  1. Some 'glitches etc.' are real or mod specific, while some are merely new user misunderstanding. But you have the ability to roll backward or forward at your leisure. If your mods are both working fine, you do not need to upgrade either. You will note from the link I posted, the prior problems fixed and for which board type.
  2. Although I haven't used that enclosure, I have worked with Dan (owner) and he's a top notch guy.
  3. I'm not @ArminF, but that version of the software can be found right here. No password required.
  4. Just a few suggestions ......... Have you tried stealthvape or modmaker in the UK. Or ati store on ebay, or protovapor in the US?
  5. Here you go @Photo Pete. Looks to be their official site, with instructions for you being in the UK. Good luck with your mod. https://www.lvevapor.com/after-sales-service/
  6. Well, I believe the default value is/was 9Wh. That should be changed to ~15-18. Then (as always) upload to your mod. I do not understand why you said that. You could use someone elses csv (curve) and values or run your own analysis which will give YOU valid results for YOUR batteries
  7. If you start escribe with no mod attached, 'edit new setting' and pick the 2 cell option, it will give/show you all the evolv default battery parameters. The csv only makes your battery % or icons more accurate. It does not affect how your mod works. I'd suggest you at least adjust the Wh setting for your battery
  8. If you start theme designer, you'll see the wallpaper tab. You can crop your picture to the size you want and use it there, Play around with it. There are many clear options for when and how it will appear. DJLSB has a good tutorial starting just after the 30 minute mark. https://youtu.be/1dvBpTm-FQM
  9. I really suggest you watch a video on how to run battery analyzer, or search the forum, or just look at your file compared to others. Or even just try to 'load' the file you posted on YOUR mod, cuz even though you say you're using it, YOU'RE NOT. 6 Columns(Fields) and 643 rows of data, ARE NOT A BATTERY DISCHARGE CURVE.
  10. What does that mean? Are you using that file on your own mod? It does NOT look like anything I've seen before
  11. Great so now that you know the current limitations, you can work around or within them.
  12. Same stuff you were told by @retird back in February. Is it a LiPo battery mod?
  13. Well ................ I'd really suggest you open a Help Desk ticket. Link in my sig. Longer answer. Yes, it does sorta get stuck. Right after a soft or hard reboot or powering down it will work again UNTIL you hit the fire button, then it sticks again for a while. This is not a hardware issue with your Triade.
  14. I can't wait any longer to give you individualized help as there were 3 questions asked, but here's a 6 page thread you can pick through. Hopefully something clicks, and you resolve the issues. And welcome
  15. Many different reasons for this issue. If it's mainly affecting your builds, have you changed anything in your process? And 'newest update' has a number, what firmware number(s). If it weren't for your 'alot of the mods' comment, I'd be asking are you reading and setting the coil resistance at ambient temp in the profile you're using questions
  16. Stealth - no lights, or few lights. There are many posts in this area about settings. Welcome
  17. 2 moderators commenting on the same post is usually a bonus for the OP at least IMHO. Butting in has never crossed my mind. Plus, I think we're done here.
  18. I think you've misunderstood me. I'm saying that if you can prove something to yourself, it's much better than relying on anyone. I could be wrong and make mistakes daily (or so my wife says).
  19. Huh? I'm not gonna comment on any reviewer, but yes, there's misinformation all over the place. BUT you can prove what I said to yourself. Go into escribe, and look at any profile with a TC material showing at the bottom. See the options for Preheat and punch? Change the material there to watts/kanthal, and now look at the options. Preheat should have disappeared, and now magically you see boost
  20. You can only pre heat in a TC profile You can only boost punch when your material is not identified as a TC material in a profile (there's a whole lot said there in a few words)
  21. Yes, it's possible. Read the post I link (click on ruckus), and the response from James, who answers all your questions.
  22. All depends on your juice IMHO, and how you like to vape. I usually go through 1 tank of a new juice in watts, then adjust for TC. That shows me the watts I'm happy at, the I'll set my preheat watts maybe 25% higher, and my regular power at slightly higher watts I know I already like. I can only remember ever being blown out of TC once, an that was because a coil leg had become loose. There is no one way, or right way. If you're happy, it's all good ... for you. general rule of thumb: Higher mass coils require more power to initially heat than lower mass coils.
  23. @TorturedZen That was really just to replicate blasting to that temp. This part was also important. Right now it's taking me over a second to reach my set temp as I like the flavor changes as it ramps up. Enjoy your mod.
  24. I opened a Help Desk ticket and was passed on to some gent who took my order for the 1A data/charging board the 60's when they were not showing a while ago. Link in my sig.
  25. Replay will work with ANY Temperature controllable material/wire as their core. I'd call the Big 4, Ni200, Titanium, Stainless Steel, NiFe .
