dwcraig1
Everything posted by dwcraig1
  1. I'd say you are on the right track with it but if it's got a warranty....well you know..
  2. So I hooked my SDNA75 up to EScribe without battery and it jumps quickly back and forth from 3.78 to 4.10. Not that that's of any help I guess.
  3. The DNA75 has no fuse but does have reverse polarity protection built onto the board. Not trying to be a wise guy but are you sure the battery is being inserted with the correct polarity?
  4. dwcraig1
    DNA 250
    The DNA250 will not power the screen without battery power as it's siblings does.
  5. On the profiles that are currently using the material that you are wanting to remove from the mod.....switch those to another material then you can remove that material from the mod.
  6. It must be removed from any profiles that are using it first, just switch them to another for the moment. Be sure to upload settings for it to be changed or removed.
  7. /topic/65540-topic/ (the whole thread)
  8. I'd open another ticket and include a link to the above post.
  9. It took some digging but it appear to be able to discharge safely to 2 volts.
  10. dwcraig1
    Lost a screw
    I savage small screws from old computer devices, floppy drives and IDE laptop hard drives prove to be a good source. For sure they are metric.
  11. Most likely your batteries are not up to the task or their connections to the sled is poor. What batteries are you using?
  12. This post may be of some interest to you. /topic/66851-topic/?do=findComment&comment=901399
  13. Well I was wrong about Device Monitor showing the fire button if pressed,it shows the up/down but not fire. I tied it just now.
  14. EScribe will show if the button is working. If you decide to put in the 250 be sure to open a ticket with Evolv on the 200 board.....or open one now on what you have. https://helpdesk.evolvapor.com/index.php?a=add BTW, it's small stuff but most of the button can be disassembled/assembled (the button cover, button, disc)
  15. It's 167 watts for the 250 with 2s
  16. I've been thinking about this ^^^ for a while but have only a guess....here it be. After sleep the mod displays what the % actually is (the zero) which is derived by it's battery settings (Wh or battery CSV, or both). So if one/both are not quite correct the accuracy of end result will be off. I'm just guessing here...........
  17. Here's the figures that I would use if it were mine: 23.50 watt hours 2.90 cell soft cutoff The figure to put into the calculator would be pack voltage which would normally be 11.1 volts for 3 18650s, perhaps 10.8 volts for 3 of those VTC5a's. I subtract roughly 12% from the Mah when using 18650's instead of lipo pack
  18. They can be downloaded from here: http://dna200.de/kurven_akku/
  19. I tested out my SDMY75 a couple of weeks ago with an Aromamizer running a couple Kanthal Claptons @75 watts. I use an LG HD2 18650. There was nothing scientific about my test and I noticed nothing unusual battery wise. It appeared to operate as one would expect a single 18650 mod at 75 watts. I thought it lasted much longer than I expected. Just saying.
  20. I think it has to do with just what area of the world the person is at (non English browser perhaps). Try another browser, that worked for others.
  21. I'm going to just have to guess at this one, I'd say the display just isn't keeping up with what the board is doing. EScribe will sort that for you when you get to it. Like I said , just guessing here.
  22. Just exactly what does that screw actually do?
  23. dwcraig1
    Nife52
    I do
  24. My best advice would be to try a different web browser.
  25. It's only going to ask when it doesn't know. I'm thinking that the temp is off, that probably has a lot to do with it also.
