zark
Everything posted by zark
    There is an error in the numbers of active batteries. This is the best topic.
  1. yes, this is triade 250c
  2. Before installing, do not forget to save your profile
  3. Try setting this setting and see how the batteries behave. On the USB and Battery screens a lot of information
  4. My test lasted 5 hours. After the test, battery performance increased by 40%. You have battery problem or modular charging. The DNA first charges the battery to full charge, and then the discharge begins.
  5. there is a battery setting
  6. One of the most beautiful themes. It's bad that there is no field for chip messages.
  7. Save your settings in Escribe so that you can bring it back and try to install it. Attention, CRV battery for samsung 30q Triade 250c remote rus.ecig
  8. I renewed
  9. I am interested only in the opinion of Russian-speaking users. The English version is here. if you can give feedback on the quality of translation
  10. Господа, я выложил русифицированную тему здесь. Мне просто интересно, это реально никого не интересует? Или просто лень написать отзывы (лучше критику). Или просто русский не рулит? Интересно послушать, что думают другие.
  11. У меня есть тема на русском, для ДНК75 нужно убрать одну из заставок (например фото меня любимого)Тема на русском
  12. Usually in the helix menu you can manually change the resistance. If you are confident in the resistance of the spiral, then put the value that suits you. During thermal control, the resistance should be locked, it is desirable to lock the resistance in any mode.
    I would like separate screens of parameters of batteries and USB
  13. yes, they have the same chips
  14. zark
    please help
    This mod has a low battery capacity. choose more resistance it will reduce power
  15. In order to understand the settings you need to be patient, open any topic in the theme designer and understand the software settings of each parameter. escribe is a very simple and straightforward programming language. you will not regret the time spent
  16. DNA 250c is 300 real watts on 3 batteries, a full-color screen, the ability to edit themes yourself, reliability and stability. Vaping at a power of more than 160 watts is more stupid than a necessity. The number of available settings surpasses all competitors, but the price of these devices is too high if you can not figure it out and you will not use most of them.
  17. DNA 250c ahead of all in terms of functionality and accuracy of settings, but it is expensive. To understand whether this is necessary for you, you must gain sufficient experience on simple devices.
  18. DNA 250c -designed for professional use. For this, you first need to know if you need such complex and deep settings.
  19. in escribe, you can disable replay. In the general window, uncheck the replay option in the current profiles tab
  20. Analised-Power 40W,Resist 0,75Ohm 3S_Samsung_30Q_Battery_Curve_analisator triade 250c.csv
