Vapors Tongue
Everything posted by Vapors Tongue
  1. right the pre heat power is only available in temp control , so now i'm wondering what is actually changeable in replay mode , as in boost , replay warmth and punch
  2. i've done a theme and added preheat power and pre heat temp they are both set in the theme to be changed and not read only , yet the pre heat power option will only allow me to read and the preheat temp is fine , is there something im not doing ? in another setting that will allows the preheat power to become changeable
  3. just to let you know my findings , now i know replay has to have heat sensing material coils like stainless steel this also could be a mixture of coils so long as the coil is suitable for temp control , well its happened to me twice now using SS316L on a Steam Crave Aromamizer plus and a QP design Kali V2 RDA it seems to happen when the coil or deck is hot and you happen to cancel replay to change the wattage , i find replay will not engage again - i just left the mod/tank to cool down and then all of a sudden replay came back without any change to the menu or anything so i believe its something to do with heat from the deck or coil. is this a bug or something nobody had found out , granted my other tanks do not do this but the ones i mentioned have done it in the past thanks Paul
  4. nice background 👌
    Good effort in all 4 of your themes - thank you
  5. bit confused , i went on the evolv website not the forum and downloaded escribe and the version says (2SP17) yet the version i have installed at the moment its saying im on (2SP19) and i'm on the INT version and on another note its been that long since i installed escribe cant remember if theme builder is included in the escribe software or is that a separate download ? Thanks for the advice and help
  6. i know replay only works with SS coils , which obviously your using but you can lock or unlock the coil on each of the 5 profiles , i noticed i may of locked the coil in watts profile then moved to TCR profile and not done the same check the resistance then locking the coil , same happened to me thinking i had lost replay again but i switched profiles from one to the other without checking resistance in that profile and locking the coil - its worth a try to answer the punch and warmth and wattage its all personal preference , i generally have watts boost on and have 5 warmth and 5 to 7 punch - every juice you will you have in a tank will spring another combination up
  7. this is what was confusing me , i know now thankyou
  8. I usually do use SS coils , didn't know replay picked and choosed which coils it wants to work with , thanks for the answer
  9. I'm losing replay mode on a Steam Crave Atomizer plus with Ni80 dual coils 0.245 ohm on the deck , any other tank is fine , is there something about Ni80 coils that replay doesn't like , tried rebooting the device which is a 250C drone , uploaded default setting and theme and still the same outcome , even tried allow dubious coils in escribe setting still no reply function , i have 3x 250C devices and they are all the same no replay mode
  10. wondering if it would be possible to import gif animated images to themes , is it a viable option or would the board not be setup for such images and use resources
  11. again my point ,opinions are subjective along with flavour you get with whatever ratio you want to go with , there is no opinion that is right here , so i'm not going to bite from somebody who clearly thinks he knows it all , opnions are like arse holes everyone has one
  12. plus the orion is suppose to be a MTL experience so build coils accordingly to that which are typical 1 ohm to 1.8ohms which are not sub ohm and the wattage is usually around 15 to 20 watts and no higher really to get that MTL experience
  13. i wouldnt say this isnt a matter of what coils suit what ratio mix of juice but its subject of taste usually more VG would be less flavour but produces more cloud , that's why most juice is made 70 / VG - 30/PG this ratio seem to be a sweet spot for flavour and cloud production - remember the more PG you have carries the flavour better but also gives you a harsher throat hit .. what wattage or coil is nearly irrelevant but in my experience if you want a very clean sort of pure taste i would try stainless steel 316L or some say 317L the resistance is down to yourself - i normally vape between 40 to 65 watts on dual stainless steel round about 0.2 to 0.25ohm - nichrome wire is also another i use
  14. all depends what theme your using , you could add one to your theme you're using now if that's the default one or you could load a theme that you may like in the downloads section with a counter already in place
  15. Hello i was seeking permission to start a facebook group working closely with this forum and Evolv approved my request , now we just need members which i know won't happen overnight and needs working on , primarily a group for anything DNA - show off your mod , talk about DNA box mods , announcing themes and get to know one another better in real time chat - if this sounds like something you would be interested please join here - https://www.facebook.com/groups/427022221169933/ i will be looking for help to run this page , so if you know anything about building , anything about the DNA chip or a theme creator please feel free to contact me Thanks formula 1 (Paul)
  16. thanks ive sent it off , fingers crossed
  17. i have something to discuss contact me when you can
  18. wallpaper looks cool , i take it you have a vicious ant mod ?
  19. id settle for side , there's mods out there not much bigger or smaller than the dna chip with bigger displays - would make it a damn sight easier to read
  20. who is with me , i wish these screens where at least double the size would make theming better and people like me wouldnt need their glasses to look at the tiny writing in some cases , that's why i try to make things as clear as possible but when your getting down to 10 and 11 pt fonts its very hard to get a font clear enough to make out without the help of the spectacles - would make theming awesome and on another level
  21. love the design and the colour combo to this theme , welldone would this work on the dna250C
