Everything posted by James
@AnnaR., when are you seeing the Error Press Up in SP38? When the device starts up after a long sleep, or...?
- 23 replies
- 1
- error press up
- dna250c
(and 2 more)
Tagged with:
Hmm. If you go into Tools->Serial Terminal, try the command X=READ BMS. That will clear out whatever battery-management errors it may have had in the past. Wait a while and send that same command again. What does it respond with?
If you would like to try it, this experimental firmware (SP38) may fix the DNA 250C Error Press Up bug that was introduced in SP35. Let me know if you still get Error Press Up when using it.
- 23 replies
- error press up
- dna250c
(and 2 more)
Tagged with:
@mrdidit, do you mean Puff Count Since Reset? If you do "Reset Puffs", this goes to zero. -
If you are encountering the issue mentioned in this thread -- spurious Temperature Protetected messages when using a high-CPU theme like Gauges, with a low-Tcr material [, and possibly, high Preheat settings... any of these three could cause the problem on their own, but it's much less likely] -- when using Temperature Protection but not Replay, and would be willing to try an experimental firmware, give one of these a go: https://downloads.evolvapor.com/DNA250Color_v1_1_SP38_US_test.sw-service (US Edition) https://downloads.evolvapor.com/DNA250Color_v1_1_SP38_INT_test.sw-service (International Edition) This won't help if your problem is related to your 510 connector or electrical grounding. Anyway, let me know how it works for you, if you run into any new bugs, etc. Thanks!
By any chance do you have Ohms locked on your wattage profile? What are your settings for that profile in EScribe?
@maximumsport, what device and firmware version? Thanks! -
When do you get the error?
EScribe on MacOS Mojave fails to launch
James replied to rtbanffer's topic in EScribe, Software and Firmware
I've posted an early EScribe Suite providing Mojave compatibility. It also makes the software 64-bit on MacOS to avoid future compatibility issues. Let me know if you run into any bugs with it. Thanks! James -
EScribe Suite 2.0 SP18 For US-based customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP18_US_ServicePack.exe For US-based customers (Mac): https://downloads.evolvapor.com/SetupEScribe2_SP18_US.pkg For international customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP18_INT_ServicePack.exe For international customers (Mac): https://downloads.evolvapor.com/SetupEScribe2_SP18_INT.pkg For customers using Linux, see the beta thread. --- EScribe --- When you double-click an .ecig file, it now opens a Settings Installer (similar to the Theme Installer). --- EScribe Suite --- Fixed MacOS Mojave compatibility. Minor bug fixes.
- 29 replies
- 12
I've posted up SP18. Mostly small bug fixes, not a major change for Linux.
The coil has to be heated above boiling before it produces vapor, so heat energy added to the coil before this does not produce any vapor. After the puff, once the coil cools below the boiling point, that heat energy is released into the environment. If you take another puff before the coil has fully cooled, the next puff of course has less Coil Loss, as there is less heating to be done. Coil Loss is an approximate measure -- the amount of heat energy added to the coil before it reached 350 Fahrenheit. This is roughly the amount of heat energy that went into the puff but did not go into producing vapor. It can be used to estimate coil efficiency as far as battery life goes..
Do you mean the Follow button? If you click Following, there is an Unfollow button.
It does it in *between* puffs? (Do you mean in the middle of a puff?) What theme are you running? Thanks! James
- 23 replies
- error press up
- dna250c
(and 2 more)
Tagged with:
I've found and worked around the Mojave ...change. The next version will be compatible. -
Are you using EScribe Suite SP17? It looks like the most recent EScribe Suite changed the order in which things were being saved, and when it's near 100% usage, this affected what would fit. The next version will correct this. In the mean time, try reverting back to SP15.1 and uploading the theme: https://downloads.evolvapor.com/SetupEScribe2_SP15_1_INT_ServicePack.exe https://downloads.evolvapor.com/SetupEScribe2_SP15_1_US_ServicePack.exe
Good catch! Download it again. I accidentally had the International Edition's Service Pack set to the US Edition. -
You can go down to 0.02 Ohm on the DNA 250C. (This software limit is mostly to prevent accidental firing into paperclips, metal shavings, etc. when no real atomizer is attached. You can still use Atomizer Analyzer to read lower resistances.) The lower you go on resistance, the more heating will end up in the 510 connector and wiring. If your mod has a high quality, high current 510 you will have no problem. You will encounter reduced power due to the current limit, however. The output current limit is 65A, so the max power is 65^2*R=4225*R. For 0.02 Ohm, that means a max of 84.5W. You can get 200W down to 0.047 Ohm, and 400W down to 0.094 Ohm.
@Canadianvape, is that new to SP35 on DNA 250C? If not, what kind of Ohms change do you see in Device Monitor as the mesh heats? If it's not at least around 20% it may not be Stainless. Do you have it as "Restrict to viable coils." or are you using another mode? -
Escribe Installation Problem !!
James replied to thugsouljah's topic in EScribe, Software and Firmware
Is an older version of EScribe running while you are running the installer? -
The clock runs off the battery, so if the board does not have battery voltage for whatever reason, the clock will not work.
The Go will show up on USB for the first hour after the cable has been plugged in. (After that, it disconnects from USB Data to conserve energy.)
I've posted SP17 in Early Firmware. It supports DNA Go. Let me know if you find any bugs in it. Enjoy James -
EScribe Suite 2.0 SP17 For US-based customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP17_US_ServicePack.exe For US-based customers (Mac): https://downloads.evolvapor.com/SetupEScribe2_SP17_US.pkg For international customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP17_INT_ServicePack.exe For international customers (Mac): https://downloads.evolvapor.com/SetupEScribe2_SP17_INT.pkg For customers using Linux, see the beta thread. --- DNA Go (firmware 1.1 SP37) --- Improved the LED response to lock/unlock. --- DNA 250 Color (firmware 1.1 SP35) --- Improved the deep sleep behavior. --- Theme Designer --- Fixed a crash on Linux when moving controls. --- EScribe Suite --- DNA Go support. Minor bug fixes.
I've posted SP17 with bug fixes for the Theme Designer, and DNA Go support.
