  1. Are you running the latest version of escribe. There was an issue which is now fixed. I just dowloaded and uploaded it successfully to my mod.
  2. NO. Those are re-wraps. Search for 'battery Mooch' and choose from his listings. Known good brands are Sony, Samsung, and Molicel purchased from a reputable supplier.
  3. Read what you quoted a couple times to yourself. And you forgot to answer this Well? What other mods/pods have you used before this, and do any have adjustable wattage? It is common knowledge to start low and increase to where YOU get the best flavor. My very first puff was at that value and it burned my mouth not the coil. So I set it to 11 and worked up to what I liked which was 15. And 14 on the 0.8. I know it was OXVA that set those wattages for each of the different pods, and the .6 for sure matches with their Kanthal version. So you put in an empty pod at your regular watts, the mod lets you vape, and you don't complain of that nasty cotton taste? So after 1 puff you're throwing them out? That's usually what a person does when a coil burns. If you LOWER your watts and put more juice in any of those pods, do they taste burned?
  4. Watts can play a massive role, but the majority of complaints are the exact opposite of yours, with numerous 'fill pod' warnings. You're vaping at the edge. If you read the notes as I suggested, you could use ecigstats, and download a couple of your burnt puffs. The maximum any 0.6Ω coil can reach is 0.558Ω. Yours 0.4158Ω The maximum any 0.8Ω coil can reach is 0.687Ω. Yours 0.6259Ω That's perfectly acceptable, what does not seem right? You hit .62Ω that's so close to the max, ~560F. That won't trigger any warning. For the second time, turn down the watts and try that.
  5. Those are both very close to their maximums. You could turn the both down a couple watts. For me, I run my .6 at 15 watts and the .8 at 14 watts. If you read that firmware thread going up from the bottom you'll see their notes. 128 is the current latest and there is an experimental SP130 in the works (you can use search for more details).
  6. What watts are you using for each pod? Are you using the latest firmware (which won't fix your intermittent fill pod, but does enable more reorting)? The latest is always the last post here. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/page/2/#comments Your Atomizer Analyzer readings are well within the range for each pod. 1. Yes, you are correct. More details here https://forum.evolvapor.com/topic/76121-low-sensitivity-fill-pod-settings-file/#findComment-946026 2&3. Anti Burn shows when a SS pod is inserted. A regular coil will not show that. Yes, it is active and prevent a dry hit in real time. More details here. https://forum.evolvapor.com/topic/76128-the-fill-pod-situation/#findComment-946065 With ~50k puffs between 2 devices, I could not say it's a board issue
  7. When you start escribe with your mod plugged in, you will also be given a notification if there are updates.
  8. @fp1 No, not the latest. The latest is always the last post here. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/page/2/#comments
  9. If that's the evolv default theme Go to settings (cog) -> coil -> boost, then up/down If that's not the evolv default theme, ask the theme designer
  10. There are not 'Themes' per se. All changes you can do are under the 'Display color schemes' in escribe.
  11. You can open a 'Help Desk' ticket and ask them to fix it. Link in my signature line
  12. If you start Device Monitor and enable volts and power, you can see how each mod is operating with your batteries. Here, with an almost 10 year old Sony 18650, for my 30 watts, the voltage drop is ~.55V (not good). When the lowest V (middle vertical line hits ~3V) I'll need to recharge.
  13. You mean check battery? The icon? What value and where? In the 80C you cannot adjust the battery curve which controls the icon or the low cutoff value, as you can in the 60 and 60C. What battery and what watts are you using in the 80C?
  14. Sent you a private message. You need to read and action it.
  15. Wayneo
    Pan
    7 seconds IS the limit. Not a bug. https://forum.evolvapor.com/topic/76116-oxva-xlim-pro-2-dna-max-puff-time-nwkg/#findComment-945935
  16. None of your 3 videos worked or showed up. I don't think if you click on them here they will show for you. AND THAT'S FINE AS I DIDN'T ASK FOR THEM, because I understood your words. In the future (what has worked for me) is use that 'choose files' option and you're done, nothing else to do. 🙂
  17. Just gotta ask. Using that same charger and cable in the same socket, will it show charging on a different device (phone, etc)?
  18. Open a 'Help Desk' ticket here. ⬇️ Link in my signature line. ⬇️
  19. You can try a hardware reboot on the device. (Remove the pod and disconnect from USB. Then hold the Fire button until it reboots. It should take about 10-15 seconds.)
  20. Never heard of this issue before. Here's what I would do, and in this order Contact the place of purchase as it's 'dead on arrival' for a replacement. Contact OXVA as it's 'dead on arrival' for a replacement. Open a 'Help Desk' here. Link in my signature line.
  21. @magman007 And now SP69 has been released. Read the release notes.
  22. That firmware does not address this issue, just what you read for the past 2 versions, and updates are always posted here. I have never had any communication with Oxva, and know nothing about documentation in their goggle drive (or even if it's accurate). DWCraig and I (among others) have been testing these since February.
  23. That firmware is 2 updates shy of the current. Download and install this one. It will also inform you of future updates. You need to go under 'tools' to install it. SP68 Yes, SS does raise its resistance when you puff, and drops back down as it cools.
  24. what resistance coil? what power setting? replay yes/no? what firmware is on your mod (bottom right hand corner of escribe - Device Monitor)?
  25. Thanks for that reply @magman007 what resistance coil? what power setting? replay yes/no? what firmware (bottom right hand corner of escribe - Device Monitor)? Not using the above settings, back to stock (default) And no errors with a new coil
