And what would that be? No DNA mod detects material type at all. YOU have to change that. If you post a full 'device monitor' screenshot, showing 'cold ohms' and 'live ohms' during a puff it would be more helpful. EDIT: Click/enable 'cold ohms' and 'live ohms' for them to show.
You'd need to contact the manufacturer, or google if anyone makes aftermarket replacements.
- 1 reply
- 1
There is a conformal coating on the board to help protect the components, but ejuice can deteriorate a connection at the solder joints/connectors. Did you meter out the connections identified by Dwcraig like he suggested.
my centaurus dna 250c does not connect to the EScribe softwar, please help
Wayneo replied to Pixelq's topic in DNA 250 Color
What type of operating system? Windows, MacOS, or Linux? Try a reboot of your PC and try to plug in to your PC directly, not using a hub.- 1 reply
- 1
That seems to be a cable or charging issue. Here's a link of others and what they did/found https://bit.ly/4cf3AiT
- 1 reply
- 1
I'd say contact your place of purchase, or the manufacturer of the external board. Good luck.
So many different things are possible. Try to plug in to your PC directly, not using a hub. Try different cables.
The 'max puff time' is in two places. First in the 'safety' tab, and the second in the 'mod' -> 'safety' tab.
Enabling every single checkbox only muddies the screenshot. At most power, power set, cold ohms, live ohms. 😃
Live ohms never greater than cold. Not gonna work in Replay. I don't have either of those RBA's and also never encountered that issue in 6 months of using the 80C, even using Ni80 and Kanthal in Replay and about 6 different RBAs. I don't think it's a board issue, more a device issue. VC should definitely be interested to know or Evolv might figure out what's wrong and inform VC. One question, did you move 'warmth' to 5 or did it come like that?
FYI, We can't see labels or filenames. And this answer should have been 'no'. The 'live ' ohms need to rise above cold. So my question is do you have any other rba's you can try? And what rba was that? Or, can you remove the boro, reboot device, put the boro back in, monitor some of your puffs and ONLY looking at live and cold ohms, do you ever see live > cold. If Yes, try to enable replay at that point.
You're blazing the trail ! It makes sense so that as you change backround patterns/colours you can just leave your icons intact and choose a complimentary colour.
Earlier, quickly, I used the replay icon and the fill and used them to overwrite my settings icon. Bottom right. I haven't created my own, but it worked for me.
For the second time. Everything you can move or change is on that 'Display' tab. There is no dedicated 'theme designer'. You can change the texts, their placement, colors, backgrounds, warnings, logos, fonts. Maybe in the future they'll enhance the chip, but with a 'Replay' only board, even I don't see anything lacking/missing. If you don't like the feature set, as a long time user, you know you can open a Help Desk ticket with your suggestions.
Can you not open the theme in the escribe 'display' tab with your mod plugged in? Everything you can move or change is on that 'Display' tab To answer your question direbtly, there is no feature lock in any theme for any board. If you give more details like type of system, someone might test it and reply.
Boro devices can be so finicky between devices and some boro/rba combinations just do not work well together, It could be flushnut, integrated drip tip, your coil having some little skarf that touches, length of rba, connection to the positive, etc. Having only 1 rba limits any sort of testing. You could search around other forums for known problems but it's way too early to consider this a board issue. Unfortunately, neither of us own that device or rba. Or, you can open an official 'Help Desk' ticket. Link below in my signature line.
Do you have any other rba's you can try? Or, check your coil connections. I don't believe it's firmware. Because your mod does not believe it's SS, so it's blasting you at the 60 watts you set. If I look back at your atomizer analyzer, your .27 ohm coil was reading like .37. How much does that value fluctuate say, over a minute when running atomizer analyzer?
Locking ohms should not help, and the crazy hot hits are because of how YOU set the parameters. When you checked on the 100, did you check with the rba all put together, but not in the boro? Turn down the power to 30 watts, start device monitor (click/enable cold ohms and live ohms) and take a puff. Post a printscreen of that here. I believe it'll be the same as you have already described except no crazy hot hits.
New Vape. Ideas for getting the most out of it?
Wayneo replied to colossalclouds's topic in DNA 250 Color
That's a helluva jump from a Vuse to a Hadron Pro! Buy some high mass inefficient coils like 2x24/32 fused claptons that will heat up very quickly with all that power on tap (especially with boost:punch), and cool down slowly carmelizing on your coils and cotton. There are some RTA's and RDA's for sure capable of high watt vaping, but they're not my style, so I can't offer any recommendations. Many customizations available with escribe Theme Designer or ready made themes available here. Colours yes, wallpapers, what's shown on each screen, yes, but no animations or games or points. The search bar works, so you could just search Pokemon as an example.- 1 reply
- 1
I'd at least move it 0.004 like Evolv sets as the starting point for all other boards. Changing or not changing it won't hurt anything. Random number 30 watts should feel closer moving an atty from the 100 to the 60.
- 1 reply
- 1
Simple answer, you'll need to find a theme you like with it shown on the main screen or put it there yourself. Here’s a great video tutorial on the board and Theme Designer. The video lingo, or escribe (hover over fields) will get you familiar with DNA words. There are many on YT. DJLSB vapes - Evolv DNA 75 C Full Review with eScribe and Theme Editor Tutorial - https://youtu.be/1dvBpTm-FQM And here’s the datasheet for the 75C with more (no datasheet for the 100C) explanations. https://downloads.evolvapor.com/dna75color.pdf
I do not understand what you are asking for, but here is the datasheet for the DNA60. There are pinouts shown on a page. https://downloads.evolvapor.com/dna60.pdf Failing that, you might want to contact the 'Help Desk', link below in my signature line.
Sharp! But show MORE colors. What am I looking at ............ 1SBS, 1 boro, 1 regular mod 18650 or 21700?
Those look really sharp @Ginger
