NO. It is NOT. Something else has been changed. Screen added maybe?
AND PUT THE DEFAULT EVOLV THEME BACK ON THE MOD. WHAT IS THE NAME OF THAT THEME, IT IS SHIT. CAN YOU READ 'MENU ERROR' ?
replacing 250C board and screen, questions after assembly
Wayneo replied to rsandage's topic in Modders' Forum
You have 8 profiles where the ohms and temp are written in case you set them up that way. You're seeing that with no atty. No, but whaetver firmware you choose you should use the International version (more features) -
Did this new board ever produce vapor? Still waiting for screenshot.
So, did it ever work at all with this new board? Using escribe, go to a different profile (not the one in use) that shows zero for ohms, down bottom you see Atomizer analyzer, click that, post screenshot.
I'd start by pulling the button cover and check for juice ingress. Wipe down the silicon cover and button pcb with Isopropyl alcohol. While it's off check if Dev Monitor still shows pressed. Then the same thing for the board itself. Use a soaked QTip to press the buttons many times.
The best way is to look at what @dwcraig1 said. So (using his setup @ 50watts, he was getting .38v drop while firing). He asked "Compare yours firing at 50 watts with a cell of similar charge" Great screenshots by the way, and you can get multiple lines on each (on my Mac I hold the control key). Beginning and at the lowest point and maybe even after. Here's one now from my 80C boro, 28 watts with boost to 38 watts, old Sony. At the 38 watts with boost I had .4V drop, and during the regular 28watts only .3v drop. EDIT: CAN YOU LOSE THE 2ND 'VOLTAGE' IN 'CURRENT PUFF' AND ENABLE' POWER AND POWER SET
That's pretty funny considering these were 3 dudes with VC San Aio's. Then this happened.
Looking for a 3D printing case
Wayneo replied to 彦兮 YX's topic in Connectors, Components, and Accessories
I'd search the large free 3D stl file sites, because this really smells like a spam magnet 🧲 to me, but I'll leave it until the first spam post. -
Boost for Watts mode somehow going to 22 on DNA60C
Wayneo replied to Exro's topic in EScribe, Software and Firmware
Search works. https://forum.evolvapor.com/topic/72299-getting-the-most-out-of-250c-in-tc-mode/?do=findComment&comment=941203 -
The mod has the ability to have 4 languages stored with it, but only English is populated by default. You can use escribe -> Display, look for Language (far down the page). Using (1) as a sample, you can create another as French or just overwrite the English. Then 'upload settings'. If you want to share your translation for others, you can do that here.
You don't need to post the same problem twice. Ever. What version of escribe are you using? Found in the bottom right corner of Device Monitor or in About escribe. Post a photo of your main mod screen.
probleme connection escribe palm custumizedv2
Wayneo replied to cedricm01's topic in DNA 75 Color and 100 Color
I have no idea what you're talking about, or if you did as I suggested beforehand. I cannot help you any longer, but someone else might. Failing that, you should open a 'Help Desk' ticket, link listed below. -
Load the latest version of escribe from here. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=940849 Try plugging directly into your PC and not through a hub. There is no easy 'on and off' at all, only a lock, then a state of sleep, then a power down. -
Does your mod connect to escribe? Are you asking about lock and unlock, or 'session mode'? DO NOT TYPE IN ALL CAPS, IT IS ANNOYING. -
Do you know if that is an Evolv charger board? After removing the cable from the board, what was the battery voltage?
What kind of mod is that? Have you done anything with the battery connections? It looks like the JST connector is not connected
Try taking a longer puff, like 3 seconds. Describe your coil? I run my GX's at mid 40's, 2x24/32 n80.
You can download the default theme from within escribe while your mod is plugged in, when it first starts up. Why do you want to remove 'Replay'? I use it with my 3 Taifun GX's just fine, even with Nichrome, SS, and Titanium.
No, not the way you'd think. You can zero out the field location and icons but You would need to check it all works the same. Why would you or anyone else want to remove 'Replay' from the mod? There are other 80 watt mods on the market with different boards, and cheaper.
I have two questions: Regarding the "TC" function of DNA60C
Wayneo replied to AuthorVapes's topic in DNA 60 Color
Is the lock resistor necessary when using the temperature control function? <- NO, not necessary if you have a stable atomizer as noticed in Atomizer Analyzer. For a boro device I'd leave it available. Also, why can't I set the room temperature? <- The room temp is read with the resistance, but you can make it changeable. -
The easiest thing for you is to find a theme that already has it and do the same for yours. IIRC Frank's theme among many others have a puff reset.
No compatible USB Devices are connected.
Wayneo replied to Exro's topic in DNA 75 Color and 100 Color
The board must also be connected to a battery for escribe to recognize it. -
How can I help when that IS NOT an Evolv product? Find the pin layouts on line, or ask the manufacturer. This is now the third connector you are inquiring about, what happened with the connector from a few days ago?
