  1. Easy, just use straight watts at the risk of a dry burn from your cotton.
  2. Let me give you a general explanation based on what you have written. Replay wants to recreate the puff you saved. Your coil/mesh will raise its resistance when you fire it, and lower its resistance as it cools back to ambient temperature. When in your 'Replay' mode, but NOT enabled, the mod keeps track of that resistance curve created by your puff. And when you click 'Save Puff' your mod tries to recreate that curve. Sometimes exactly, or at lower wattages. Your mod 'right now' shows 'boost:Punch' at 3 (but not on), 'warmth' at 1. So right now you get no boost of watts initially, and it's just 50 watts. Once you click 'save puff' warmth now enters the picture. IF you were chain vaping your coil before enabling replay and your coil has cooled to ambient you will get even more watts than 50 but not too much. That's warmth. OR depending on different factors you definitely get less watts than what you initially set. Like if your coil is not as saturated as when you enabled replay. You can actually vape that mesh almost DRY without a dry burn. If you have any questions or want me to clarify anything let me know. Or if I have cleared up your understanding.
  3. I can't look at that. For the third time, look at dwcraig's S C R E E N S H O T
  4. You need to plug into your PC, and start escribe. I need you to go into escribe (with mod plugged in) and do a full screenshot of the profile you're using. When you start escribe you'll see 'current profile' and a number. Click below on that number then do a screenshot.
  5. @dwcraig was right when he said it could be your wicking, but post an escribe screenshot of the profile you are using. Bolded words have special meanings Screenshot instructions in my signature line ⬇️
  6. IMHO you've gotta meter out all your connections. For the USB-C you know it has worked outside the box. I'd lift that off and see if it connects, then lift at the board end if it still didn't connect. What else could it be? Same thing for the battery. Using 1 battery, measure it externally then in each slot at all the connection points to the board. Then do the other battery slot. Same thing for the fire button and up/down.
  7. Great news. 👍 Let us know the final outcome if you remember 🙂
  8. Well, if that was after i said then open a Help Desk ticket. ⬇️ Link in my signature line. ⬇️
  9. I'm too tired to guess what Device Monitor shows
  10. B- and G ground is cell 1 negative. Pin 1 is cell 1 positive and cell 2 negative. Yes, Pin 2 is cell 2 positive and needs to be bridged to 2-4 plus B+ like you have. But you need to clean it up. I also worry about all that exposed wire on the red. When you're done, use your multimeter and measure Ground + Pin1 (cell 1 voltage), then Pin1 + Pin2 (cell 2 voltage).
  11. DO YOU SEE ME POST %'s IN MY POSTS? Now look at your cells. You really need to redo that soldering or clean it up so solder is only each pad from ground, pin 1, and pin2. I'll tell you from now, if I see a single % in anymore of your posts, someone else can help you.
  12. Right now it's stuck uploading that file you chose. Follow my first post.
  13. Exit escribe, restart PC and escribe. Try to upload again if it does not automatically restart the upload by itself.
  14. You're seeing the 'batt' warning because you're hitting the 'low voltage' warning because the battery is sagging down to ~2.9v. Look at your Room vs. Board Temp at 150°F. A lot of heat is being generated internally trying to give you that 60watts. Isn't that the solder/wire free mod where everything is just screwed down? If it is, see if any are loose and can tighten them up. P.S Screenshot instructions in my signature line for the future.
  15. Restart your PC and escribe. Use the cable that worked. No image shown. Don't drag and drop, just choose and upload image (do not insert image). Is it the evolv USB-C board?
  16. The bottom of the board has like a little longer section. Is there a white (JST) connector there, or are there some thin wires directly attached to the board? Just a photo or 2 of that area would be good.
  17. Definitely not a bug, not a board problem. Wiring or connector problem. Do you have a multimeter? I have never seen the innards of a Riva, but you could check the voltage shown for cell 2, and what the board sees.
  18. Thank you. There's all sorts going on there. You need to change your battery specs back to normal. For 'size class' that should be back at 'normal', and 'cell soft cutoff' 2.75 volts. Then 'upload settings to mod' From 'Device Monitor', look at your 'cell 2' it's showing 1.1v. That is the problem. Unplug mod, physically swap your battery positions in the mod. Plug mod back in restart esribe -> device monitor. If cell 2 still shows a low voltage it is your mod wiring or connection. If cell 1 is now low it is a dead battery.
  19. OK, then also (in escribe) click 'mod' -> 'battery' and do another full screenshot
  20. Did you ever click 'Restore Defaults' in escribe? I need you to go into escribe (with mod plugged in), then start 'Device Monitor' and do a full screenshot. No need to take a puff.
  21. Follow these steps and report back. In escribe (with mod plugged in), check you are in a 'profile' that has 'use replay on this profile' checked. Make sure for coil material it is 'watts' or something like that. (Not SS) Remeasure the resistance of your coil on the mod. Take a couple puffs and see if you can enable replay. If you cannot start replay, post an escribe screenshot of that profile. Start Device Monitor. On the left, click these checkboxes only. Power, power set, temperature, cold ohms, live ohms. And a full screenshot after taking a puff and pausing the screen.
  22. Screens do die from time to time, but not usually in your way. If it were me, I'd remove the screen, clean the connectors on the zif connector and the screen area that touches. See if it's any better. You can purchase new screens from protodiy.com Also this has been moved tp the 250C area.
  23. It's all done on ONE page, under the Display tab. You should also read this post. -> https://forum.evolvapor.com/topic/72254-theme-editor/
