Periodic table. Thats Iron, Chromium, Aluminium, an alloy we/they call Kanthal. 😊
Damn @Dieseljesus that really sux. Don't the UK have laws for defective products?
@intel @Dieseljesus @EagleRock how did this end up gents? What did the mfgr say or do to resolve the issue?
Yup, after you post 1 photo and 1 screenshot 😄 in your first posting.
Start escribe with no mod plugged in. Under 'escribe' click about. Post screenshot of that. Take photo of mod, post that.
Black and white DNA60 You can't, maybe it did it automagically. Color DNA60C would be in the theme loaded.
"how to force a coil measurement?" Or just yank the battery You can see our/the troubleshooting steps here. https://forum.evolvapor.com/topic/72256-replay-dna-80c/
Sure. By default the boards by Evolv are sent to mfgr's with TFR not TCR files .... just saying. If your material (wire) supplier has provided you with either type of info you can create your own.
Sure, you can either turn up your preheat watts or punch value OR BOTH. Your SS316 material profile is fine. What changes do you imagine there?
Question about the USB-C capabilities of the DNA60C
Wayneo replied to Overkill's topic in DNA 60 Color
This has been true for years and used on the regular DNA60 boards also. Being an off-board/non integrated/add-on some mods even have no USB port at all. -
IMHO you should really let them know of any issues and the opportunity to rectify. Neither of my 60C's have a USB-C port, and I only plugged the charger board in and saw the LED. All my mods have worked with escribe for years on both the Air and old MBP. It's been a while but IIRC I was getting close to 3A charging (as advertised) on the 100C. -
I do not have a 2A charger board installed, but I do have one in hand, and when plugged into the board itself I got the big red flashing LED showing. MacBookPro (old) I can say USB-A to USB-C works fine, standard belkin cable Macbok Air - USB-C to USB-C works fine, standard Apple cable. My other USB-C devices all work straight USB-C to USB-C (80C and 100C) on the Air and apple chargers Have you reached out to TekDivision, are they using the Evolv board? -
Boost Punch is a proportional increase from your set watts, only at the beginning of your puff for 1 second. And it's only from 1-11 (longstanding bug that allows the number to go to 22). By starting Device Monitor with Power and Power set you can see the difference. Was there any particular reason you chose 215C? By using Replay with watts material type, you could easily use your 60-65 watts which will give you dry hit protection.
Sure, why not, to both. You're right there with the ability to change either or both at your will. You could just vape in the watts profile and use boost: punch and come back and say what those numbers end up at.
@franknchill dude, I've now created another pinned post on how to install a theme in this area.
Download new theme Start escribe with mod plugged in. Go to theme -> Load theme (Select theme you just downloaded) choose 'Open' (on a Mac) Then 'Upload Settings to Device' <- Most important thing 😉 A theme also includes the following screen behavior fields Active time, Idle Time, Fade-In, and Fade-out time. <- If you don't like any of the 4, change it yourself. Under the Language Tab are short forms for messages. If you don't like them, change them BUT if you want to report an issue you need to use the long form, or the default Evolv short-forms. After you've done it a few times, there is a quicker way by just starting escribe, then 'Theme Designer' immediately.
- 2
Done. It's in the 60C themes. Let me know if you can see it fully and any issues with those bottom fields only.
Version 1.0.1
383 downloads
Slightly touched. Bottom fields moved up so you can see the whole status line at the bottom of the main screen. There are 3 different colored backgrounds you can choose from. Purple, green, or pink, all 3 with skulls. All 3 wallpapers are in each file, so if you want, you can just download 1 and mix and match colors all from 1 download -
That's what I'm seeing and it's definitely a Bogan (skulls) theme in Green. I'll take that theme, move everything up so you can see that 'status' line. And post it in the themes section (for all users) and you can download and install it from there. Hope that sounds good to you.
You said it was a logo. Was it a logo or word?
That .ecig file IS the complete setup and backup of your Stubby. I cant find any firing logo in it, just the word 'Fire' while in use.
So you do not want this answer, which would be done by doing what I asked in the first line of my reply?
