  1. April 13, 2021. The download count has been spammed for this theme by an unknown user(s) due to this same action (spamming) from other theme designers. Wanna be losers looking for imaginary internet fame. This same comment is posted for the current 5 themes shown and the prior 2 Top themes.
  2. April 13, 2021. The download count has been spammed for this theme by an unknown user(s) due to this same action (spamming) from other theme designers. Wanna be losers looking for imaginary internet fame. This same comment is posted for the current 5 themes shown and the prior 2 Top themes.
  3. April 13, 2021. The download count has been spammed for this theme by an unknown user(s) due to this same action (spamming) from other theme designers. Wanna be losers looking for imaginary internet fame. This same comment is posted for the current 5 themes shown and the prior 2 Top themes.
  4. April 13, 2021. The download count has been spammed for this theme by an unknown user(s) due to this same action (spamming) from other theme designers. Wanna be losers looking for imaginary internet fame. This same comment is posted for the current 5 themes shown and the prior 2 Top themes.
  5. April 13, 2021. The download count has been spammed for this theme by an unknown user(s) due to this same action (spamming) from other theme designers. Wanna be losers looking for imaginary internet fame. This same comment is posted for the current 5 themes shown and the prior 2 Top themes.
  6. These are the words of the inventor/developer.
  7. That doesn't look bad. So go to the 316 profile, measure and set the ohms. It should be close to one of those. Can you post a printscreen from escribe of the profile number you're using.
  8. Can you check the stability of the cold atty/coil in escribe by using 'Atomizer Analyzer'. You should see very small fluctuations in the resistance (.002 - .004Ω) as low power is applied. Let me know. Is this that same mod you had issues with that off center 510 and check atomizer issues? Have you ever vaped in TC before?
  9. Let the coil cool down to ambient/room temperature, remeasure the resistance of the coil, and then try again. Have you vaped successfully in TC with this mod before?
  10. "I hope you all find this useful and please do note this is not for a regular 250c, but for the Vaperz Cloud HOG which has been modified to 400." Every single DNA250C with 4 batteries in series can hit 400 watts just as easily/capably as that HOG. That theme, which is really just a new wallpaper is mainly the Evolv default and can be used on any DNA color mod.
  11. Try stealthvape or modmaker, both in the U.K
  12. @host11 Go to any field you want. Options. Don't show units
  13. Thanks, and this is before coffee. BTW, I've also been called the worst 🤣 Feels, man. Scary times ahead for you guys
  14. Well Protovapor seems to have the small ones in stock. You can check if they're still shipping https://www.protovapor.com/product/replacement-dna-screen/
  15. Outside of the U.S, probably stealthvape, or modmaker. Both in the U.K Hopefully they'll use discreet packaging. During non pandemic times, I've had Royal Mail deliveries take anywhere from less than a week to two weeks to Canada 🇨🇦 Edit: You don't have to use the Evolv data/charging board. Others such as the Delro and SXK BBs have used others. They can be found at mcmaster-carr (www.mcmaster.com) in the U.S
  16. @dnafitness This post inspired me to find an old credit card sized cheat sheet and repost it here https://forum.evolvapor.com/topic/71559-cheat-sheet-key-combos-for-non-color-mods/
  17. Can be found here https://forum.evolvapor.com/topic/71559-cheat-sheet-key-combos-for-non-color-mods/
      • 2
      • Like
  18. Can be found here https://forum.evolvapor.com/topic/71559-cheat-sheet-key-combos-for-non-color-mods/
  19. Cheat sheet for non color mods. The only thing missing is the boost punch feature (like pre-heat for any wire type not used in a TC mode). Works for board types 60, 75, 250, and 200 (except boost punch) Boost Punch - Go to a non TC profile (watts material). Lock mod (click 5x). Hold + and - minus at the same time. Then up or down. 1-11 proportional for 1 second. Unlock mod. It’s a 1 second boost, proportional, like on TC This was created by user wanderb. Below were his words Coming from years of using YiHi boards, I found it hard to remember all the different button combinations to configure my Therion 166. To help alleviate that problem I made a creditcard sized cheatsheet that you can print, and store in your wallet. Print the attached PDF (do NOT scale to fit), cut out the desired cheatsheet (regular creditcard size, and slightly smaller to leave room for laminating), then fold it over. One side has TC mode, the other side wattage mode. Glue the final product shut, or laminate it and cut it out again. The smaller version has 2mm less on each side, which makes it creditcard sized after laminating. DNA250-cheatsheet-v1.0.pdf
  20. IMHO, If this is new, I'd return it to place of purchase. It would be DOA (Dead on Arrival)
  21. No worries @Roxii about the mailbox. We got you. If you're having trouble finding the theme @James Bellinger sent you, I can send it to you. Once you require no more changes I will publish it as the Roxii theme and you can let others know it has been a help 😇
  22. In looking at your screenshot, notice up at the top it shows both batteries at 4.18V Right now that's what battery analyzer believes to be 100%. You could (in the screen behind it) move that far left value down to 4.18 as being 100% so some light or theme message appears. Totally off topic, and not related to this, you could also upgrade your version of escribe. Link in my signature.
  23. Can you post a full screenshot from 'Device Monitor'
  24. Right down to a 10 point font, so it could read battery % as on the default
  25. @James I actually worked with @Roxii and made something similar for her over the weekend. Mine was also the default based with only the battery % taking her to the settings. That way her phone could read/speak the values while she's out and about. She plugs in and makes all changes via escribe
