will ALSO Replay if under Mod->Safety you change that option to 'allow on unlikely' using the same parameters as above.
I would certainly agree with support as they have access internally with the designers and developers. My main concern was with your puff screenshot. You're asking a whole lot from that single battery board with a boost buck converter. As you can see, your power (green squiggly line) plunges after hitting that 100 watt peak, never really leveling out. So it ends up being a weak puff after that initial burst of power. Is your main reason/benefit for using TC to stop you from going over 450°F or for 'dry hit' prevention. Your current preheat parameters does nothing. If it's for specific, I can make suggestions for a better puff. If it's for dry hit prevention I can help you with trying 'Replay'.
Hi hopes, but doesn't sound like a board problem. Hopefully SV looks after it. Bill, I just looked it up, over there 😉 while complaining about my 2 POS Paranormals. It was Jan 5, 2019, my 4s Lipo running SP38 I said "I have 2 Non C LiPO's that maintain their voltages for weeks. My one 4S LiPO Color mod drains about 3% over a 24 hour period of not being used." Which was only .1V per cell. Now that we know of that long period before sleep, I still run the latest firmware so the mod doesn't re-read all working parameters like SP33 has to.
Dovpo Odin 100 Mod Firmware Update
Wayneo replied to LacocoRoco's topic in DNA 75 Color and 100 Color
His DNA75C can actually boost to 100 watts with the right battery setup. If your mod has boost (sometimes called soft, normal, hard) you can do that with yours. Part of the beauty of the DNA with escribe is that you can actually see your mod performance, and have a good one year warranty on the board. Now if he could get Stainless Steel Mesh (VandyVape) he could use Watt boost and replay, and never get a dry mesh puff. I hear they are pretty nasty. No matter what you do, enjoy your mod. -
It says right there in the product description "...............The Odin 100 is equipped with the DOVPO chipset" You'd need to measure from the center of the bottom actuator to the center of the usb and if it's about 8mm then a swap would probably work. IF you want to use Replay or temperature control then you might want a DNA. If you're just a straight watts user ... save your money. -
Welcome @LacocoRoco but if the link you posted is correct, what you have IS NOT a DNA mod. If you can find your 'bypass' mode that is NOT a feature on any DNA or 1A charging. -
Welcome Ronnie. 🖐️ None of the moderators run Linux so when you wrote 'updates menu' that's not there for Windows or Mac systems. Those 2 words stopped me (and probably others) in my tracks. New board firmware will/should only be in the International (INT) versions of the escribe suite.
So many BEST profiles after 8 years. Use the search bar ↗️
If you're talking the LED between the fire button and the screen, no. Some fancier themes will do that in different ways such as a sliding bar as the battery depletes, or a battery icon that changes color.
- 1 reply
- 2
There are pictures in this link. https://forum.evolvapor.com/topic/71319-how-to-change-a-screen-on-lostvape-paranormal/?tab=comments#comment-934609 The cover hinges at each side where the ribbon goes underneath the connector. Go to the opposite end, and lift/push the cover towards the ribbon. I think I've used a fingernail or tweezer at the edge of the cover. It will stand vertical to the board. Make sure to slide the new cable in straight and far enough. When you push that cover down, you'll hear/feel it click in.
It's that easy once you get to the front of the board. It's late, I'll write it up in the a.m for you. Or user jacobevolv has pictures if you search his content. What kind of mod?
You can get new screens at stealthvape or modmaker. Both in the UK. All DNA color screens are the same.
What version software is on your PC? Have you tried different cables? Do you know or heard of any other users of this SXK device that have used escribe with theirs?
Escribe -> safety tab.
It should still be under Manufacturer warranty. I'd return it to place of purchase or ask Mission. It does not sound like a board problem.
Think Vape Finder 250 (without c) lost Firmware
Wayneo replied to Fearomoon2's topic in DNA 200 and 250
NONE of the files posted so far are FIRMWARE files. These have ALL been theme files (logo, etc). A FIRMWARE file has a .ecig file extension. -
You could use a multimeter at the back of the jst connector to measure each cells voltage and the total pack voltage
While the retailer should be the one to address this, I'd really suggest you open a Help Desk ticket, and let Evolv guide you. Like Bill, everything looks somewhat normal with decent brand batteries. All the cell soft cutoff does is say what voltage to generate a 'Weak battery' warning, letting you know the 'check battery' will be coming soon. The polling interval for device monitor was ~4 times per second, on the mod it is always reading everything live and at a much faster rate. There are no warnings or errors on escribe Device Monitor, only your mod. You think it's heat related, BIll thinks it's the board, I think it could hardware, firmware, or an over taxed battery(even though it wasn't hot). Hence, my suggestion to contact the Help Desk (link in my signature line)
When the mod starts limiting the watts, can you feel the battery, and is it hot or anywhere on the mod hot? How long has this been happening Can you tell me the battery details. Can you tell me the firmware version on your mod. For future DM screenshots, can you do a full one (it would have shown firmware), and you only need volts, power, power set.
Yes, excellent. And turn down the watts while vaping. From your Profile 2 settings, with the DRv2 you are using everything basic. Any/every mod with no sort of boost, with fresh batteries should be almost identical at 55 watts. Every atty/RDA you need to check/prepare the coil before wicking. Low glow dry burn and check for hotspots Because it's an RDA you need to keep those wicks juiced up between puffs (5, 10, 12 puffs). I can't see it being your mod or RDA.
Easy Answer: Turn down the watts. Longer Answer: Do a FULL screenprint of your current profile in escribe, like this and answer the 3 questions below. Did you try your DRv2 on your friends mod? And how was it? What material (wire) are your coils?
