  1. @zark comrade, sure, I can understand that (what you wrote). Now both your board and room temps are more realistic, and I believe you can see those in °C.
  2. @zark wrote -> This phrase made me think that I was mistaken when entering room temperature when analyzing the case. I re-analyzed the case and now the mod does not heat up above 55 ° C even when vaping while charging. Most likely, the analysis of the case is a very important factor in the fight against overheating of the board. I think you're mistaken comrade. Your mod never overheated after you made that error (Room temp value higher than it really was). It just thought it did. Think about that, it's a much longer reply if you don't understand why I would say that.
  3. Yeah, it's one of those toughies. If they yank your chain stealthvape.co.uk is the official Evolv repair depot if you're not in the USA. Good luck.
  4. Try the video you posted yourself. It didn't play for me. Thanks for the escribe update.
  5. Your video did not play in your initial post. And you ought to ensure that your version of escribe is updated especially if this is your first dna color mod. Link in my signature for the escribe link. Edit: If it won't even light up, you've got 2 choices, I'd do them in this order. Place of purchase for vaperz cloud warranty. It could be anything. Evolv 'Help Desk' link if you think it's the board.
  6. Can you post a full printscreen/screenshot from escribe -> 'Device Monitor' while plugged in. Thanks.
  7. @greenwich444 Go read the 2nd post here (my 1st reply). You don't need to create 2 new posts, as well as asking here . The search bar up there works as well. ↗️
  8. Moved to proper forum
  9. That is correct. The default is a basic working theme, direct from Evolv. Some companies write their own to customize them, most do not.
  10. Themes run the gamut from absolutely stellar to the opposite. Click on that big 'Downloads' option and you'll have around 8 different sorting options. In my mind, the About section tells you a lot about the quality of the theme in most cases. Or reviews and comments. Some will give/show/allow just about every single option. Others are more minimal. Your choice for what you prefer. HOW the theme works is all up to the Author, and you can leave a review or comment for theme specific queries. Good luck.
  11. There is an early release that is newer, and when Evolv deems it fully baked it will be pushed to escribe for more general use. As a new user you might want to wait, but if you must, it's in the 'Early Firmware' post in this area. Firmware is board type/chipset specific, not Mfgr. device specific.
  12. Thanks for the update.
  13. Quick answer - no. SSxxx has always been an alloy so unless you have your own thermocouple, it'll always be a guess at best. I trust the Evolv and steam-engine TFR files, or you can create your own TCR material profile using anywhere from 0.00092 to 0.00100
  14. @DangerBass Did you ever get this resolved? Did you send it in, or if you did the swap yourself did you notice any ejuice on any components? @BrentMydlandthis post is the one is was referring to.
  15. Very interesting and detailed post @BrentMydland 👍 I know a handful of users who have had this same issue. Multiple mods, and only 1 going through screens. I wonder if Evolv ever gave you a reason for each of the prior screen swaps? Thoughts here, in the past have ranged from juice entering the board at the edges or dirty connections at the Zif connector that can be cleaned. Or just a low quality screen. The problem for us is we never hear back from the users, or from Evolv. I have never suffered a screen issue with any of mine. Having said all that, there are Evolv instructions on how to change the screen, and then you could see for yourself. https://forum.evolvapor.com/topic/71341-how-to-change-a-screen-on-lostvape-triade/ I'll go comment on a similar issue post asking about that resolution, you'll see. If it were me, my suggestion(s) to you would be the same as they were to him. Please let us know how this gets resolved.
  16. Nichrome 80 is not and has never been a material used for TC vaping on a DNA mod. From my dictionary "(woes) things that cause sorrow or distress; troubles" was a very fitting word for your DNA75. I see we're all done here. Have a great day gents. 🙌
  17. What part of that statement do you NOT understand? I'm this close -> <- to hiding or deleting or locking these posts that clearly show a basic lack of understanding the most simple concepts My patience is wearing thin.
  18. What was the question? PURE CRAZY TALK. Look at YOUR screenshot. Look at 'Temp set' 550C, then you also enabled the 'Temp' value, BUT THERE IS NOTHING SHOWN. WHY? CUZ IT'S FIRING AT YOUR 13.3 WATTS. EVERYTHING WAS THE SAME NO MATTER WHAT YOU SAY.
  19. Look. Nichrome 80 IS NOT A TC MATERIAL. NO MATTER YOUR TALK ABOUT 550°C IN YOUR INITIAL POST OR 350°C HERE THE HARD BOARD LIMITS WILL NOT ALLOW THAT (EVEN IF IT WAS A TC MATERIAL) You can only adjust the watts or boost with that material.
  20. From your screenshot you are not close to any limits. Adjust the power/watts up. This is not a firmware issue. The same tools are available to you, but using files from not even the same brand is just crazy talk. Being a low watt vaper, the internal mod resistance is probably a little low. The same tools are available to you, but using files from not even the same brand is just crazy talk. Being a low watt vaper, the internal mod resistance is probably a little low. IF YOU WANT TO REHASH YOUR DNA75 WOES, GO DO IT IN THAT THREAD.
  21. Alrighty gents. This forum is to discuss your current issues that you are having with your DNA mods. Comparing your mod to others is fine in general, but not the focus as we're here to help with your mod in hand. You can self edit your posts, or I will in the morning. Be certain with what you write, because I will be pointed in my critique. If you don't self edit I can lock and hide this topic and you can start again , because in good conscience I'd hate for a new user to read the vast majority of these posts.
  22. @Fyl8866 I have merged your 2 initial posts into this one, which in itself was a duplicated post. You don't need to do that What kind of material (wire) are you using? What atomizer are you using? Can you post a full screenshot while firing your Odin 75C in Device Monitor. Just 3 checkboxes ticked. Power, live ohms, cold ohms.
  23. I would follow Mooch's CDR rating, not the manufacturer rating. BUT if you're going to be using 2 different batteries with different amperage ratings you decide what value to use. Do you use the higher rating and stress the lower rated battery or not. The 2.75v value for 'cell soft cutoff' is a decent value for both, even though I've seen a 2.3v 'fully discharged' value for some batteries.
  24. They are different depending on each board. From lower to higher in this order. 200, 250, 250C. Usually page 1 or 2 on the datasheet for each board. Your mod probably has the evolv defaults configured. For battery specifics you should use Mooch's ratings/testings. Edited: You were talking battery specs, I was answering board specs. 🙄 I've moved this post from the 'DNA 200 and 250' section to the 'Batteries and Charging' section.
  25. Translation: I'm sorry, I'll enter it in Japanese. No matter how many times I check how to insert it without displaying the screen, it does not appear. I still do not understand what you mean, so I will ramble. The DNA75C datasheet shows how to install the screen. https://downloads.evolvapor.com/dna75color.pdf When the ribbon cable is bent over the LED it will still shine through, showing a color, if you choose to. Some mods have a dedicated hole where you can see it. Some mods have a big enough gap around the fire button where you can see it. Some mods use a clear fire button. Some mods you can't see it at all. I hope that helps.
