Wayneo replied to David Campbell's topic in EScribe, Software and Firmware
@tennisguru1 Simple Answer: No, as it's not mentioned at all above. Long answer: The DNA75 only ever needed 1 update which was named and released 2016-06-05. You can see your current firmware version in 'Device Monitor', lower right hand corner -
Steam-engine. Wire Wizard. Upper right hand box. You'll see equivalents. Use Nickel. In the lower area of the page, use your actual material. Also it's a good way to use different materials on the DNA40 which only had Nickel.
Cold ohms is not correcting itself/updating on my DNA 250c
Wayneo replied to bluegray's topic in DNA 250 Color
Quick easy answer: Yes! Longer answer: Architecture/thought process change with the C boards. On the C boards, both the resistance and the temp it was measured at is written into the profile number you are/were in. From there the cold ohms at 70F can be calculated (like the 60) and used inTC. OR in theme designer you can change the value displayed to you, to what it would be at 70F. -
You can get an official answer here. https://helpdesk.evolvapor.com/?a=add For Question 2, there's a firmware (SP38) you can try in the thread called "Throttling" right here in this DNA 250 Color - General Discussion area. Right now on my browser, it's on Page 4 posted by James. Welcome
@James , my mod with SP35 (told you about this earlier) did not exhibit this until after I created a new screen on the Evolv default theme and had it set to 'return to parent'. After changing that option to 'return to main screen' all is fine at SP35. That mod is still at SP35.
- 23 replies
- error press up
- dna250c
(and 2 more)
Tagged with:
@taffarovsky@yahoo.fr This .ecig file would be the settings for his mod, with his batteries, and its thermal characteristics. The improvements will be that the ambient temperature should be more accurate, and his battery % will be more accurate. Many will just download this and use it, or the tools are there for you to run your own. These are mainly important for very low ohm build Temperature control vaping. Welcome.
Moderator EDIT: Moved to a better area. You'll need to read through this post. Like I already mentioned .... it's a cheat so YMMV. Welcome
You've posted this in the DNA250 Color area. Is your mod a color screen or actually a DNA200 or 250? Yes to the 250 and 250C, there's a cheat for the 200.
Yes. Escribe software link was/ is also in my signature line
Welcome There is a dedicated DNA GO section, and an official Pinned posting from Evolv regarding this issue.
Gents, for those of you that still have a (non respoding) faulty Orion, I hope you've read the official Evolv response posted earlier today. Below is the link.
Which Service Pack are you currently running? I'd suggest you run EARLY SERVICE PACK - EScribe Suite 2.0 SP18, mod firmware version 1.1 SP35
DNA 75C - using replay only ck atomizer warning - help
Wayneo replied to 1shootist's topic in DNA 250 Color
IMHO, this could be the 510 connection on your mod. I'd clean the threading and positive pin on it with IPO and make sure it still springy. -
@LanzarotechrisIt's really up to the theme author and what he has chosen to be displayed or changed. There is a special review and comment section for each. Instead of calling it the Preheat/Punch tab, just the word Preheat allows the use of a larger font. For display purposes I would have used the same, but for troubleshooting, the quasi official Evolv definitions/norms (for me anyway, is the only way for my old tired brain to think in wattage or TC (actually TP) mode. )
@Lanzarotechris I'm a Mac High Sierra user. I also find 'starting up' escribe slower with this latest version. No idea about the next release. After trying 3 different browsers Safari, Firefox and Chrome I still don't see the About Me. No idea about your battery issue. Happy vaping.
No idea if you're talking in a Theme (which can vary), or Device Monitor. I'll talk Device Monitor so you know what CAN be available in a theme. In a Profile where a NON TC material has been selected you can do a BOOST PUNCH. Set 1 second slider. Effectively a hard normal soft like other mods, to give a beefy coil that extra to start vaping quicker. In a Profile where a TC material has been selected you can do a Preheat of the coil. You Preheat it by punch/watts, either by a slider 1-11 again (notice no timer), or to a temp, before the Preheat function ends.
Damn, I wished you hadn't noticed that. And here's where we get into different mods again. This will all sound Greek, you might need to read it a couple times. If both mods were properly thermally calibrated your room temps would be closer. If both mods had their internal resistance properly set, your mod would take into account those unique minute differences in connection losses up to and including the 510 connector of the mod. Now even if both those were done, the non C mod (Your 75) uses the info above to derive the 'refined' value of the ohms of that coil at 70F based on that derived room temp at the time. (So long as you didn't lock the resistance). Here's the difference A Color mod uses the current Ω and same current derived room temp as its base values, and writes that into the profile it was created. Hence 'a' difference. BUT if one were to refine your SS304 coil to 70F it would drop the value even further to ~.1725Ω (using the tcr of 0.00100) compared to your .182Ω on the 75. These all play into it. I dunno, I can't remember seeing or noticing an 'About me'.
Different architecture and generation boards. On your 75, click Atomizer Analyzer button. Different generation board. Click Diagnostics in Device Monitor.
YOU are over complicating things, and using terminology that has different meanings here. Use your 30 watts in a straight Replay profile. No TC, just a TC capable material/wire. Adjust the BOOST PUNCH to Preheat your wire. Enable Replay, when you like the puff. Turn down warmth. Only think flavor. If you have an issue after that, tell us. Once you START ranting, I stop reading. Sorry man, just trying to be helpful. OR If TC's working for you, just use that
Just to add a few points. When you plug in your mod, the escribe display will change depending on the board type. Some will show different options/features. When I get a new juice or coil I'll run a tank or two in straight simple watts. TC can blast through flavors or even burn or mute them at different temps. When I understand the juice and coil I'll fire up Device Monitor. Boost Punch for the 1 second PREHEAT you want. Slider 1-11, proportional depending on settings. Device Monitor tells all and will show exactly what's going on with each parameter change. I can't figure out if you're ranting about using your mod in Watts mode, Replay in watts mode, TC, or TC with Replay. And I cant talk about the UNKNOWN settings, cuz I just don't know about them.
You might want to upgrade your firmware. The .25 is the DL coil, not the MTL coil. The Max Puff Time limit is under the 'Safety' tab. Cheers.
@TorturedZen IMHO the OP is purposely vague in his description, needs and intended purpose, so I'll take a wild a*s guess. As weed/cannabis is being decriminalized in many places, or CBD for medicinal purposes ........... one could put a non liquid (think weed/shatter) in a tank, and heat it till it vaporizes, then inhale after their timer ends for a full puff. Specialized vaporizers like that but much more rudimentary have been around for years for that market. OR SO I'VE HEARD Or perhaps has Strabismus, allowing them to focus that close. There are other specialized forums for that use case.
Lost Vape Paranormal 250C
Wayneo replied to BrodatyVape's topic in Connectors, Components, and Accessories
Solidly attached. I'm not gonna start jamming anything anywhere. Sorry. -
Checked and crashed with High Sierra here.
