Note:
I hope you guys like it!
Material FireMaterial Ocean
  • You can use replay now with any coil material.
What's New in Version 2.1.0
  • Enable/Disable replay from the Atomizer Profile screen. Forgot this one from my to-do list.
Major version 2.0.0 - Everyone should update!
There has been a lot of new development in the recent weeks. This is a major update and everyone should update, especially anyone running 1.5.0 or lower.
  • The theme incorporated two main screen UI since 1.6.0. Material UI has been made the default UI, and the old UI is now called Classic UI. You can enable Classic UI from the settings.
  • Lock screen now shows the charging/power bank current when plugged in. There is also a new gauge when using the mod as a power bank.
  • Atomizer Profile and New Atomizer Detect screens have been majorly overhauled. You can fire from the Atomizer Profile screen again.
  • Atomizer Profile screen now lets you adjust the Pre-heat power.
  • On the Atomizer Profile screen you can adjust the Pre-heat temperature either via a Punch gauge or via a Temperature field. You can switch between them with the new toggle. For more information see the UI reference picture below.
  • Atomizer lock feature is now available in all types of profiles. Previously it was only available in TC profiles. This decision was made because EScribe lets you lock resistance in any profile, and sometimes it's necessary to lock the resistance in mods with a spotty 510 connection.
  • Bugfix: Mystery click from "coil power" to "cancel replay" while replaying has been eliminated.
  • Various other tweaks throughout the theme.
What's New in Version 1.6.1
  • USB connection status added to lock screen. Thanks @retird
What's New in Version 1.6.0
  • Gauges now has two different UI for the main page. I've incorporated elements from the Material-ish themes on to the Gauges theme. Thanks @BlindBuck for the idea!
    You can enable the Material-ish UI elements by going to System > Settings and enabling "Material-ish"
  • Minor refinements of the various gauges and variables on the main page.
What's New in Version 1.5.0
DNA75c now supports replay!
DNA75c now supports replay with the new international firmware 1.1 SP33.2 INT. As such I no longer need to maintain two separate versions of the theme. You can flash the same Gauges 1.5.0 theme file on both DNA250c and DNA75c.
You have to have 1.1 SP33.2 INT firmware flashed on your DNA75c device for this theme to work.
blue_moon979
Report ·
   5 of 5 members found this review helpful 5 / 5 members
Share this review
Vapin
Report ·
Share this review
auzideals
Report ·
Share this review
DMAN
Report ·
Thanks.
Share this review
Pphish
Report ·
Share this review
micksvapes
Report ·
LOVE it
Share this review
runder
Report ·
...beautiful theme! 😇
Share this review
Logan
Report ·
Share this review
Kaan
Report ·
Best thx
Share this review
jessey
Report ·
Excellent design love it.
Don't know if feasible ..
Share this review
Stephan Müller
Report ·
Share this review
zark
Report ·
Хорошая работа
Share this review
Mick077
Report ·
Share this review
sed0y
Report ·
Good fo my Mirage 75D. Thank
Share this review
Wookash
Report ·
Although I am still new to the whole DNA stuff, I have managed to go through quite a few themes by now. I am honestly impressed by this one - it's beautiful in its simplicity and very intuitive. Just recently installed it on my Lost Vape Mirage DNA 75c and I love it already - will definitely stick with it for now as it's the best of the themes I have tried so far. Looking forward to new updates. Kudos to the maker!!
Share this review
Spat
Report ·
Amazing theme, I really love it. Good job!
Share this review
parrot
Report ·
thank you make theme i use really good!
i have some question.
i press and hold the fire button while the screen off, the screen will be briefly broken and the lock screen will appear. Firmware issue?
i use  250c paranornall^^
Addressed in the discussion section :)
Share this review
Stepladder
Report ·
Share this review
Sinister Dex
Report ·
Just got a Lost Vape Paranormal DNA250C and adding this theme was the first thing i did. Absolutely amazing! Thank you!
Share this review
TopCat
Report ·
Lovely UI really clean and simple. The majority of the settings are accessible too.
Share this review
martiemartz
Report ·
The best theme I ever came accross. Simple, comprehensive and easy to use (from a dna user of some time already, might require a bit of learning curve for newbies). Topnotch work! Thanks for allowing us to use this theme.
Share this review
Mr.Ninno
Report ·
Share this review
Mastervaper
Report ·
Good theme this one...Thanks for sharing
Share this review
Vapesignals
Report ·
Simple but well designed. Looks stunning! The creator has done a fantastic job. Thank you and keep up the great work
Share this review
omghax
Report ·
Absolutely amazing... thank you.
Share this review
