Vapors Tongue
Everything posted by Vapors Tongue
  1. ok i thought it might no be right , just thought its firing and just doing the same job a coil would do but i had my doubts - thanks again
  2. could i use this to run a battery analyzers when i do a battery profile or does it have to be a coil ? its an inline voltmeter
  3. thankyou
  4. ok im well away building my own box , now i have bought i fire button to wire on to the pcb , i know which is positive and negative on the board but the fire button just has 2 pins with some tiny writing on the back and i cant make out what it says even using a magnifying glass but it does not look like positive or negative or symbols that would look like a minus or plus , does it matter which pin is the positive or negative on the fire button ?
  5. great find retird much appreciated for the info thanks guys
  6. Thanks for the info and the link
  7. so there should be no difference between a retail chip and a retail manufactured chip , same terminals and everything as obviously my box mod hasn't got the wired fire button but uses the touch pads to fire , if i get an enclosure then i would have to wire the fire button up with new actuator fire button and would escribe pick up the new battery config because i plan to use 2x21700 instead of 2x18650 , with a new battery sled . also i've seen those fire buttons which aluminate is it same terminal and wiring as a normal fire button you would wire thanks for the time
  8. Hello , is there any difference between a chip installed from a manufacturer and one you can buy retail from Evolv - could i take a chip out of a ready made box with a 250C in it and install it in a custom enclosure , the mod box i have at the moment has a full set of actuators buttons but the enclose would require me to solder a wire from fire button up to the pcb board
  9. Reviving an old thread but i suffered the same problem with error up message every time i uploaded a theme or firmware to my device but everything worked as it should even though it displayed error up message , the device in question is a vapecige VT250C i now have 2 of them one gives this error up message the other one doesn't , i read this thread and tried Wayneo's solution as my lock screen hadn't got anything assigned to it so i assigned round robin and it fixed the problem of the error up message
  10. Warmth of replay - numbered 1 to 11 like how boost interacts with non temperature controlled coils
  11. Best way to learn is understand the original default themeworks , learning what each setting does familiarize yourself with how the menu works and the settings in escribe where your profiles are located , then download another theme whichever you like and make small changes like wallpaper or the way the layout is positioned make small changes - then understand how the theme is configured looking at how each setting is configured and how to replicate it , it takes time and with time each theme you make will become better with time
  12. haven't we all put 100's of man hours in creating themes , i know lets all put a donation tab on our themes it seems the way forward lets have the rest of the community now pay us for our time - hours worked on themes - nobody forced you to join the forum or do a theme and yes by all means start a thread will be interesting
  13. sticking a paypal donation link onto your theme is in bad taste a lot of guys work hard making themes for free and to improve and help the community in general who like to create and share with others , people have free will to donate or not donate that is entirely upto them to do so , but youre doing it off the back of theming - that i do not agree with
  14. thanks just clearing things up i need to add something on my theme
  15. need some feedback on your DNA devices - so appreciate it - how many clicks to unlock your device ? the default is 5 clicks to unlock and this cannot be changed in therme or escribe - am i correct so unlocking the device will always be 5 clicks and if you change clicks on the device its to lock only it will not affect the unlock sequence of 5 clicks because this is a default and cant be changed in theme or escribe and also let me know if your using INT version of escribe or US version and what service pack if you can alter unlock sequence either in escribe or theme itself
  16. no problem , my themes and other users themes are available in the download section here https://forum.evolvapor.com/files/ alternatively if you want my themes you just need to click on my profile and look for uploaded files.
  17. you can do that if you wish but make sure you backup your original settings , i suppose its one way to get a round pre determined setting for your particular needs
  18. on my theme or where it has the profile tab on top , here in the photo its called profile one where on the device it may say watts , SS316 or replay etc - to select this tab is what you do when altering wattage , you navigate the menu by the 3 buttons or two buttons on your device and the 2 outer buttons act as up and down and the middle is to select or highlight that particular setting as you would do for changing watts and once select you use the outer button again to change values or cycle the profiles
  19. you can go into escribe and preset the profile setting wattage and pre heat and replay on all other features that the material you choose can start off with like a basic level you cant start from like setting the watts to 50 or 60 and preheat options to a required level before altering them on the device , that's as much as a preset you can do - changing materials or swapping tanks will always trigger the new coil detected which you have to set - as the photograph shows where to alter the default levels
  20. cant remember off the top of my head if the standard default theme has those options or toggles , but two of my themes i have uploaded just recently have, the green skulled vaporizer themes and chameleon download them take a look how the toggles are configured and add them to the default or a theme of your choosing through theme builder , basically when you get the hang of theme builder you can more or less add what you like so long as the options are available in the drop down menus and you just edit and add to your chosen theme as you with the picture under "DEVICE" page it has keep screen on and brightness options which in this theme is called SCREEN
  21. your drone looks different to mine its not as see through as yours at the top did you buy it new ? mine is relatively see through but has a plate underneath this bit you show
  22. no problem with my drone , i would say you've got a dodgy one , apart from the design flaws its the best squonker on the market if you can overlook the flimsy battery door and be aware of it , the fiddly replacement of the squonk bottle can be difficult to easily place in and out but i use the ceramic tweezers and takes a couple of seconds apart from that looks lovely in ultem and silver takes dual 18650 and has a DNA chip and fits a 30mm rda or rta with ease no many squonkers can boast that
  23. plus i forgot to mention you can monitor the battery to see how many amps it pulls when firing either through the theme you use or in escribe in every time you fire it
  24. i would start by buying a standalone charger and if you get the same results i would buy another pair of batteries and compare the two , it may well be the battery isnt getting enough charge or you may have a faulty set or even fake pair of batteries , if you get the exact same batteries and they charge or perform better using the stand alone charger then i would return the other batteries to the vendor you bought them off , then we can rule out one thing at a time
  25. i wouldnt advise charging the batteries via the mod for safety reason and life span ,( although plenty do) its always recommended to have a stand alone charger , i hope youre using the usb cable that came with the device and not a mobile phone charge or anything of that nature as sometimes the amperage is different to what the device needs and then there is the right type of batteries yes you can use any 18650 but better the amperage , better the mah and that results in how long the batteries last and how often and how quick they charge and buying from a trusted source theres alot of fake batteries out there - any device like the DNA 250C would require Samsung 30Q batteries with something like 30 amp discharge and 3000mah or anything equivalent to those figures
