Everything posted by dwcraig1
Rebel 250c squonk mod battery sag when firing
dwcraig1 replied to Chief Salty's topic in DNA 250 Color
Make the contacts hit the cell flat like not on the peak. -
More likely than not your battery sag is from the sled contacts....contact to cells is poor. What's with the extra long bare end of T1 wire? -
5 clicks is to turn off/on is the default setting, it can be changed in EScribe
Well for one you need to make sure that Replay is enabled in the profile that you are using. Also make sure your flat wire is SS and not Kanthal or Nichrome. EScribe will be most helpful in resolving this, note difference between cold ohms and live ohms when firing using Device Monitor, TC wire increases resistance while Nichrome and Kanthal remain constant. Without a resistance change when heated Replay can not work.
- 1 reply
- 1
Firmware updates, yes
Newest firmware update 250c
dwcraig1 replied to Vapingturtle's topic in EScribe, Software and Firmware
Computer only, won't work with iPhone. Windows, Mac or Linux OS. Will it turn with power cable plugged in? -
Use device monitor in Escribe with the cell checked, fire it and hoover your mouse on the low point and read voltage (red arrow). If it's below what your soft cell cut off is that's why you get the message. If you see too much voltage drop look to all the connections from the battery to the board. If the battery adjustment screw can be removed do that. Clean all threads of cap with alcohol even if they appear clean, clean the mod's positive battery contact as well as each end of the battery. Most likely there is a poor connection between the battery and the board. Check what your soft cell cut off is set to, I would set mine to 2.75 volts.
- 1 reply
- 1
Looking for a DNA75D? Try here: https://www.protovapor.com/product/evolv-dna-75-retail-box/
Take a look at ECigstats, under the tools tab in EScribe or Programs in Windows ect. Not there? download it. Might just be what your looking for.
I don't have an answer for you, I'm curious as well. The pack voltage is correct for 3 cells, does the mod work properly? Here is wiring configuration for 3S, note the bridge from 3 to 4 I suspect you will get an answer shortly from another member/staff
Here are what I believe are the newest releases for Mac, give one a try if you are using an earlier version. https://downloads.evolvapor.com/SetupEScribe2_SP19_US.pkg https://downloads.evolvapor.com/SetupEScribe2_SP19_INT.pkg
There were some 200 boards that said DNA250 on one side and looked like a 250 on that side, the other side looked like a 200. They mostly were used for replacement boards. If EScribe says it's a 200 then it's a 200.
triade 200 screen on only when pressing fire button
dwcraig1 replied to casper89's topic in Installation and Assembly
Give a try here: https://helpdesk.evolvapor.com/index.php?a=add&category=1 -
This might not quite be the answer that your looking for but I have the same problem. The way I deal with it is to use a cable of "lesser quality", it only happens to me with my best cables.
Whenever one of the cells show voltage higher than 4.2 generally the battery management chip has failed. -
HCigar VT250s high battery drain (or wonky reading)
dwcraig1 replied to aatoo's topic in DNA 200 and 250
Look for the LG HE2 csv file, give that a try. -
Triade dna250c, case analyzer, device still charging at 0.001- 0.009 amps
dwcraig1 replied to HEAVEN's topic in DNA 250 Color
If you stated how long that you waited for the temp to stabilize I missed it. So how long did you wait?- 10 replies
Look very closely at where the B- wire of the board connects to the mod's body.
Make sure to try cleaning battery cap threads and the threads that the cap screws into with alcohol and q-tip. I've seen same problem on other mods before where the threads of the cap were the problem even though they appeared clean.
No, as that's about as low as you want it to be set to. With a 15 watt load on a full charged battery your voltage drop should be almost 4 volts.
The problem appears to be with battery, battery holder, wires from battery holder to board. How is the ground connection done on the negative side of the battery? is it a chassis ground or wired. Clean the battery caps threads and the threads of the mod with alcohol (if it has this)
Check my last post., power isn't making it to board properly
