James
Everything posted by James
  1. In EScribe, the "Temperature Coefficient of Resistance (approximate)" option has a minimum TCR that it allows to be specified. This is essentially an editorial decision on my part -- below a certain level, it's just not going to work well. The firmware of DNAs has no such restrictions, so you are welcome to upload any monotonic curve, and it will happily *attempt* to control to it. It will try. As an aside, here are a few reasons that controlling very low TCR can't work well: The smaller the resistance change, the more other parts of the system will distort the accuracy of the result. For example, some stainless steel atomizers have nickel legs. Suppose the nickel legs heat 20F. If the legs are a tenth of the resistance, stainless has 1/6th the TCR of nickel, so that's going to measure as if the stainless steel has increased 20F*(6/10)=12F. So as the legs heat up, your vape gets 12F colder, even though the coil is staying the same. Suppose the material you chose has 1/60th the TCR of nickel. That's going to be a 120F distortion. As the TCR gets smaller, this kind of problem gets bigger. Even copper wiring has a TCR. Sometimes screwing in an atomizer slightly differently can shift its resistance some fraction of a percent. If (say) 400F is 1%, how can you hope to get the vape consistent? There's an electrical noise problem at a certain point. Suppose you have a 1 Ohm atomizer and can read to 1 mV / 1 mA. At 25 watts, it's 5V, 5A. If (say) 400F is 1%, 1.01 Ohms is 5.025V, 4.975A. You've got 25 values between 70F and 400F, so a single bit of electrical noise on either voltage or current will be 13 degrees. That's going to be a rather bouncy vape. etc.
  2. This will happen if the battery is not connected / making contact. It bounces like that when it is powered by USB only.
  3. I'll be looking into this in the coming week.
  4. Yes. Go to the Theme tab, Theme Designer, Appearance tab, Fading.
  5. I've posted SP6.
  6. I've posted SP5.2. Mostly I've fixed bugs on the MacOS version, but a few of them affect Windows as well. No new firmware Service Pack just yet.
  7. I've posted beta 13, which fixes some of the bugs reported here.
  8. @blueridgedog: Found this. Thanks!
  9. The Soft Cell Cutoff is 2.75V, so yes, it should be possible. Is it refusing to fire for you at 3% battery?
  10. Hmm. @Fathur Rahman, one thing to try: remove the battery and leave it without power for about 15 minutes. Then put the battery back in. (That will reset the clock. The clock stays on for a while after unplugging the battery.)
  11. Out of curiosity, does your account name (/Users/accountname/) contain any non-alphanumeric characters? I'm wondering if it didn't change user correctly during the installer.
  12. @koronis, thanks for reporting that ECigStats display bug. I've fixed it. @bmaggot, for future reference you should be able to do chmod -R 755 to do all subdirectories as well. That said, do you not have write access to your user directory? That really should not happen. By any chance are there other programs in the .mono subdirectory? I wonder if one of them set the permissions up in an odd way. @Uwe Kliem, what do you mean specifically by the Mac-Touch? What does it do that is out of place on MacOS? Thanks!
  13. Hmm. This theme is going to that screen on both SP24 and SP25 for me.
  14. Could you message me this theme? I don't find it in the Downloads section. Would very much like to reproduce this bug.
  15. What theme? Thanks!
  16. @ozzy: On MacOS, they are stored in /home/Username/.config/Evolv/EScribe Suite/Backups. It will only store, for each device type, at most 20MB, and at most 200 files. (Typically, .ecig files are smaller than 100KB.)
  17. @ndb, @Lowbytes: Give beta 12 a try. Thanks!
  18. No, room temperature is just not preserved across firmware updates. They revert to the board temperature. Doesn't mean anything is wrong with your thermals. That's on my (very long) to-do list, don't worry.
  19. Interesting. Looking into that. @JBood: Give beta 11 a try.
  20. I've posted beta 10 for Mac. It fixes a number of Mac bugs: Available Materials not saving, ECigStats minimizing to the Dock, some themes not being uploadable, and a few others.
  21. I've posted up EScribe Suite 2.0 SP5.1 as an early release. Most of the fixes are for the Mac version, but it does correct temperature instability on some low-resistance Stainless coils (75 Color).
  22. The Cold Ohms should be more accurate in SP24. (What kind of mod resistance do you have now, out of curiosity?) That said, is your non-preheat power sufficient to make it to 500F? Preheat is not meant to hold a temperature perfectly, it is meant to get the coil and wicking up to around the liquid boiling point. (Preheat backs off as it nears its target temperature.) It doesn't make much sense to have preheat temperature up near the vaping range IMO. If it preheats to the liquid boiling point, that's ideal, since beyond that the mass flow rate of the vape will be largely controlled by the power setpoint.
  23. @Noah B: Yes, the next version fixes it going into the Dock. It still has a dropdown menu presently, but at least when minimized it just goes away again. I may look at embedding more of the screen in the dropdown in the future, that's an interesting idea. @znapr: Could you message me the theme? It's probably a bug.
  24. Oh, I see what you mean. I thought you meant the dock icon. Yes, it appears to show on the right side. I'll have to fix that.
