Everything posted by dwcraig1
As with all DNA boards the fire button can only be locked. The only "off" would be to remove the battery.
looking for LG HG2 accurate scv File
dwcraig1 replied to Naorha100's topic in Batteries and Charging
I would think the default curve would be pretty close. It won't function any different only the battery meter will be more accurate. Are you having any type of battery issues, low battery error when firing, ect? -
I am not the person that did mine. The 3 cells have their tabs soldered together to be in series and they need to be undone and soldered together in parallel. An 1860 sled can be installed in that spot and the case fitted with magnets instead of the screws as some others have done.
The dimensions of the FullyMax 900 are listed as (I rearranged the numbers for comparison ) 70 x 26 x 19 mm, the one that you linked to is 62 x 34 x 6 mm. The FullyMax 900 fits the space just right. I think you would have a problem with the 34 mm part of it. One really never knows the actual size of one till it's in your hand. There needs to be room for swelling so a tight fit is to be avoided.
Here ya go https://www.e-cigarette-forum.com/threads/evolv-ing-thread.736118/page-920#post-21206403
That will be hard to find
With the Hana box kit from Ebay and a DNA75 board that Psyclone Mods was almost giving away one of the moderators here built me a Lipo powered DNA75 mod. The included 3s 950 Lipo from the kit was used but first it was opened and had it's cells wired from series to parallel (DNA75 is 3.7 v not 11.1v), a some what tricky operation and not for the faint of heart. So not including shipping or labor this is about a $20.49 mod. The deal on the DNA75 boards is long gone.
Don't wait for Evolv to reach out to you, you reach out to them here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
I'm running the latest and it's 1.1 - SP33.2 Must be a typo
It's quite possible that you might not have any problem inside them as they kind of seal. But since you have it out in front of you you might as well check them.
In the switch? once dissembled, clean out any liquid that may have gotten inside....either your e juice or the alcohol.
The screen sticks to the board. Be sure the screen comes with the board and not sticking in mod. Carefully pry off the metal cover of the switch (red arrow). Try to bend it as little as possible, remove rubber piece, remove small metal disc. Remove the screen prior to cleaning too. https://downloads.evolvapor.com/dna250.pdf
The Lava box dna200 looks to have the typical set up for the buttons, a button on the face pushes against the button of the switch on the board.
I just finished one this morning that I got from the Ebay guy. It was a Hotcig DX200 Does the Lava box use a daughter board for the switches? These are not clones, choose no battery, he will include one. He included two with mine. https://www.ebay.com/itm/HANA-MODZ-DNA-250-200-75-Do-It-Yourself-DIY-kit-11-colors-Free-Battery-incl-/112645968597
So I finally locate VB's post showing the switch disassembled and the photo is gone.
Make sure to pay attention to which way the metal disc in the switches go, it is just one way.
No, it will want to eat things
I'm to understand that Lost Vape only works on one product at a time. Here's one more: https://vapordna.com/products/hcigar-vt75d-tc-dna-75c-box-mod
https://www.elementvape.com/lost-vape-skar-dna75-tc-box-mod https://www.protovapor.com/product/xpv-dna-75c/
When you press the fire button once with it locked does the LED light up? If it does that would indicate that the button it's self is functional. To unlock requires 5 fairly quick presses.
The best place to get an answer to that is here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
I thought that SP38 solved that problem. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=929633
Use a magnifying glass if needed. It goes into the slot marked by arrow, not above it. Put it in squarely past the notch marked by arrow and carefully close cover. I had major problems with this on my first one, I kept trying to put it between the door and connector instead of the slot. https://forum.evolvapor.com/topic/67402-best-way-to-put-the-screen-ribbon-in-place/?do=findComment&comment=906534
In Escribe change the figure for battery capacity and upload settings. You didn't mention what cells that you are using so either convert mah to watt hours and subtract 20% or try a conservative figure like 25 wh if using 3 cells. Or run Battery Analyzer. Note: I have modified the curve to reflect the change from max puffs to max recharges (charging stops at 4.1 volts)
EScribe 2.0 SP17 includes firmware SP35 https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=928400
