dwcraig1
Everything posted by dwcraig1
  1. While you can't change the battery bar you can show battery % in another field.
  2. This is a total stab in the dark but here goes......is the battery by chance set to LiFePO4 instead of Lithium Polymer?
  3. What does EScribe's Device Monitor show for cell voltages?
  4. I want to now more about the "sparks" ...components on the board firing up? Or the coil?
  5. I have two DNA40 boards here installed and working perfectly that have the fire buttons snipped off by using flush cutting pliers. Both work perfectly. I just pulled one of the buttons that I had cut off out of my desk drawer and checked it electrically, the two legs on each end of end of the switch are connected internally. When the button is pressed all legs are connected. Note that with the switch installed on the board the pads on the lower side (towards center) are battery voltage and when the button is pressed the two upper pads are supplied with battery voltage. So I checked one of the installed boards with the fire button cut off, only the one lower pad (the one on the "out" side of board) had battery voltage. The two upper pads both became "hot" when my external fire button was pressed. So I think it would work just fine but from what I see with this 40 it would be the two lower pads that might be better if bridged. Heck, on my other one I think I cut off all three buttons......Flask clone.
  6. I guess that you aren't wanting to put it back. You can just remove the cover, disc and rubber part. On the DNA40 I snipped the four "legs" with no added problems, I would think to 200 would be the same but it might be good to wait for more answers.
  7. I don't know what the hardware cell cut off on the DNA250 board is, I have asked but not got an answer yet. On the DNA200 board the hardware cut off is 2.85 volts, this is under load. The board is intended to be generally powered by a lipo pack so the cell cut off is higher than it would be for 18650's. I wouldn't be surprised if the hard cell cut off is the same on both boards. My estimate for your watt hours is 23 - 24. For a DNA200 board powered by 18650's I use 2.9 volts soft cell cut off and 3.09 with lipo. Running Battery Analyzer will give you the proper figures if you wish to do so.
  8. A couple of questions. What it does Escribe Device Monitor show for cell voltages? Is your battery set for "maximum puffs" or maximum recharges?
  9. It seems this is unknown, maybe Evolv can set us straight on this. What is the hard cell cutoff on the DNA250?
  10. Mine ask when necessary with SP3/4
  11. That is the spot on the board but how are you going to attach to the 510? You might check the 3 board mount screws to assure they are tight, they supply the chassis ground. Be extra careful not to over tighten and break them.
  12. Up top in Escribe, options/user interface/ manufacturer. Or scroll to the lower part of the page if already set to "manufacturer"
  13. Sure you can, it's exactly the same way only you lock the temp instead of power. Check it out.
  14. Sounds to me like perhaps the nut that holds the 510 body into the case may be loose. https://youtu.be/g5fwz_SsqIU @ 23:40 there is a good view of it.
  15. To change profiles start with fire button "unlocked" Press and hold the + and - buttons at the same time to "lock power" With power locked press the + or the - two times quickly and the profiles will change by pressing the + or - Perhaps re lock power when done...by pressing and holding the + and- at the same time.
  16. I'd say you are on the right track with it but if it's got a warranty....well you know..
  17. So I hooked my SDNA75 up to EScribe without battery and it jumps quickly back and forth from 3.78 to 4.10. Not that that's of any help I guess.
  18. The DNA75 has no fuse but does have reverse polarity protection built onto the board. Not trying to be a wise guy but are you sure the battery is being inserted with the correct polarity?
  19. dwcraig1
    DNA 250
    The DNA250 will not power the screen without battery power as it's siblings does.
  20. On the profiles that are currently using the material that you are wanting to remove from the mod.....switch those to another material then you can remove that material from the mod.
  21. It must be removed from any profiles that are using it first, just switch them to another for the moment. Be sure to upload settings for it to be changed or removed.
  22. /topic/65540-topic/ (the whole thread)
