Everything posted by dwcraig1
dna 250 Tuglife DNA 250 Screen light malfuncion
dwcraig1 replied to Tugnick's topic in DNA 200 and 250
Did it work properly ever? -
The new Paranormal.Same old BS.
dwcraig1 replied to Smokin Dave's topic in DNA 75 Color and 100 Color
I don't have one so I need to ask. Does the 510 connect to the board with a ground wire or is it chassis ground? Same question for the boards's B-. I'd be looking towards things like that. EDIT: Well at DJLSB Vapes on his video I was able to see the ground wire on the 510 but not much else as it resisted disassembly. So still want to know how the board is connected to the battery negative. -
A screen showing sag while firing would be most helpful. (pack)
How to prevent DNA from dying after disconnecting from USB
dwcraig1 replied to Lowbytes's topic in DNA 200 and 250
Is this being reported as happening on mostly 2 cell mods?- 25 replies
- cell1 = 0v
- not booting
- (and 3 more)
Inductors.
Triade 250 . Battery reads 84% on batteries with full charge
dwcraig1 replied to dleone32's topic in DNA 200 and 250
Try dropping the watt hours shown in the Mod section of Escribe by 15% and wait awhile.- 10 replies
- 1
IPV2, but can be found in many others. Escribe will show your battery sag....for better or... Oh, I didn't do that, it was factory. I did solder the wire on the end of the spring where it contacts the batter on the last one I built (it came with the springs)
- 29 replies
This modification works well when using a coil spring (they in earlier times worked good enough at lower amps) Factory done below. The wire is soldered to the disc.(braided wire)
- 29 replies
That style of contacts is fine for toys and low amp draw flashlights and such but not a high amp device like a DNA200
- 29 replies
- 1
It sounds to me that it's charging only.
A rounded surface against a flat surface has very little actual contact area, flat to flat has much more.
- 29 replies
With the addition of the PCB the battery becomes longer than 65 mm. Then perhaps the user decides to screw in the battery cap till it's flush......Bingo....the problem arrives. Example: Typical Capacity: 2000mAh Nominal Voltage: 3.6V Discharge Voltage: 2.8V Charging Voltage: 4.20+-0.05V Max Continuous Discharging Current: 30A Dimensions: Length: 66.9mm Diameter: 18.30 Weight: 46g
Explain your situation here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
I'm assuming that after opening Escribe and it didn't connect that you pushed the "connect and download setting " button...correct? Also the version of Escribe is for the 250....correct? I had something similar happen awhile back but can't remember just what.
Have you tried using a different USB cable?
A new battery is a good idea, there is sure to be some damage from it sitting that low for an extended period.
Your cells are below the voltage that the charger will start charging from, You will need to do USB Recovery charge. At the top left of Escribe under the tools tab is the option for USB Recovery Charge. It's a slow process and you may have to do it numerous times.
Lavabox dna 200 battery charger but box won't work.
dwcraig1 replied to Hot93stang2001@gmail.com's topic in DNA 200 and 250
Try this, explain details here: https://helpdesk.evolvapor.com/index.php?a=add&category=1 -
I think you will find that it's this guy. I feel just the opposite, I cringe at the idea of removing the battery from the board so I charge almost always with USB.... for the same fears.- 25 replies
- 2
- cell1 = 0v
- not booting
- (and 3 more)
On an ERM case that I broke a screw off in one of the boards mounting holes I put a machine screw with a soldering tab and nut through one of the 510' holes through the case and soldered a wire to the tab and output GND. I had to mount the screw that used in my Dremel. I chucked it in my Dremel and run it's head against a file to get it to fit the hole properly. Just saying.
