James
Everything posted by James
  1. 75C Replay is progressing. It is markedly more consistent than a week ago. We will get there
  2. If your device's battery wiring and batteries can handle 30A input, there is no problem. The board will limit input current (from the battery) based on the settings in the Mod -> Battery tab. If your device's 510 and output wiring can handle 30A output, there is no problem. The board will limit output current (to the atomizer) based on the settings in the Mod -> Electrical tab. Increasing the maximum output power on DNA 75 Color (International Edition) to 100W does not remove this protection, and heating of wiring is proportional to the square of the current going through it and is not wattage-dependent. So, as long as the device's batteries, input and output wiring can handle the current limits they were shipped with (as they should be), there is no problem increasing the max wattage of the output. Increasing the maximum currents, *that* is something that should be checked over with a manufacturer. DNA 75 Color (International Edition) allows a Max Peak Input Current of 35A and a Max Sustained Input Current of 30A, and if a manufacturer's wiring, batteries, etc. are good enough to handle that, 100W can be made to work down to a lower battery percentage.
  3. @HarryHunt, one thing you can do is, go to the SS 316 profile for your device in EScribe Suite, and change Temperature to 'Off'. Upload this, select SS 316 and vape it at 35W. Check the Temperature check box in Device Monitor, it will show it but not limit it. Be sure to turn Temperature back on for SS 316 afterwards.
  4. What directory you are trying to save into? As for loading the saved theme, what is the file extension?
  5. I think this is already fixed. I don't encounter it in EScribe Suite 2.0 SP13. What version are you running?
  6. Are you in Watts mode? There are two (overlapping) Watts fields on that screen. One (for temperature-sensing coils) looks like 10W 100F The other (for non-temperature-sensing coils) is centered and looks like 10W (Only one of the two shows on the real screen, depending on whether or not the profile's material is temperature-sensing.)
  7. To change Watt Increments, launch Theme Designer and download the theme on your device. Go to the Screens tab, click Main Screen, click the Watts field you want to change. Go to Source, it will say "Coil power". Click Options. Change either Decimal Places or Step Size. Then upload the theme. Should work The "Go to Source, it will say "Coil power". Click Options." ought to be "double click the Watts field", but it has conditions so that doesn't work. It ought to be simpler. I'll add getting rid of that step to my To-Do list.
  8. Hmm. Could you private message me your settings .ecig file? Also, what language is your computer running in (English?)? Thanks!
  9. Hmm. Are all of your coils of very similar resistance? Maybe it thinks you are putting the same coil back on.
  10. Make sure your user is a member of the plugdev group. EScribe Suite should suggest adding you automatically, but if it failed, doing that manually and logging off/on should give you the permission you need. (What permissions do you see in the /dev directory for hidraw devices?)
  11. The 75C is a single-cell board and does not know anything about it if you are putting batteries in parallel. Also, its battery meter operates on voltage, not fuel gauging, so it doesn't need to know anything about the capacity of the batteries.
  12. Ahh, your laptop runs at 1280x800... I don't have a scrollbar defined for that portion, actually. Will add to my to-do list. Thanks!
  13. I've posted up the Linux version of EScribe Suite 2.0 SP13. @Pop7335, @Suomynona, out of curiosity, how are you launching EScribe Suite? From the icon? The script the icon launches is set up to move the menu bar into the application, avoiding bugs with Ubuntu's unified menu bar. It works for me on Ubuntu 16.04 with Unity.
  14. @dasa2337: I've posted up EScribe Suite 2.0 SP13 on the Evolv DNA 250 Color page.
  15. Hmm. Is this new on SP12? What happens if you set MacOS to always show scrollbars?
  16. What window manager are you using etc.? Is your configuration out of the ordinary?
  17. The DNA 250 Color needs a battery attached to power the real-time clock.
  18. Is this EScribe 1.2 or EScribe Suite 2.0? If the latter, try unchecking Service Packs in the installer. Does it help? Thanks!
  19. @Twiq, SP5.1 and SP6 should be quite similar about charge resetting. Are you sure SP5.1 cuts out less? SP5 certainly would, yes, but SP5.1 should be the same as SP6 in that regard. It is self-protective functionality, detecting quick cut-outs of charge current that can be bad for the device. If it's doing it, it doesn't hurt anything, just annoying. (To be honest, I may have it overly sensitive right now.) PCs have fairly clean USB power supplies so you are unlikely to encounter it there. Does the charge resetting happen to you on other chargers you have? What brand/model of charger is it? 1 Amp or 2 Amp?
  20. @Pop7335, are any menus working for you at all? What window manager are you using etc.? Anything out of the ordinary?
  21. @Kurtis_Loew: 75 Color SP27 is available in EScribe Suite 2.0 SP8 or newer. (Look for the EARLY SERVICE PACK section. SP12 includes it.)
  22. What firmware version are you running/have you been running? Does it only ask about New/Old Coil with the most recent (SP27)?
  23. @Wayneo, what issue did you encounter with the install? Also, SP6 should let you read mod resistance quite low again.
  24. What error do you get when you try a manual update (Tools -> Apply Firmware) ? Also, which version of EScribe Suite are you running?
  25. I've posted up an early firmware with Boost on DNA 250. Let me know how it works for you.
