That was NOT a true statement. Even if you setup your profiles as @dwcraig1 has suggested, YOU will still need to change to that profile.
I'd suggest you update your version of escribe first. Link is in my signature for the latest.
Can you post a full printscreen of Device Monitor with the mod attached. Thanks
What are the individual (battery) cell voltages right now? Unplug mod, swap battery positions. Now, after swapping positions, what are the individual cell voltages? If you can't find the info using the theme start escribe -> Device Monitor. It's on the left hand side near the top
By design these 2XX boards only 'buck'. Those others must 'boost' and 'buck'. Here's the Designer/Engineer comments https://forum.evolvapor.com/topic/69940-dna250c-wont-give-me-11-volts/?do=findComment&comment=926591
Lower the coil resistance if you want more. Yes, the 3 battery mod will output more power than a 2 battery mod based on your current battery voltages.
No more ideas. You may as well open a Help Desk ticket. https://helpdesk.evolvapor.com/index.php?a=add&category=1
Right now do you have any other 200 series boards where if you click on the 'load csv' it will actually open the window to choose a file? Have you tried rebooting your PC? What OS are you running?
Whew. Glad you solved it. I also have an OG BB. Right down to those fancy aftermarket painted/anodized screws (threading) holding in the battery connector can cause problems. I only know a few other BB users that even use TC. I build mine (exocet or insider) quite often with Ti01. I have a clone Haku, but never even unpacked it.
Damn, you have thrown me. I just don't know.
Yes. They can be found here or (Stealthvape and Modmaker) in the UK. Here's a link with instructions
That whole boro area is your positive and negative connection and should always be clean. Glad to hear it's working now with a different RBA. Which RBA setup was giving you issues?
It would have saved us both typing if you had answered my very first question, but no worries. Sounds like Stainless to me.
You can see that rise for yourself with device monitor with temp, cold ohm, and live ohm checked
Yes
Sounds like your mod not sensing that coil as temp controllable. Seeing as it's a BB, apart from checking the coil, you could clean the brass/copper base that the coil touches, clean the nut and the threading on the box. After that it should work as before.
Can you plug into escribe and do a printscreen of the current profile, or do you have to do this on the mod? If you have to do this on the mod, is the temp value still shown as one of the values in small text on the left?
Sorry man, not an Evolv board in there. You should seek advice elsewhere. Don't they have a product forum?
Yes. Enjoy your mod.
NiFexx has been used for vaping for many years. I use it occasionally, but I'm not going to say what's safe for anyone other than me. The GO board will allow Replay with pretty much any TC capable material/wire. Or it'll work like any other mod in straight watts.
You can open an official Help Desk ticket here and they will guide you: https://helpdesk.evolvapor.com/index.php?a=add&category=1
By now you'll see It's nothing more than a slightly and hastily warmed over copy of the djlsb theme with Replay (IF the djlsb version didn't have Replay) Start escribe. File -> Open that .ecig file Theme tab -> open/change/look at/save theme (after deleting 1 wallpaper) You'll see nothing but theme
Loaded easily on my 75C. That is clearly a V1 theme in the .ecig file. But if you like it .............. whatever. Just go delete wallpaper #3 which is not even used and it will load, or any one of the wallpaper screens. At least it's not hideous
In the ecigstats app check that the 'link to account' and 'options' are setup properly. Plug into the machine that has the ecigstats app more often (its icon should appear) Download your data from the ecigstats web page
