  1. Wayneo
    Replay Mode
    No, not the way you'd think. You can zero out the field location and icons but You would need to check it all works the same. Why would you or anyone else want to remove 'Replay' from the mod? There are other 80 watt mods on the market with different boards, and cheaper.
  2. Is the lock resistor necessary when using the temperature control function? <- NO, not necessary if you have a stable atomizer as noticed in Atomizer Analyzer. For a boro device I'd leave it available. Also, why can't I set the room temperature? <- The room temp is read with the resistance, but you can make it changeable.
  3. The easiest thing for you is to find a theme that already has it and do the same for yours. IIRC Frank's theme among many others have a puff reset.
  4. The board must also be connected to a battery for escribe to recognize it.
  5. How can I help when that IS NOT an Evolv product? Find the pin layouts on line, or ask the manufacturer. This is now the third connector you are inquiring about, what happened with the connector from a few days ago?
  6. Post a photo of the mod screen. Just looked. It's not a DNA mod.
  7. For starters @balt did you ever try 'session mode'. You never came back and updated this post? @RicketyPumpkin Your vendor should have given you instructions on how to set this up based on their testing, and looking at those photos and your comments I don't think it will work for you. Any material file you used with Arctic Fox will work on your Therion. Hell, it started as a clone of escribe. DNAs have always had the ability to use TFRs and TCRs and AF copied that, so whatever you already have can be uploaded on your Therion. I'd really suggest you ask that dude with a thermocouple and same version crucible to share the material file with you. Could you post a link to their instructions?
  8. Using this diagram, follow pins 11-15 *Take note of pin 15.
  9. No, not normal. Reach out to your place of purchase, there should be a warranty of some sort. Failing that open an RMA at the Help Desk. Link in my signature.
  10. Correct, NOT a DNA. Their display and font is a dead giveaway. Especially that backward slash through the zero. 😉 If you're just a plain watts user it'll be a fine mod.
  11. Can you post a photo of the main screen. Lost Vape makes non DNA versions of many of their mods (while keeping the same name). That main screen will be different.
  12. You can let your batteries run down to the Low battery warning. That all depends on your vaping style.
  13. 2A charging is the Max, limited by the board, no matter what steamcrave says 🤔 and that’s shared by 4 cells, so that’s really only .5A per cell.
  14. I plug mine into the nearest outlet to me. You should take whatever safety precautions you believe necessary. I believe there are fire retardent charging bags sold but never heard of anyone using them, maybe you already use one for your current batteries.
  15. @sma Sure looks like you've left a review on the WRONG theme. At this point in time, no one has downloaded this theme. 🤪
  16. The 80C is 128x128 pixels. It is a slimmed down 'theme designer' application. You have a maximum of 4 backgrounds and 6 'set' fields. Backgrounds can be stylized, and easily changed to another while in use. Fixed Fields - Coil ohms, battery, watts, replay capable/on/off, status, and settings. There is also a status line. Those are fixed fields. You can also define your 'language' ------------------------------------------------ 80C je 128 x 128 pixelov. Ide o zoštíhlenú aplikáciu „návrhára tém“. Máte maximálne 4 pozadia a 6 polí „set“. Pozadia sa dajú štylizovať a počas používania jednoducho zmeniť na iné. Pevné polia - Ohmy cievky, batéria, watty, možnosť prehrávania/zapnutie/vypnutie, stav a nastavenia. Je tam aj stavový riadok. Sú to pevné polia. Môžete tiež definovať svoj „jazyk“
  17. Yes, and the new Evolv data/charger board is 2A
  18. 2 things. I didn't include the link because it didn't have 'Replay', the comments about the snow in the wallpaper and the other link posted seemed more complete. I only searched 2 words, with 2 extra options after clicking that magnifying glass. 'Files' and 'all words'. Glad you're set.
  19. I'm pretty sure the 7 year old 'DJLsb Vapes Therion Theme' v 1.0.0 posted here by himself would not be a derivation.
  20. In my signature line, see that link 'Help Desk', click on that, you'll be talking directly to Evolv.
  21. One (1) post, 7 years old for a dual battery DNA60, vaped at 50-60 watts does NOT make it common. Edit: In my signature line, see that link 'Help Desk', click on that, you'll be talking directly to Evolv.
  22. Really? On THIS forum? I think you are mistaken, or show me.
  23. Is yours working fine now? I think that mod does NOT use the firing button on the board, instead using an external button. Not sure about the 2 smaller buttons, but a wonky fire button would screw things up. Have they actually replaced boards? EDIT: Both small buttons and the USB connector are on a daughter board. So NO ON-BOARD buttons at all are used.
  24. Hello 👋 You musta figured out your issues and abandoned this post❓
