Note:
I hope you guys like it!
Material FireMaterial Ocean
What's New in Version 1.5.0   See changelog
DNA75c now supports replay!
  • DNA75c now supports replay with the new international firmware 1.1 SP33.2 INT. As such I no longer need to maintain two separate versions of the theme. You can flash the same Gauges 1.5.0 theme file on both DNA250c and DNA75c
Changelog from 1.4.2
  • Fixed the screen lock issue in both version. Turns out too many things were updating on the main screen while firing that caused a lag. The lag probably caused the system to not register the rapid clicks trying to lock the screen.
  • Resistance lock status icons have been changed once again. Please see the attached screenshot for an explanation on how this new version works. Sorry to have made so many changes to this.
  • Last puff screen now shows the puff counter.
Changelog from 1.4.1
  • Fixed the "All conditions must have the same size" error for DNA250c version. Sorry about that guys, thank you Yorkyboy for pointing it out!
Changelog from 1.4.0
  • Puff counter overflow fixed
  • Live Puff now doesn't show temperature if not in a TC profile
  • Added a ton of new DNA250c specific features. Ported them from the Material-ish themes. All three themes now have the same features and customization options.
  • Resistance lock is now active in TC profiles only.
  • Added replay warmth gauge in atomizer profile screen. You can't fire from this screen anymore. There's no back button on it anymore, press the fire button to exit.
  • Like 13
  • Thanks 25
blue_moon979
Vapin
Khaled Shehab
Good Job
auzideals
DMAN
Thanks.
Pphish
zark
Хорошая работа
Stepladder
neX
Sekker
Thank you, Sirtimi Titbit!
micksvapes
LOVE it
runder
...beautiful theme! 😇
Logan
mykl10
Kaan
Best thx
Twinkie Manhammer
Max038
storm119
myk376
· Edited by dwcraig1
DazClimax
skyrockets1uk
jessey
Excellent design love it.
Don't know if feasible ..
Stephan Müller
Mick077
sed0y
Good fo my Mirage 75D. Thank
