dwcraig1
Everything posted by dwcraig1
  1. For the purpose of uploading the theme to this forum just use "Save Theme" on Theme tab page, no need to go into Theme Designer. It should default to the correct file type (ecigtheme), name it what you choose to. Save it to where you can locate it and upload it with your post to this thread. Using Device Monitor with device set on the theme for Replay select cold and live ohms from the tick boxes and fire it. Make sure it is showing an increase in resistance when the coil is heated or Replay won't work. This will establish that your wire is indeed TC capable providing the resistance changes from cold to hot. If there is no change then the wire is Kanthal or Nichrome which will not work for Replay. It looks like from your setting that with a proper wire you should be getting the option to start Replay after firing device.
  2. https://downloads.evolvapor.com/dna75.pdf mm of coarse
  3. Their warranty is done by place of purchase, if nothing can be done there try here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
  4. What is the Cell Soft Cutoff set to?
  5. Have you cleaned the threads of the battery cap and the threads that it screws into on the mod? Does the battery appear tight when the cap is screwed in? Alcohol works well to clean these (91% rubbing alcohol) Is the voltage bouncing with the mod not being fired?
  6. What does EScribe show for cell voltage? Both standing and firing.
  7. If you want to ask Evolv for the info on the board components you need to ask here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
  8. This is the version of EScribe, not the version of the firmware on the device. Though is does contain the INT firmware necessary for Replay. ("3. I'm on SP 19 INT firmware")
  9. To check the firmware version of your device open Device Monitor and the version will be listed in the bottom right lower corner. (Example is of DNA75C)
  10. I would think that either EScribe or your version of firmware is not the required international version. Here is what the page with profiles looks like/
  11. Have a look here, perhaps it will be of some help. https://www.e-cigarette-forum.com/threads/the-ultimate-tcr-list.721201/
  12. Well don't do like I did a couple of weeks ago. I accepted the setting from atomizer analyzer but fogot to upload to device so I had to do it again.
  13. That would be my first choice as well.
  14. The voltage on cell # 1 pretty much tells whats up. Note that the voltage on cell 1 is higher than 4.2 volts. (it's not though). The battery management chip is defective. You can try to return to seller/maker or start a ticket with Evolv. https://helpdesk.evolvapor.com/index.php?a=add&category=1
  15. The last time I read about a member with this problem they were using an older version of EScribe from before the 250 came out. Is your version one that works with a 250?
  16. First thing would be to try a different cable. External USB hubs can be a problem too.
  17. dwcraig1
    Neo Go
    Agreed
  18. dwcraig1
    Neo Go
    https://forum.evolvapor.com/forum/41-modders-forum/
  19. $12 + $2 = $14, not sure but you must have been looking at the board w/screen.
  20. https://www.evolvapor.com/products/dna75color $2 shipping
  21. They are even more here but in stock: https://www.intaste.de/Lost-Vape_3
  22. I'm looking at voltage of cells because % ihas no accuracy
  23. Not the fuse. Charging rate is probably going to be low using USB recovery till it gets to above 2.5 volts per cell.
  24. Go here, to get it taken care of if you don't locate the problem. https://helpdesk.evolvapor.com/index.php?a=add&category=1
  25. Did you get the PM that I sent you a couple of hours ago?
