You need the latest international firmware 1.1 SP33.2 INT (included with EScribe Suite 2.0 SP15) on your DNA75c for it to work.
Note:
I hope you guys like it!
What's New in Version 1.6.0 See changelog
Gauges now has two different UI for the main page. I've incorporated elements from the Material-ish themes on to the Gauges theme. Thanks @BlindBuck for the idea!
You can enable the Material-ish UI elements by going to System > Settings and enabling "Material-ish" - Minor refinements of the various gauges and variables on the main page.
What's New in Version 1.5.0
DNA75c now supports replay!
DNA75c now supports replay with the new international firmware 1.1 SP33.2 INT. As such I no longer need to maintain two separate versions of the theme. You can flash the same Gauges 1.5.0 theme file on both DNA250c and DNA75c.
Changelog from 1.4.2
- Fixed the screen lock issue in both version. Turns out too many things were updating on the main screen while firing that caused a lag. The lag probably caused the system to not register the rapid clicks trying to lock the screen.
- Resistance lock status icons have been changed once again. Please see the attached screenshot for an explanation on how this new version works. Sorry to have made so many changes to this.
- Last puff screen now shows the puff counter.
Changelog from 1.4.1
- Fixed the "All conditions must have the same size" error for DNA250c version. Sorry about that guys, thank you Yorkyboy for pointing it out!
Changelog from 1.4.0
- Puff counter overflow fixed
- Live Puff now doesn't show temperature if not in a TC profile
- Added a ton of new DNA250c specific features. Ported them from the Material-ish themes. All three themes now have the same features and customization options.
- Resistance lock is now active in TC profiles only.
- Added replay warmth gauge in atomizer profile screen. You can't fire from this screen anymore. There's no back button on it anymore, press the fire button to exit.
With version 1.6.0:- Download
